Question about George Foreman G5 Indoor Grill
Thermal Fuse? Ok, so I know it's a thermal fuse issue... that much I have gleaned. The problem is actually *getting* to the fuse to replace it. For the life of me, I can not figure out how to access that small red pannel on the underside, which is where I assume the thermal fuse itself to be. Little help?
  • 4 Answers
Re: Thermal Fuse?
Under the bottom hot plate, remove the screws and open the grill, one of the wires has a heat protective sleeve on it and is held to the casing with a clip, the thermal fuse is under that sleeve, I contacted the manufacturer and they said it was not available as a spare part.
Posted on Jan 03, 2009
0 characters
3 Points
Wolfgang puck tri-grill/griddle stopped working, can it be fixed
yes its most likely the thermal fuse and if you take it apart you will find it and they are cheap to replace only a dollar or so , very common reason that most people dont know and throw away and buy new , they are designed to fail about once a year for that reason , you could keep it forever if you get some fuses
Jan 05, 2016 | Wolfgang Puck Electric Grills & Sandwich...
Used this machine 5 times and it now has no power, just dead!
If fuse in plug ok, Then the week spot is the wiring, Bear in mind the elements are in the top and bottom sole plate so stress faults can occur in the wiring between these plates. Also sometimes a thermal fuse may have gone, This component is usually hidden somewhere in the wiring.
Nov 17, 2010 | Breville BGR400XL Sandwich Maker
Foreman gv5 grill just stoped working
There is a thermal fuse in series with the heating coils inside. You will have to disassemble it, find the fuse, take it to an electric supply house and get a replacement. Some soldering "may" be necessary.
Mar 21, 2010 | George Foreman GV5 Indoor Grill
My gr31sb grill wont heat up, i found the microtemp g4 thermal fuse is bad by by passing it and the grill works. how do i get a new fuse?
Don't know if this helps but Radio Shack has Microtemp 10 amp G4A00 Tf 144c (144 deg Celcius) Thermal Fuses. These are the ones with the little red conical end on them. Under $2 each. I needed one to put in my toaster oven. Couldn't find the small metal clips to attach it to the wiring though. Since it is very diffucult to solder these without damaging the fuse, I'll have to recycle the old clips.
Jul 24, 2009 | George Foreman GR31SB Indoor Grill
My G5 Grill will not turn on
I'm not sure, but there is probably a thermal fuse which has blown. These are very difficult to acquire and sometimes very difficult to install (they can't be soldered -- you have to use a crimp connector).
The fuse is about the size of small glass fuse and has a wire on either end of it and it's connected in line with the hot wire coming from the wall outlet.
Apr 21, 2009 | George Foreman G5 Indoor Grill
The electric used to work but now it does not seem to heat
Maybe the thermal fuse as blown inside the heat proof sleave ...
Usualy it's a 240 degrees celsius Thermal fuse ...
But check ...the tempreture should be printed on the tiny metal 'tube'
60 pence each from somewhere like Maplins ..
Jan 18, 2009 | George Foreman 10814 Indoor Grill
Hi pathollis,
I'd contact the manufacturer, especially if it's still under warranty.
Go to
And click on "George Foreman" (lower-right portion of the page), it redirects you to a secure webpage where you can register.
Part of the page reads:
"Call toll-free or visit our websites for assistance if you need more help.
Parts & Accessories:
Phone: 1-800-738-0245 (Monday–Friday, 8:30 a.m. to 8:00 p.m., ET)
Product Warranty:
Service: 1-800-231-9786 (Monday-Friday, 8:30 a.m. to 8:00 a.m., ET)"
If I can be of further assistance, let me know. If this helps or solves the issue, please rate it accordingly.
Thanks in-advance for using,
Dec 29, 2008 | George Foreman GRP99 Indoor Grill
George foreman 10814
The 240 degrees celcius Thermal fuse under the heat proof sleave as blown ...
60pence each from Maplins ...
Aug 26, 2008 | George Foreman 10814 Indoor Grill
Grill Stopped working
I am having this exact same problem. Did you ever get yours taken care of? I was going to take mine apart and look for a fuse...
Sep 24, 2006 | George Foreman G5 Indoor Grill
George Foreman G5 Indoor Grill Logo
326 people viewed this question
Top George Foreman Electric Grills & Sandwich Makers Experts
tina gallow
Are you a George Foreman Electric Grill and Sandwich Maker Expert? Answer questions, earn points and help others
