Question about Sony CRX-230EE (33383923840) Burner
Sony crx 230ee
Cannot back up quicken file. error message" please choose another location. that drive (d) is read only.
Drive was working fine previously.
  • 696 Answers
Hi Rolyn,
This problem is a result of the fact that Quicken needs to compress and adjust the file on the fly as it write it. CD/DVD disks cannot be edited on the fly so the program sees them as an invalid choice. Save your backup to the harddrive, when it's done drag and drop the file to the CD or use your CD burning software to make a copy on CD.
Hope this helps FixYa,
Chris
Posted on Jul 18, 2009
My cd writer driver is showing error code 39
Your drive may have taken a driver update, causing the problem. In device manager, right click on the device and select properties, then under the driver tab, select "Roll back driver". If a driver update is at fault it will complete the roll back and hopefully cure your ills. If there is no driver to roll back to, you can attempt an update under the same tab.
I hope this helps and good luck.
Jul 12, 2009 | Sony CRX-230EE (33383923840) Burner
Quicken 2001 get error message "File NOT Backed Up" I am trying to back up to a thumb drive?
make sure that any file on the thumb drive is not is use while backing up
it colud also be due to a virus infection
also scan for viruses
Jul 03, 2009 | Intuit Quicken 2001 Deluxe (256101) for PC
Using the same quicken file on two networked computers
After you install Quicken on both computers it is no problem. If you put the Quicken file (the data is on the file that ends in .qdf, on a flash drive (you should be able to get one for $15 or $20) , you can carry the file in your pocket on a key chain. Then any time you want to use the file just double click on the file and Quicken will open on either computer. Make sure yo password protect the file and also back it up to one of the computers frequently in case you loose the flash drive.
Mar 20, 2009 | Intuit Quicken® Premier 2006 Full Version...
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
I have reinstalled quicken deluxe 2000 after my hard drive crashed.This has been repaired,All The previous quicken accounts programme has been stored on the d drive. I do not know which quicken files to...
In the C drive Navigate to View menu and choose option "Details"
Now you can see the Created Date for specified files so that you can check which files are older / newer
May 27, 2008 | Intuit Quicken Deluxe 99 for Windows...
New installation on Toshiba lap top. Unable to transfer data from Quicken 99 on IBM lap top. IBM did not recognize flash drive. Copied to email and sent from IBM. 3 messages below with attempts to add...
Try reinstalling Quicken 2008 after uninstalling it first via 'Add/Remove Programs" in Control Panel. this should help.
Also check out THIS article on converting Quicken files to new versions and other info..It may prove to be quite useful..
As for the IBM Laptop not recognizing the flash drive, generally they come with a driver CD. Try installing that on the IBM and see. If you do not have the CD, you should be able to find the driver from the manufacturer's website, or do a google.
Should you have any further questions, please feel to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FIXYA rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Apr 19, 2008 | Computers & Internet
Backing up a Quicken file
This is probably due to an update. Quicken and quickbooks perform updates in the back ground on a frequent basis. The easiest way to take care of this problem would be to create a directory called backup on the flash drive and instruct quicken to backup to it.
Provided you're using windows XP, click on My Computer, select the icon for your flash drive, F: Right click and create a new folder and name it backup. In quicken when you go to backup, just change where it says F:\ to F:\backup
this should fix your problem. Please email back if you have any problems getting it to work.
Dave
Feb 28, 2008 | Computers & Internet
"Disk not ready" message
Unless you are using linux, try typing F:\ not F:/. Microsoft uses a backslash for directories while unix/linux use /.
Quicken Data File
just copy it to hd, open properties (right click file and choose properties) and uncheck "read only" attribute.
you will have a normal file again.
remember that every file burned to cd, will receive the read only attribute.
Nov 29, 2007 | Sonic RecordNow! Deluxe 7.3
Errors when Backing up information from hard drive.
I have several drives backed up and they work fine whenever they are imaged. anyway.. These drives are made for use in Windows and Mac enviorments. It is usually MAC users that have this problem.They are usually preformatted using fat32. because the drive is usually for storage fat32 is sufficent...but there are certain characters that fat32 dosen't care for...Do you have file naming scheme that uses odd characters? if so Those are the file names the error is refferring to. You may choose to reformat the drive using fat32(again) or NTFS(note fat32 has a better chance of data recovery just in case)your main hard drive might be NTFS. The rest is only important if you use a MAC Now if you have a MAC see below. How do I initialise the external drive for Mac OS X? Preparing the Seagate/Maxtor external hard drive in Mac OS X Mac OS X cannot mount a FAT32 partition larger than 137 GB (128 GB binary value). Our partiton is 160 GB (149 GB binary value). Since your external drive comes with a large FAT32 partition preinstalled you will need to initialise the drive to use it in Mac OS X. WARNING: Initialising or partitioning the drive will erase all data on the drive. If you have used this drive on another computer take the drive back to that computer and copy all data off of the drive before proceeding. When the drive was plugged into the Macintosh you probably noticed a message reporting an error that it cannot read the volume. At this point you have the option to initialise the drive. If you missed that message you can initialise the drive manually. Initialising the drive in OS X If you see the volume error, you can click the Initialise option. If you do not see it, then go to Finder > Applications > Utilities > Disk Utility. In Disk Utility: Select the external drive (149.05 GB). Be sure you select the correct drive before proceeding. If you have more than one 160 GB drive then be sure to select the correct one. 1. Go to the Erase tab. 2. Choose the type of partition (Mac OS Extended). 3. Type a volume label. 4. Tick the box that says "Install Mac OS 9 drivers". If this option is not selected, this device cannot be used by a computer running Mac OS 9. This option does not affect Classic. 5. Click Erase. 6. Read the prompt and Click on Erase again if you agree to erase all the data and you are sure the correct drive is selected. 7. The drive will now show on the desktop with a Firewire icon and the volume label as the name. Additional Information For more information on the FAT32 partition size limit in Mac OS X please read document number 107483 on Apple's support web site. For more information about formatting drives in Mac OS visit Apple's support web site. For more information about decimal versus binary capacity values visit our FAQ on the subject. Let me know what happens. Good Luck, Tim
Mar 16, 2007 | Maxtor OneTouch II 100 GB Hard Drive
Sony CRX-230EE (33383923840) Burner Logo
77 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
