Question about Nokia 5000 Cellular Phone
Security code not working
I tried all the combination but failed to access the security code.
I forgot my Nokia 6500s security code and i can't access the phone memory
I HAVE A BIG PROBLEM.
well, i cant remember the security code for my nokia 513c2 Xpress Music
i tried every combination in the world and every website on the net and nothing worked.
The thing is, in most 'unlock your phone' sites you need to press * and # but my keypad doesnt allow that, if i press * they go code error and same thing with #. so.. anyone have any advise.
seriously im really desperate lol hurry up :)
Oct 02, 2010 | Nokia 6500 Slide Cellular Phone
My nokia 7500 prism has a security code on there witch ive tried to put in but does not seem to work an i really need the security code to get into to the phone witch i cannot access at the momment i do...
Hello, the standard master reset code for nokia is 12345. But if fails, you can get the code here for FREE*) :
www.nfader.su
kind regards
*) need to key in your IMEI #
Aug 15, 2010 | Nokia 7500 Cellular Phone
Brought a new laptop with wireless installed have a philips SNB5600 but have lost the security key how can i get the code
go to the wireless access point admin settings (not on your wireless adapter on your laptop). then check wireless security settings. if you see something there such as security key, that is the security key that you need to set up on your laptop. if security key is not visible, try to see if there is an option there which says unmask to show the security key, then copy it to your laptop. if all else fails, change the security key in the wireless access point and change all the wireless adapters that connect to it accordingly to the new security key you set it up.
Nov 07, 2009 | Computers & Internet
How to unlock a cathedral electronic safe ea25
After opening the electronic safe (with the pre-set factory code of 159B) locate the small red button on the
inside of the door near the hinge.
2. Press the red button and then release it, you will hear a beep. DO NOT SHUT THE DOOR UNTIL YOU HAVE CONFIRMED THAT YOUR NEW SECURITY CODE HAS BEEN ENTERED CORRECTLY.
3. With the door open, enter your own personal security code, which can be 3- 8 digits long, and confirm your new code by pressing the letter “B” on the electronic touch pad. Before you close the door, try the new security code to make sure the lock release the knob so you can turn it and retract the live action locking bolts.
If the code fails, go through steps 1-3 again. If the code works successfully, then you should lock the safe. When you open the safe in the future enter the security code you have set followed by the letter “B” and turn the knob.
If the incorrect security code is entered 3 times you will have an automatic lockout for 20 seconds before you can try your code again. If the incorrect security code is entered 3 additional times there will be a 5- minute lockout before the code can be tried again.
BATTERY REPLACEMENT
This safe uses 4- AA batteries. Under normal use, batteries will last about 1 year. When the battery is low, a red light will come on warning you that the battery is low. To test the batteries, enter your security code. If the batteries are low the red light located in the middle of the top of the keypad will start to flash.
To replace the batteries, open the safe door with your security code and turn the knob. Push the batteries cover plate, which is located on the back of the door, and replace the old batteries.
YOU MUST PROGRAME YOUR SECURITY CODE AFTER YOU REPLACE THE BATTERIES. SEE STEPS 1- 3 UNDER “ENTERING YOUR SECURITY CODE”.
TROUBLE KEY
A “Trouble key” has been provided in case you forget or lose your security code. Remove the small central panel from the front of the faceplate. Insert the key and turn it counter clockwise. Then turn the knob on the door towards the right. This will manually open your safe. If you lose your key, you may purchase a replacement key by referencing the serial number located under the central panel by the lock.
MAINTENANCE FOR KEY AND ELECTRONIC SAFE
If the door of the safe starts to rub on the door frame, open the door per the instructions above. By the door hinges you will find a threaded stem. Use an Allen wrench to tighten the threaded stem. This will help realign the door and give you trouble free access to the contents of your safe.
Nov 01, 2009 | Home Security
Forgot personal security code
Kindly try code master code 12345 for your nokia. If fails, get the code at www.nfader.su
If still fail , get it unlocked at www.unlock-zone.com
Regards, Jay_
Sep 19, 2009 | Nokia E61i Cellular Phone
How to unlocked a security code for china phone
flash your phone so then you can creat a new code.
Aug 21, 2009 | Nokia 6233 Cellular Phone
I can't find my manual and need to know the radio security code.
Kia replaced radio in father in laws car but failed to update code. Now wants to sell car but radio wasn't working. Kia no help at all !!! 10000 combinations (mathematically) try 1111. Worked for me. cheers
Sep 12, 2008 | 2003 Kia Rio
4 digit unlock code on phone
the defalt code for your phone is 1234 the best advice i can give you is contact motorola and speak to a tech their they have codes to unlock them there is a trick we try some times take your battery out while phone is on some times shocking it will bypass security and if works perform a master reset on the phone that will change every thing back to factory settings the defalt security code for a master reset is 000000 hopefully this will help
Feb 16, 2008 | Motorola Mobility RAZR V3
try to menu the unlock code to be able to use security code. then try 000000,. hope it can help you,. -ronel
Feb 15, 2008 | Motorola Mobility RAZR V3
Nokia 5000 Cellular Phone Logo
162 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
Damen Wong
Damen Wong
