Question about Waring WW150 Waffle Maker
Waffles are separating when we open the plates
  • 24 Answers
This is because of one of two things-- either a) your iron's aren't seasoned well enough (meaning they're too "clean" and need some kind of non-stick cooking spray) or b) they're dirty and need to be cleaned. A lot of people don't realize that a dirty waffle iron will stick just the same as one that's "too" clean will.
Sometimes you can jiggle the top part of the iron when you're opening it and keep the waffle from separating-- or take a butter knife and slip it in on top to remove the top half of the waffle from the iron before fully opening it.
Posted on Sep 14, 2009
  • 4,070 Answers
In my experience this is due to sticking on the plates. I spray a little cooking spray on them with each batch I make.
Maybe they arn't quite done.
Posted on Jul 12, 2009
2 Suggested Answers
  • 27 Answers
SOURCE: Waffle plates stop heating
The most common reason for not heating up is because of a blown thermal fuse. Apparently the controller lets the iron get too hot or the fuse is out of manufacturing tolerance - and so the fuse opens.
The green lamp is normally lit when the relay is off and dark when the relay is on. When cold, the relay normally turns on within a second of power-up (switched on). During power-up, the green (ready) lamp should flicker on, and then as the relay clicks, go dark. If the green (ready) lamp does not flicker, the fuse is probably blown.
The fuse is clamped inside the bottom clamshell in silicon tubing. A replacement fuse (240°C) can be purchased from many sources. The fuse should be re-attached to the wires with new all-metal crimp fasteners.
If the iron is getting too hot and blowing thermal fuses, you may be able to avoid this failure by keeping the thermostat set lower.
Posted on May 25, 2010
I recently bought a Bella waffle maker but it separates and sticks to both sides
did you ask whoever assisted you in purchasing if it was non stick? if it was take it back it must be faulty.
and if it isn't apply light amount of butter on both to and bottom plates before making waffle, quick fix!
Oct 20, 2017 | Bella Kitchen Appliances - Others
I lost the instructions for my sunbeam waffle maker, and I dont know how long Ihave to bake it.
Here is a direct link to the User's Manual for your appliance:
http://dl.owneriq.net/d/db0acd4e-57c1-43f0-a51b-4ef04ad30e2d.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
See page 2 of the manual for detailed operating instructions. Basically they read as follows:
Preparing Waffles
1. Close Waffle Maker and plug into outlet. Use only voltage specified on bottom of Waffle Maker. The Power light (Red) and Ready light (Green) will come on.
Caution: Touch Waffle Maker only by handles during use or directly after use. Take care not to touch hot surfaces.
2. The Waffle Maker is ready for initial use when the Ready (green) light goes out (approximately 2-4 minutes).
3. Open Waffle Maker, pour approximately 3/4 cup waffle batter onto grids. For best results, pour batter around outer edge of waffle maker. Close cover. It is very typical to have a small amount of batter run over grid and down Waffle Maker. However, if an excessive amount of batter runs over, use less batter.
4. Close the Waffle Maker by lowering the upper plate onto the lower plate and secure with the safety latch. Do not open cover while steam is escaping. Most waffles bake in approximately 2-4 minutes, depending on personal taste. Waffles are generally done when the Ready light (green) goes out and when steam no longer escapes from sides and front of Waffle Maker.
5. When waffles are done, remove with a fork or wooden tongs. Note: Be careful you do not scratch the non-stick cooking surface.
6. Close cover and wait for Ready light to go out before preparing another batch of waffles. The next waffle may be baked in less time because the plate will store heat.
I hope that was helpful to you, good luck and take care.
Joe.
Aug 31, 2011 | Sunbeam 3852 Waffle Maker
I have a swb7re waffle iron. What's the best way to clean it?
Hello, W/D here.
Not everyone will tell you this, but here's the best way. When you are finished with the waffle maker, the plates will be oily. That's good. Wipe down the outside of the appliance with mild soapy water, followed by clean water. Wipe down the plates with clean water only, just enough to remove any left over waffle material. Then, dry the plates with paper towels, or a soft cloth. You want to avoid detergent on the plates, as this strips the oil off which seasons the plates, making better waffles.
Best regards, --W/D--
Feb 10, 2011 | Star SWB7RBE Waffle Maker
The waffles stick and separate when I open the top
You really have to use a release agent, like pam. Waffles have a ton of surface area that needs to release.
Jan 24, 2011 | Krups FDD912-75 Expert Belgian Waffle...
Need Manual
I found only one other reference to cleaning this model on the internet and that TWB2 did not have detachable plates. You should not immerse this. I generally do not clean the "Teflon" surface of waffle makers - leave it oily. I do clean the outside with a damp soapy sponge.
My experience with waffle irons is that you should lightly oil the inside (spreading everywhere with a boars hair brush) just before adding your first waffle batter. Even non-stick surfaces need a little oil.
>>My Waffle Tips: The batter should contain more egg and oil than a pancake batter does. If your waffles are too chewy, you mixed the batter too much and made gluten. The egg whites should be beat separately to stiff peaks and folded gently into the batter. The batter should be quickly spread across the lower griddle, filling every void. Pay attention to the amount of steam coming out of the griddle and the smell - this correlates to the moisture content of the insides and the crispness of the waffle outside.<<
May 21, 2010 | Toastmaster TWB2 Cool Touch Belgian Waffle...
I need a user manuel i tried to make waffles the other day and they stuck to machine. what a mess
even though it may have teflon on the plates it will still need nonstick cooking spray or butter brushed on both plates between before each waffle made then watch the steam once the batter is in and the lid down the more steam the less done wait for very little steam to be coming out and open should be pretty good. let me know if this helped thanks goofballlovers
Mar 10, 2009 | Toastmaster 200 Waffle Maker
Repalcement plates for Model 270A Toastmaster Waffle Iron?
There is no way you can get replacement plates for you Toastmaster cheaper than you can buy a new one, the most expensive Toastmaster waffle maker I found was $30. the cheapest was $15 shipping will be at least half of that.
Feb 09, 2009 | Toastmaster 287 Waffle Maker
Waffles sticking and separating
try washing the inside of the waffle maker with a damp rag then dry..
Jan 05, 2009 | VillaWare 5800 Classic 4 At-A-Time Waffler
Salton Belgium Waffle Maker
I, too, was searching for that wonderful Belgian Waffle recipe and thought, no problem, I'll just look on-line. I couldn't believe it when Salton didn't have it posted on their site (if they did, I couldn't find it) and was taken to your requests for the recipe. So, I went the whole mile, or should I say traveled over mountains of files, and couldn't believe that my filing system still works after all of these years, the Salton Belgian Waffle Maker & Recipe Guide for Model No. WM-4 was right where it was supposed to be. (And my husband, and prior bosses I should add, have laughed at how I save and file everything. I'm glad I can share this with you all now...
Basic Belgian Waffle Recipe
1 cup all purpose flour
1 tsp. baking powder
1/2 tsp salt
1 tsp sugar
1 cup milk
1 egg, separated
1/2 tbl butter, melted
-Sift dry ingredients together in a bowl
-Add egg yolk and milk to the dry ingredients and beat together thoroughly.
-Beat egg white until stiff, stir 1/4 into batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated waffle mold. The light should be off. When batter is added, the light will go on. When the light goes off again, the waffle is done.
-Makes about 6 waffles.
Chocolate Waffles ("which make great ice cream sandwiches," says the recipe book.)
1 tsp baking powder
1/4 tsp salt
2 tsp sugar
2/3 cup milk
1 egg, separated
2 Tbl melted butter
1 1/2 squares semi-sweet chocolate (1 1/2 ounces)
3/4 tsp vanilla
-Add milk, egg yolk, and vanilla to dry ingredients and beat until well blended.
-Melt butter and chocolate together in microwave or double boiler. Stir chocolate mixture into batter.
-Beat egg white until stiff, stir 1/4 into the batter to lighten it and then gently fold in the remaining egg white.
-Pour a scant 1/2 cup of batter onto the heated heart waffle mold. (Hmm, the WM-4 isn't shaped into a heart??? Oh well, moving onward...)
Serve sprinkled with powdered sugar or cinnamon or topped with vanilla ice cream and chocolate sauce.
Aug 17, 2007 | Salton WM8BEL Belgian Waffle Maker
Kitchen Appliances - Others Logo
536 people viewed this question
Top Waring Kitchen Appliances - Others Experts
jdtech
Ps Daengr
Ps Daengr
Level 1 Expert
bradyrock325
Level 1 Expert
Are you a Waring Kitchen Appliances - Other Expert? Answer questions, earn points and help others
