Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
HE error on LG dishwasher
I get an HE error after the rinse cycle. It used to happen intermittently but now happens a 100% of the time. If I choose a different program like "Gentle", it seems to go through. Any help appreciated.
Regards,
Anton
    Problem Solver:
  • 8 Answers
HE is a HEATER ERROR
Possible causes
¥ The Circuit of Heater is troubled.
¥ The Thermistor is troubled.
¥ The Heater is shorted.
¥ The Relay Circuit is troubled.
Possible solutions
¥ Repair the Circuit of Heater.
¥ Replace the Thermistor.
¥ Replace the Heater.
¥ Repair the Relay Circuit..
Posted on Jul 20, 2009
    Problem Solver:
  • 6 Answers
Check the temperature of your water going into the unit if it is above 70 degrees Celsius then you need to turn your hot water tank down. If the temperature inside the unit it too hot it will HE error and shut down.
Posted on Aug 03, 2009
LG TurboDrum DD 8 kg WT R801 machine with LE error. Usually I can override the spasmodic message by manually setting the wash, rinse and spin cycles, but not today. The motor speed indicator is not
You have an intermittent problem with the machine's motor. Have the stator and rotor sections of the machine checked out by a qualified electrician.
Jan 01, 2015 | LG Washing Machines
LG Dishwasher LD-1403W - loud whirring noise during wash
We had same problem machine same age, had a service person in and the found that the motor was dying. LG wouldn't cover saying that it was normal wear and tear. b
Jan 01, 2010 | LG Dishwashers
We have an lg dishwasher LDS5811ST and there is an error code. LE or an or 2 capital E's with top missing off of the first E. We tried turning the breaker off for 20 minutes and there is water going into...
Kevin,
The LE error on the LG dishwasher means that the dishwasher believes there is a leak because the level of the water is decreasing between the time the wash or rinse cycle begins (with the proper amount of water) and before the cycle ends and the water is pumped out.
After you have ruled out a real leak (check closely underneath) then here is the next step. 99% of the problem with LE is caused by the drain hose not having a high point between where it connects at the dishwasher and the drain.
The fastest (but not best) way to fix this is create a loop in the drain hose raised high up underneath the counter top. Attach it so it will not fall back. The cause of the "leak" is the natural siphon effect that can develop when the drain hose has not high point. (exactly like the siphon tube you may have created in science class.)
Please report back what you find, OK?
Sep 12, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Frigidaire dishwasher not completing cycle.
hi,
The cycle doesn't complete
If the cycle doesn't complete, check these:
Water-heating cycle
Timer
Water-heating cycle
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows:
On some units, the pause is timed and the unit continues after the allotted time.
On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too.
Timer
Timers don't often fail. But if every other part of the dishwasher seems to be working properly and the timer knob seems to be stuck in one place--doing one function continuously--the timer may be at fault. Dishwasher timers can't be repaired. If yours is defective, replace it.
I see an error code
If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Good Luck
Thanks for using FixYa
Jan 03, 2009 | Dishwashers
Dishwahser rinse cycle running for hours
Do you have high temp rinse or sanitize selected? This will pause the timer during the final rinse cycle to heat the water. The sensor might be bad. Try the quick cycle, I don't think this heats the water.
Jun 09, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Doesnt dry dishes
The heater on this unit only comes on twice, once in the wash cycle, and again in the Sanitary rinse. During the drying cycle all that happens is a vent opens and a fan comes on. The fan removes the hot moist air from the unit and the dishes dry off. If your water is not hot enough, this is why your dishes are still wet. Rinse aid also helps to sheen off the excess water as well.
Sgt 48
May 06, 2008 | LG 24 in. LDF7810 Built-in Dishwasher
Noisy Dishwasher
has there been any hard objects such as fruit seeds nuts egg shells ect. is it doing it in all the cycles
Mar 28, 2008 | Dishwashers
Long cycle times
Many dishwashers heat the wash and/or rinse water to a higher temperature, as the cycle calls for it. In these cycles, the dishwasher pauses after it has filled with water, waiting for the water to reach the pre-set temperature. What happens next, depends, as follows: On some units, the pause is timed and the unit continues after the allotted time. On others, the cycle can't continue until the water reaches the higher temperature. If you have this type of dishwasher and the water isn't being heated (say, because of a problem with the heating element or thermostat), after the unit stops at the heating cycle, it never continues. When you repair the heating-system problem, the "cycle problem" is fixed too. About the led: If your dishwasher has a digital readout and you see an error code, it may indicate a problem with the unit. If this happens, look up the error code in your owner's manual to find out what the problem is.
Dec 30, 2005 | Bosch 24 in. SHU6802UC / SHU6806UC...
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
1,380 people viewed this question
Top LG Dishwashers Experts
Marvin
Marvin
Mike
Lollo Pop
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
