Washer stuck on pause
Was working fine till heavy load of towels. found them wet with water in machine. tried to spin. keeps saying paused, no error code. I have unplugged, factory reset, cleaned coin trap, taken locking mechanism off, wiped down, no luck still says pause. sounds like signal is going but I don't hear lock click. what next?
5 Suggested Answers
SOURCE: WD12 Indesit washer/dryer
my indesit wd12 is not spinning
Posted on Jan 28, 2008
  • 1294 Answers
SOURCE: Cleaned trap; but still won't drain...
Surely your pump is clogged, which you should dismantle to check or replace.
A very important thing for all front loaders, all pockets should be checked before dumping in machine, small items should be placed in pillow case or special plastfc bag - so they don't slip into inner drum by accident, and clog pipes, etc.
Posted on May 31, 2008
huuum
  • 750 Answers
SOURCE: Affinity LTF7000ES door not staying locked
unplug the washer and wait 5 minutes before plugging it in again!
this resets the system. If this does not work then you may have a faulty door lock, latch, or switch!
An need hands on service on location
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Jan 01, 2009
richroth
  • 9472 Answers
SOURCE: front load washer stuck on final spin
What is the complete model number of your unit?
Posted on Dec 10, 2012
Front load washer stuck on final spin
Dec 10, 2012 | Washing Machines
Laod with bath towels won't spin out
hi, you may find that the towels when wet are to heavy for the belt to grip the drum if it spins with normal clothes in you need to reduce the load when you wash your towels, hope this helps.
Feb 11, 2009 | Magic Chef CAV4000AWW Top Load Washer
My Duet washer doesn't run through the entire spin cycle on heavy duty setting. Clothes come out of washer, naturally,WET!!!!!!!!!!!!!! Seems to spin out better on the normal cycle. spin cycle dosent...
If the drain time exceeds eight minutes, the water valves are
turned off and “F/02” is flashed. Press PAUSE/CANCEL two
times to clear the display.
NOTE: After four minutes the “Sud” error will be displayed,
then four minutes later the “F/02” error code will be
displayed.
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make
sure the pump is running.
4. Check the drain pump filter for foreign objects.
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER KEEPS STOPPING DURING CYCLE need to pause and restart x's
i would remove hte bottom access panel (3 screws across the lower front) o fmachine. form there you will gain acess to the "button trap" its a clean out for the pump assembly, sounds as if there is a something clogging the drain there fore preventing washer form high speed spin. beaware when the plug is removed there will be a bunch of water behind so be prepared with some towells, ( i use a kitchen plastic bag to collect water and any other gunk that may come through
Dec 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Oct 25, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Ge front load washer model WSXH208A Will not spin
Mine kept stopping mid cycle also, pouring water on the floor, then the start/pause button flashed and the door unlocked. I found the solution to clean the lint filter on the GE Adora. Go to http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
I just did this and my washer is now running instead of the flashing start/pause and door unlocking. It was fairly easy. Make sure you have towels and a flat pan to catch the water if you don't have the machine on a riser. There may be water inside so a wet vac may be helpful too. Once my washer finishes what was in it, I have these funky towels to clean. You'll be very surprised what you find in the filter! Best of luck!
Oct 13, 2008 | GE WSXH208A Front Load Washer
Wont spin
Sep 17, 2008 | GE WSXH208A Front Load Washer
I have a zanussi jetsystem iz16s and it keeps pausing just after its filled up with water and coming up e20 (I think thats the error code) any ideas what the problem might be.
Sep 11, 2008 | Zanussi FJS1225W Front Load Washer
Error codes
if this is a fridgidaire washer, I guess it's a clogged coin catcher. You have remove the front access panel and clean it out. I am working on that now.
Nov 05, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
