The zig zag is not normal when I sew it it has straight stich in between if you no what I mean thanksThe zig zag is not normal when I sew it it has straight stich in between if you no what I mean thanks
You can't post conmments that contain an email address.
THE ZIG ZAG STITCH ON MY BROTHER LS2125 DOESNT ZIGZAG NORMAL IT MAKES STRAIGHT STITCHES IN BETWEENTHE ZIG ZAG STITCH ON MY BROTHER LS2125 DOESNT ZIGZAG NORMAL IT MAKES STRAIGHT STITCHES IN BETWEEN
With most machines after you select the Zig Zag setting you then select the normal stitch knob that can be adjusted for long or short stitch lengths and that should also give you adjustment on your Zig Zag stitch length .
Yes, because a zig zag stitch is creating a wide stitch and the tension on the thread is going to pull the fabric within the seam together, you can't seam thin fabric with a wide zig zag. It will "tunnel together". If you are using this stitch to neaten a raw edge, then try using the serpentine or three step zig zag where the needle pierces the fabric 3 times in each leg of the zig zag, this will give better results.
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Check the position of the Button Hole Stitch adjuster that is directly under the stitch length control. It looks like a flat head screw and should be straight up and down for normal sewing.
you start with the broad zig zag stitch bar across the top then you go down the left side using a smaller zig zag stitch then you make the the broad zig zag stitch at the bottom then you make the smaller zig zag stitch on the right side all the way to the top broad zig zag stitch & your done the right side zig zag does not go beyond the top broad zig zag stitch
FIRST > Make sure your bobbin case is threaded correctly...
NEXT For normal straight sewing the top tension should be around 5, for zigzag or satin stitch you need to lower your upper thread tension a bit. Try it at 4, if it still pulls your bottom thread to the top try it at 3 etc...
i believe your machine is skipping the stitch on the RIGHT side as you sew and this is normally a timing problem. Lower your needle about 1/16 inch and try it . It might work to finish your project but it will need to be serviced to have the timing corrected. sewman7
