Compaq Presario M2000 PC Notebook
Problem for Compaq Presario M2000 PC Notebook
By Tarsing on Nov 15, 2007
When I switch on, press f1 to resume, f10 to setup appears then freezes
Comments:
Nov 20, 2007
- Still same, can' t run bios setup. When I switch on, press f1 to resume, f10 to setup appears then freezes. The screen doesn't change .
Same Problem
Mar 29, 2009
-   me too -   Guest
Oct 25, 2008
-   i have 100% same problem.cn someone solve this problem please.janjoowa-   janjoowa
Jun 30, 2008
-   Exactly same problem.
Followed steps provided without memory it beeps but still no difference made-   Guest
Nov 25, 2007
-   I have the SAME exact problem-   Roxbox
Best Solution
posted on Nov 16, 2007
Helpful)
rwedinburgh
Rank: Wiz
Rating: 85%, 96 votes
Unless your machine took a bad fall down some stairs, I am guessing you have a problem with hardware. Unplug the machine and remove the battery. Unplug any external devices like cards, USB devices and printers, etc., and then reboot. Is the hard drive running? Try F10 into setup, and then select LOAD SAFE DEFAULTS AND REBOOT, or something similar. If this does not get it going, check to see if the harddrive or memory has become unseated in their bays somehow. Turn the laptop over, remove the screws covering the little doors, lovingly and gently unscrew the harddrive retaining screw and remove it, and then put it back in and secure the screws. Check to make sure the memory modules are seated correctly, and reseat them if necessary. Then try rebooting. If you get the same problem, go into the BIOS again and check to make sure you are booting to the HDD as first, and then start turning off devices in the BIOS and rebooting in cycles until it boots. Also, try booting to CD (for example, OS installation disk) and if that works, you likely have a boot problem or hardware problem on the hard drive.
Good luck....
Comments:
Nov 20, 2007
- If you are unable to get it past the BIOS boot screen, you must have a hardware problem locking out the BIOS from completing.
Try this.
Unplug everything and remove battery.
Turn the machine over, uncover the hard drive in its bay, and remove it. Then try to reboot. If this does not fix it to allow you to enter the BIOS, shut down again and remove the memory and any other card from the system you find exposed on the underside of the machine.
When you reboot, you should either get a BIOS message saying the memory count is incorrect, or other memory error, or else a beeping sound from the laptop. If you do not get one of these, I would guess you either have a motherboard problem, or, possible, the keyboard, which is connected to the motherboard by a thin ribbon, has become disconnected.
If you get the beeping sound or a memory error, try putting the memory back in one chip at a time until you get a memory count and BIOS message and can enter the BIOS. If you put the memory back in and get the same error as before (machine locked, cannot enter the BIOS), it might be a memory problem or (more serious), a motherboard problem.
If you cannot access the BIOS to troubleshoot the problem using the above methods, you probably need professional help with troubleshooting the hardware, or need to find a friendly geek who can help diassemble the machine, test the keyboard and memory, etc. If you want to have a bash at this process yourself, post again with the results of the above process.
Good luck...
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 28, 2009
Not Rated)
druchad078
Rank: Apprentice
Rating: 0%, 0 votes
is there a master reset button for compaq pre m2000 series???? i have no disks,,
Was this helpful?
Yes
No
Solution #3
posted on Jul 26, 2008
Not Rated)
shan73
Rank: Apprentice
Rating: 0%, 0 votes
The problem was resolved when we removed the HDD. the checked with a different HDD problem reoccured.
Removed and replaced the SATA cable. Problem Resolved.
Shantanu
Was this helpful?
Yes
No
Popular Solutions for Compaq Presario M2000 PC
Questions and Unsolved Problems for Compaq Presario M2000 PC
Do you recommend Compaq Presario M2000 PC Notebook?
Answer
Answer
use a acer aspire 5810TZ. what is the icon for the camera?
Answer
hi i hve problem with bios the version i need is f.23 wereas the verion available on site is f.22.... (More)
Answer
my screen has vertical colours half way up my screen so i only have half a screen why is this
Answer
Any device (card) that I try inserting into the pcmcia slot will freeze the Presario M2000 with XP.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
