Question about Whirlpool Refrigerators
Water is dripping into the refrigerator from the freezer - I have a Whirlpool ET18UMXSW0
  • 585 Answers
There is a drain line from the freezer to a pan beneath the refrigerator. If clogged will result in water escaping into the fridge. Water in fridge can also result if the box is not level, with the top tipping away from the wall. If the box is not chilling properly, then you have another problem with the defrost system.
Posted on Jul 12, 2009
Whirlpool dripping water from freezer drawer
See inside freezer box floor. Do you see Ice layer build up. If so then your defrost drain line is clogged.
Sep 23, 2014 | Whirlpool Refrigerators
Whirlpool refrigerator with top freezer
If there is an ice maker in the freezer, look to see if the water is coming from there. If it is then replace the solenoid valve where the water comes into the back of the refrigerator.
Mar 05, 2014 | Whirlpool Freezers
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Have a Whirlpool refrigerator/top freezer model ET1CHMXKT06. Water from freezer drips into refrigerator. How do I stop this?
Check drain in the freezer which probably runs through the Ref. Pour water in Drain in back of
freezer and see if it drains. some may be getting inside ref.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 10, 2011 | Whirlpool Refrigerators
Refrigerator set on 5 the coldest and there is a water dripping
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water dripping inside top of refrigerator.
if freezer is on top what is happening is your drain hole behind freezer panel is clogged
Nov 11, 2009 | Refrigerators
Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
WATER DRIPS DOWN FROM INSIDE TOP REFRIGERATOR BELOW FREEZER
Not an original solution - but a good one. Remove panels at the back of the freezer compartment to expose the heater unit or heater wire that defrosts the freezer coils and wrap a solid copper wire gently around the heater/ heater wire and place the loose end in the drain. This will conduct heat to the freezer drain and help keep it open. I did see a manufactured part in one of the appliance parts websites but it did not match my unit.
May 29, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
126 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
