Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
Internet sharing problem
I have d-link des-1008d model when i connect with other computer file and printer is shared but my internet connection is not shared?
plz help me how can i do it
  •  Robert
    Robert May 11, 2010
    Is this switch plugged directly into a broadband modem? Or is the switch plugged into a router that is plugged into a broadband modem though the WAN port?
  • Hassan Raza
    Hassan Raza May 11, 2010
    Hi, Have you shared internet connection sharing (ICS) service on active internet system? Which type of internet service are you using? Dial Up? DSL? LAN? Regards; Hassan
  • 3 Answers
Hi..hmm try to remake new connection and it must all be the same like if your connection is MSHOME the other computer should be MSHOME. if is dosnt work configure your router wan and Lan.
Posted on Sep 03, 2009
I brought a des 1008d swtich i want internet sharing with swtich .i connect all pc with this switch
You have to connect all the computers you have to the switch and connect your DSL or cable modem also to the switch and enable DHCP in it. Configure all your computers to obtain IP address automatically. This should work and you should be able to share the internet across the network
Dec 21, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Why i cannot connect broadband connection through switch more than one computer at same time? But only one computer can connect.
Internet through your broadband connection is normally setup for single user.
If you need to use multiple systems to be connected to internet then you need NAT (Network Address Translation) to be enabled.
But unfortunately the D-Link DES-1008D doesnt support that.
Dec 02, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
How can I install or connect my d link to the internet line and my computer
I assume you have a broadband connection which you are directly to your computer.
In that case please connect the broadband ethernet cable to one of your switch port.
Get a new CAT5 or CAT6 ethernet straight cable and connect one end to any free port of the DES-1008D 8-Port Ethernet Switch and other end to your Computer.
No configuration needed to be done on DES-1008D 8-Port Ethernet Switch
Best Regards
Nov 20, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
When i get connected to d-link des 1008d switch port the computer will get automatically configured 255.255.0.0 to subnet mask therefore i have class c ip address and i dont have internet connection...
u no need to worry about the subnet mask 255.255.0.0
just do the following connections
  1. connect a utp cable from modem/router to dlink switch.
  2. connect a utp cable from switch to ur pc
Assign ur pc manually with following configuration
ip: 192.168.100.5
subnet: 255.255.255.0
gateway: 192.168.100.1
and your router with ip: 192.168.100.1 And enable pppoe in ur router.
Thats it you are connected to internet. No need to enable ics etc.
Jul 05, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Two pc connection by dlink switch
connect the router to the switch using any port-it does not matter which port you use. Connect each computer to any port on the switch-it matters not. The router will assign IP address to the computer as they are added.
DONE!!!
Good Luck
Sep 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
I dont how to connect my pc's using D-Link
Dear! first of all you need a 4 port hub or 8 port switch that have easily available. Now, first of all, put three wires (Straight Through Cable) in three different ports and other side its ends put in that nodes or computers. Now they are connected to each other. You want to sharing data for each you should run setup wizard for sharing inside the network places after that computer required a restart. Now the computer will start and data will share to each oher. You should use IP address for computers, first of all IP 192.168.0.1 for first PC and 192.168.0.5 for second PC and 192.168.0.10 IP for 3rd PC. Enjoy, everything is accessible now ...........
Thank You
Jul 28, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Printer sharing wirh USB hub
I would connect the printer to the main computer, network the 2 computers and enable printer sharing. The only draw back to this is that the main computer will have to be on in order for the other to print. Vista makes this easy to do.
Jan 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
I have a d link DES-1105. cant get more than one computer to work on hub/switch.
Hi!
Unfortunately, hubs or switches cannot be use to share internet access specially if it's connected to a modem. To share internet access, you will need a router. If you prefer not to use a router, you can enable ICS (Internet Connection sharing) on one PC and share internet access to the others. However, the PC that will share internet access will need two ethernet cards (or LAN cards).
Your setup will look like this:
If internet is not a concern, and you just want to connect the computers to share files and resources, you will have to se your computers to static IP. You do not need any additional device - just connect your computers to the hub, setup a static IP on all the computers.
If you need further assistance setting up static IP on the computers, please reply and I'll give you the step by step instruction for that.
For any setup, a router will be the best option.
I hope that helps.
Good luck and have a nice day!
Nov 30, 2008 | Computers & Internet
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
268 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
