Question about Iomega Computers & Internet
My Iomega portable hard drive (Model # RPHD-U) powers up when I plug it into any USB port, but neither my system nor any other system that I connect it to can find it. The problem is not with the cable because I can plug a similar portable hard drive (different manufacturer) in using that cable and it works.
sandrew
  • 2961 Answers
SOURCE: iomega external 100mb zip drive
No just connect to your usb and windows should automatically install drivers after recognising the hardware.
Posted on Mar 13, 2007
Balisonu79
  • 42 Answers
SOURCE: iomega portable hard drive
Please check in device manager that storage mass device is not showing yellow mark if it is please first remove any storage device showing yellow mark in usb devices in device manager >
You wil find device manager in windows 2000/xp in control panel >administrative tools>computer management ..then click on device manager
Second thing is please remove/uninstall any storage device information from device manager
Restart the pc and then go to device manager and see there should be no entry of storage device in usb root devices .After this fix your usb device and it will work definately
Regards
Balisonu79
Posted on Feb 13, 2008
  • 217 Answers
SOURCE: Portable Hard Drive refuses to stay linked with PC
I'm thinking the usb port being used on the home pc may be bad. Do you have any others available to use?
Posted on Jul 11, 2008
SOURCE: Portable Hard Drive will not respond / install
how many wattage had your computer? you need to upgrade your power supply.you need also to check your bios setup on usb port
Posted on Oct 03, 2008
SOURCE: External hard drives not recognized by MacBook Pro using SIIG eSATA II 2 Port ExpressCard-M
Fixed- I purchased one of the following esata cards with the JMB360 chipset and it worked in my brand new Macbook pro 17" right out of the box.   My other eSata from SIIG, inc would not mount any drives or accept any drivers.    So the silicon based eSata's must have some type of hardware conflict with Macbooks.  (P.S.  I purchased the one from Best Connectivity for $20).   These cards all use the JMB360 Chipset:
  • ApioTek (1 port card) (EXTREME eSATAII Express Card)
  • Best Connectivity (1 esata)
  • GWC Technology (GWC BS1020) (2 ports)
  • nGear (Moved to the Sil3132 chipset list. See my more recent post about this)
  • PPA Int’l (2 ports)
  • VC (an original brand of Vintage Computer Inc.)
  • Syba (1 Port)
  • Sunix ECSA24J (Discontinued)
Posted on Feb 24, 2009
My Iomega eGo Portable Hard drive 500 GB main light is not showing when i plug it in through the usb drive, i think this connection may be damaged. Is a way to solve it to buy dc5v to usb cable and plug it...
Have you tried connecting it with the Firewire cable that came with it? (your pc may not have the correct port) or connecting it with a different usb cable?
Has the drive been dropped? it has a protection system which shuts the drive down when it is dropped. you may need to put the HDD into a different caddy or plug it directly into a desktop pc's motherboard to retrieve you data.
I hope this helps.
Jan 21, 2011 | Iomega eGo Portable Hard drive 500 GB ...
I have a Iomega 500G portable hard drive RPHD-U, when I plug the USB 2.0 in I hear a clicking noise on my HP computer. The portable haed does not show up in the my computer devices. This device use to be...
Hello
At the link below you will be directed to a tip i wrote on this exact issue. Click on the link below to navigate to page.
Click HERE.
Please feel free to let me know if you need any further assistance.
Thank you for using Fixya!!
Kind regards
Lock123
Jan 08, 2011 | Iomega eGo Portable Hard drive 500 GB ...
I require instruction on the use of my portable hard drive.
its very easy. just connect to your computer usb port. If your drive requires power put the power adapter. Before connect to frontpanel USB of your system. Once check your front panel usb is working or not. Check with some other memory stick or mouse etc.. Because if your front panel usb connect reverse there is chance to lose your hard drive..
Jun 24, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
MY external portable hard disk won't power up
Hello Sir,
does this disc have some external power source?
If so then just plug it in.
If it takes power through USB then your USB port is damaged, try other USB port.
Cheers,
Mike
May 08, 2010 | Iomega Silver USB 2.0 Hard Drive
No cpu will recognize the drive or acknowledge it is connected to the cpu. This problem occurs across all the ports (firewire and usb). The drive lights up and receives power from the cpu and hums and...
make sure that you plugged in the Portable HD to a USB 2.0 port. delete the USB root hub from your device manager and install it again. change your data cable.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Mar 26, 2010 | Iomega 250GB Ego Portable HD Red 250 GB...
Hello, I plugged in my iomega 1tb desktop hard drive storage device and the drive does not appear in my drive or computer. I do have the new hardware 'sound' that comes up but I dont have the drive show up...
Iomega 1TB Desktop Hard Drive is a dedicated usb 2.0 plug and play external storage device that has an ability to transfer at 480Mbits/second. having these large capacity storage drive needs a fast connection and additional power source to make sure to run the external unit system properly.
just make sure both power and data cables are properly plugged and connected respectively. if you are using it with a desktop, please always plug your usb connection from the Iomega 1TB external drive to the rear USB port in line where you built-in LAN is.do not plug it in the frontload ports. some motherboard manufacturers uses usb 1 and/or 1.1 only for frontload desktop casing provision.
thank you.
Dec 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
Computers & Internet Logo
1,953 people viewed this question
Top Iomega Computers & Internet Experts
Marvin
Marvin
 Grubhead
Grubhead
Alun Cox
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
