Question about Toro Garden
I have a Toro model 20007 front drive is not working. Wheels will turn freely. I have both wheels off. I open up the small box and check the drive. seems clerar of debris. Help please
SOURCE: Wheels do not freely roll backwards
SOUNDS LIKE THE PINONS ARE ON BACKWARDS. THE KEY SHOULD SLIDE OFF THE PINIONS WHEN PULLED BACK AND LOCK WHEN ENGAGED. YOU HAVE THE OPPOSITE PROBLEM OR ITS BACKWARDS!
Posted on Oct 16, 2008
  • 48 Answers
SOURCE: The front wheels on my lawn mower have locked
on yours you must replace the entire tranny unit - to make it roll you can remove the front wheels and remove the small gear on both sides - doing this of course will turn it into a push mower not self propel
Posted on Oct 21, 2008
SOURCE: poulan/weedeater self propell not working
Poulan/weedeater Model#we6452se serial# 030497m 000378
Posted on Oct 24, 2008
  • 4 Answers
I had this same issue. In my case, the sheild that keeps the dirt out of the gears in the wheel has gotten broke and the gears filled with junk and jammed the wheels. I just have to take the wheels off and blow the junk off the gears.
Posted on Jun 07, 2009
  • 89 Answers
SOURCE: craftsman lawn mower wheels won't turn
take cover off the top off deck and see if your belt have came off next turn deck sideways but before you turn it sideways take air filter off cause oil can come through and ruin the filter noe look and make sure the belt is on the pully
Posted on Nov 04, 2009
Why won't my front wheels turn after changing the transmission and belt on my Toro model 20012 lawnmower?
Thjere are 4 possibilities:
One, the wheels have plastic hubs with gearing on the inside shell, they may be stripped and not engaging.
Two the transmission is shot; you can check this by removing the belt from the blade pulley and engage the drive control handle; then manually turn the pulley on the transmission by hand, if the wheels engage the tranny is ok.
If the wheels and the tranny are ok then it could be the cable or belt.
Aug 02, 2014 | Garden
Front wheels do not move on self propelled lawn mower
check the cable at the front gear box
Mar 24, 2012 | Toro Garden
Craftsman model 917377411 front propelled drive not engaging
On your model I beleive these wheels are driven with small gears inside the inside diameter of the wheels. If the shaft is turning, then you probably have a gear problem. Remove a wheel and inspect both the wheel, and the small gear. They are prone to wear.I'd suggest replacing all four parts if worn.
Jul 18, 2010 | Craftsman Garden
My toro 20016 self propel is only turning the right wheel
Remove the left wheel and check the gears inside the wheel and the drive sheft. They might be worn or sheared and need renewing or maybe they just need oiling. Spray them with WD 40.
May 20, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Rear wheel drive does not push mower when engaged. But, when mower rear wheels are lifted off the ground, they turn weakly.
remove the rear wheels and check the gears in the wheels- they are plastic and part of the circumfrance on the inside of the wheel. If worn replace wheels.
also check belt- it should be tight with very little play when drive is engaged ( obvioulsy check this with engine off).
Nov 28, 2009 | Toro Lawn Mower With Toro Power Tools
Toro self propelled will not move wheels. Checked engaging keys
Remove the front wheels and see if the cogs that are molded into the wheels are stripped. If they are stripped out that could be where the noise is comming from.
Good Luck let me know if this helps.
roundo4
Aug 13, 2009 | Toro Lawn Mower With Toro Power Tools
TORO Wheel Horse Lubrication
this is like a snapper drive it has a rubber plug that you pull out and fill with 0 grease lube meaning 0 is the weight of the grease that comes in a tube. you can get it at any little small engine repair or automotive shop.
Jun 11, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 20016 self propel
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
214 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
