Sony Ericsson W910i Cellular Phone Logo
Posted on Jul 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi. My battery life time won't last for an hour
Hi. My sony ericsson w910i battery life time won't last for an hour and sometimes the phone just switch off itself. What is actually the problem of this phone? I bought a new battery it also shows the same problem.
270rexton
Level 3:
President:
  • Sony Ericsson Master 782 Answers
  • Posted on Jul 13, 2009
270rexton
Level 3:
President:
Answers
782
Questions
Helped
308237
Points
2472
Some files might be corrupted. Try reinstall firmware using SEUS from your PC.
How long is the battery life?
As far as I discover ,up to now, the battery life of the Sony Ericsson Xperia X10 smartphone has been kept under wraps. The official product page is just left blank under the battery performance section. However, with the news of the handset launching in Japan, the official SE Japan site does reveal this juicy information. Given its 1GHz Snapdragon chipset and 4-inch screen, I wasn't putting too much hope in decent battery life, but it's looking reasonably okay.
Talktime with 3G networks should last for 4 hours and 50 minutes, whilst a 3G standby time of 200 hours is quoted. Obviously official numbers are always inflated, but at least you'll hopefully be able to get a good days use out of it before having to re-charge.
Just for your own test;
On the dialler press * #*#4636#*# * and under battery history make sure that your phone is sleeping when you are not using it. (Time spent not sleeping)
If its at 100% then an app you've installed is preventing your phone from sleeping. I think the latest firmware fixes the issue
Please switched off the auto screen brightness and set it manually at about 75% which should shorten the battery life but so far no.
A free program called TaskKiller will definetely help to close the .apps draining battery...
Pls read the articles on the URL below for more info and Tips..
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
How To Fix The Battery Life On The Sony Ericsson XPERIA X10
http://www.sonyinsider.com/2010/04/13/how-to-fix-the-battery-life-on-the-sony-ericsson-xperia-x10/
Sony Ericsson W910i Cellular Phone nck unlock code
hi,
as far as my experience unlock codes are the best method to unlock your phone, i used codes from
http://www.theunlockarena.com/sony-ericsson-w910i/rs13wp9/ to unlock my phone
and it worked well,you need to specify the country and network provider
3helpful
2answers
How to unlock?
To Unlock the Sony Ericsson W910I Model mobile from the Network lock You can use the Unlock Code You can get the Unlock Code at
http://www.wickedunlock.com/sony-ericsson-w910i/rs11wp9/ and Unlock the mobile following the Free Unlocking Instructions Below............
Sony Ericsson W910i Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Sony Ericsson W910i mobile phones. If you enter over a certain amount of wrong unlock codes on your Sony Ericsson W910i mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Sony Ericsson W910i without any SIM Card,
2 - Press the left arrow key/button once,
3 - Press the button * twice,
4 - Press the left arrow key/button once,
5 - The message "Personalize with MNC2" will appear, (or you will have displayed an unlock menu, select the lock you want to unlock)
6 - Enter the Unlock Code.
If your Sony Ericsson W910i does not have a left arrow button/key(e.g. Sony Ericsson W950i) and on a few phones(not all) that have a "JOGDIAL" you must press the "down arrow" key/button instead of the "left arrow" key/button for step 2
My phone was working last night but then i say it was low battery so i went to plug my charger in. when i plugged it in it turned off straight away and hasnt been able to turn on since. i tried plugging...
Hi, The battery cell is too weak to power up the phone.
You will have to leave the phone charging for more hours for the battery cell to come up to be able to power on the phone.
If after charging the battery for longer hours and it doesn't come up,that means the battery cell is dead and will need to be replaced with another battery.
Take care.
3helpful
2answers
I want to unlock my sony ericsson w910i fre how
hi friend,
press * and then press the right soft button to unlock if it doesn't works check this out Unlocking your Sony ERICSSON W910i is just the start of roaming freedom. This safe, simple process is one of the easiest ways you'll ever find to save money. The unlocking code and five minutes of your time will enable you to use your handset in ways you never thought possible.
We need only a short time (no more than 12 - 24 hours ) to generate your Sony ERICSSON W910i subsidy code. The sooner you place your order, the quicker you'll receive the unlocking code and be on your way. Both ordering and entering the code are easy. Just follow the instructions.
How It Works
  1. Select your phone and fill out our order form
  2. We will email your unlock code along with easy to understand instructions on how to enter it.
  3. Put in a different SIM card and enjoy your new freedom.
Once you have received your Sony ERICSSON W910i unlocking code, it is very simple to enter it:
  1. Remove the SIM card. Turn your handset ON
  2. PRESS the left arrow ONE TIME
  3. PRESS the * button TWO TIMES
  4. PRESS the left arrow ONE TIME
  5. The message "Personalize with MNC2" will appear
  6. You may now enter the Unlocking Code we sent to you. It may be necessary to PRESS ENTER or OK
    ERICSSON
    -W910i-,K850i-&-W890i-UNLOCK_...%20-">cgi.ebay.co.uk/UNLOCKING-FOR-SONY-ERICSSON-W910i-,K850i-&-W890i-UNLOCK_... -
hope this helps u
thank u for using fixya
please rate me............................
regards
sivaranjini
Battery last for about 1 day only
hi sir... dont change ur batteries or go for new one... Its becuase the battery pin available in ur mobile device has got damaged... so its unable to store charges for a longer duration...Better give ur mobile for service and they will replace u with new pins.. dont waste in getting new batteries..
thank u rate me!!!
Sony ericsson w910i
if its a pre paid you have to call 1512 for credit balance.
Battery problem with sony Ericsson W910i
Try changing battery with one that works. If it still persists, then it is possible that it is an internal problem with the charge or even with the charger itself.
Thanks
2answers
Sony ericsson w910i
take the cover off remove the battery leave it for about 10 seconds, in the meantime clean the battery contacts then reinsert the battery and turn it on, think its had a build up of static and that sometimes stops the phone from switching on
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
