SOURCE: Maytag electric dryer will not run
Just like the other tech. said, it is most likely your belt or a bad motor. The belt is a pain in the neck to replace because the top, the back and sometimes the front need to come off.
SOURCE: maytag electric dryer. Tumbler won't turn.
The first thing to check is the drive belt. you will need to turn the dryer on its side and look to see if the drive belt is broken. If this is o.k it will be the motor.
SOURCE: disable buzzer on Maytag Atlantis MDE6200AYW
it could be done by taking the control panel off and maybe diconnecting the buzzer other than that what I have researched there is no other way sorry
SOURCE: What colors on electrical cord go with what screw on dryer?
black on first screw/white on middle screw/red on third screw/green to the screw on case that says grnd.
I have voltage going to the motor 120 volts and i check the white wire on top of the timer , i also have 120 v, i cut the white wire going directly to the motor and it runs fine and heats up ,i open the door and the dryer cuts off, hit the start button and it restarts. I just am not getting the neutral to the motor. Is the timer bad?
the timer should cut the hot not the neutral. i would check all the wiring from the plug on.
The red wire going to the motor has 120 volts on it. The light blue wires on the start switch have 120 volts on them, the black and brown wires on the relay (i think it is a relay) has 0 volts always. . The motor has 1.5 ohms on it.
This dryer gas been running for over a year, the breaker and the 220 volts going to the dryer is good.
