A
clean indicator that flashes/blinks 7 times and then repeats, indicates
a problem in the dishwasher which should be investigated and not just
the control 'reset'! That is why the control will not let the
dishwasher start once such a condition is detected.
If the dishwasher's
electronic control doesn't detect a water temperature increase during
the main wash cycle, that symptom can occur. No water temperature
increase could be caused by a problem in the heater element, its
in-line thermostat, the related wiring or a problem in the electronic
control.
It is also possible
just the washer not spraying properly (possibly from blockage in the
filter or problem in the pump), the dishwasher not filling sufficiently
or draining prematurely or even a problem in the door latching
mechanism's switch(es) could cause it.
*Some actual investigation should be undertaken to isolate and correct the cause of the symptom.*
Once corrected, the
error display may have to be cleared from the control manually. That
can usually be done by putting the unit into diagnostic mode by
pressing the key sequence 'Heated Dry, Normal, Heated Dry, Normal' and
then pressing cancel.
This was taken from "http://www.appliance411.com/faq/blinking-clean-light.shtml" But is common D/W repairman knowledge
Mike
