Odd how the few who tried to answer ignored this part of the question, "I don't have a computer". Or the fact the person specified the item in question is a micro SD card for a phone, but people kept answering as if it were a flash drive, or a computer was related. Open your eyes people. Sheesh!!!
As with most phones with SD card readers they will have their own method of mounting/formatting a card for use in the phone. DO NOT use the computer to format the card prior to using it in a phone.
Insert the card into the phone and open settings. Find memory card options. Scroll down to mount card option. Select that to mount the card. Another option should be available or should appear after the card is mounted. Format the card using this method to be used on the Moto E.
Same thing applies to camera's... they will have their OWN format /mounting method and you shouldn't use a PC version format. As the device will have some format or parameter is requires in order for the card to be used in that device. Only use a PC format if the product specifies to use a PC to format.
SOURCE: sandisk micro sd card forget password in nokia
Try putting the memory card in your PC and formatting it from My Computer.
If you have a camera that takes this kind of card, you can try to format the memory card from there as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
SOURCE: problem with the sandisk 4gb micro sd card. my
some comp cant read the card a cheap fix is go to radio shack and get a reader/writer card its a usb connnection and should work for it did for me even my printer couldn t read my 4 gb
SOURCE: Format 8gb sandisk micro sd problem
Often times, these jump drives have a tiny, nearly invisible read-only switch on them. Check to see that it isn't set to read only, which will inhibit formatting, among other things.
SOURCE: Sandisk 16gb microsd formatting incorrectly
Hi unfortuanley you have been sold a fake card
http://memory-cards-blog.blogspot.com/2009/12/dane-elec-8-gb-compactflash-memory-card.html
Please can i ask that you leave ffedback and vote if this has been useful
SOURCE: Sandisk cruzer 16gb, Macformat, tv won't recognize
Dowload codec Klite pack, via Google, and open the files with that media player, the tv should then pick it up, seeing as its a multi codec reader program, Hope it helps
