Question about Mag Innovision InnoVision LT865s 18" Flat Panel LCD Monitor
I cant find a power cord inlet to connect a wire to, i have a LT8655 modle
  • 382 Answers
Between the monitor and the support is a small plug in for the power cord. It faces straight down. Should be a snap on cover. look where the monitor pivots. Have a good day.
Posted on Jul 12, 2009
Want to fix power cord but cant figure out where a green wire goes from cord
Hi Earl
The green wire from the cord goes to a secure connection on the junction box.
This link and video will tell you all you need to know.
Hope this helps you out.
-Steve
Wiring Dryer Power Cord
Mar 12, 2015 | Dryers
Does my Acer Aspire 5100 laptop have a fuse?
No. Power would be prevented by a bad outlet, power strip not on, faulty or mis-connected power cord, bad connection between the tip and inlet of the power cord, a bad power inlet, or a faulty motherboard. Independently testing each of these until you narrow it down is really the best/only way to figure out the problem.
Nov 16, 2012 | Acer Aspire 5100 Series Laptop Charger...
Is the aspire 5517 power inlet two peices or one peice connected to the motherboad
2 if you are referring to the power cord. 1st piece with an adapter that connects to laptop. 2nd piece is just an extension cord.
Sep 30, 2012 | Acer Aspire 5517 Laptop
How to replace water inlet valve on a hoover 500M washing machine?
To replace your Hoover washing machine water inlet valves watch this instructional video http://youtu.be/78D5ieegS98
Or follow the instructions below
Turn of the power at the power point and disconect cord.
Turn of water supply to the machine.
Disconnect the water hoses
Unscrew the screws on the rear cover and remove
Use a screwdriver to press in the inlet valves plastic locking clip
Pull the inlet valves upwards and disconnect spring clip electrical terminals
Push in new inlet valves and connect spring clip electrical terminals
Reinstall plastic locking clips
Reinstall rear cover and reinstall screws
Reinstall water hoses and turn water on
Reconnect power cord and switch power on
Aug 02, 2012 | Washing Machines
My home has a central vacuum system hook-up but no vacuum installed. My friend upgraded his central system and gave me his Eureka Mega Boss central vacuum system and the accessories, including the pow
The power head requires 120 Volts. Some hoses have a receptacle in the handle for the power head plug, and the hose has a cord at the wall inlet end that plugs into a receptacle. Some hoses have a plug at the wall inlet end that plugs into a 120Volt receptacle built into the inlet. The hose plugs into this receptacle when you push the hose into the inlet. The power for this built-in receptacle is wired with line voltage when the system is installed.
Apr 15, 2012 | Eureka 1810 Central System Vacuum
I need to know how to install a cellanoid in my Whirlpool Duet washer Mod # GHW9150PW4 is there a place to get the instructions?
Are you meaning the Water Inlet Solenoid Valve??????
If yes .... you need to know if your W/P Duet GHW9150P Front Load Washer really has a bad Water Inlet Solenoid Valve for the Hot and Cold water. This valve is where the Hot and Cold water hoses connect to the rear of your washer on the upper top left side in the rear as you are facing the washer. In my opinion it is highly unlikely that your Water Inlet Solenoid Valve is bad....but it is possible. Sometimes the filter screen in the inlet(s) of the Hot & Cold water valve can be stopped up with dirt, sediments, etc. If you turn off the water faucets and remove the Hot & Cold water hoses from the washing machine... you will be able to see the screens...if they are stopped up you can remove them with a small screw driver and clean them and reinstall them.
Hook up your hoses and turn on your water supply Hot and Cold faucets.
Here is a quick test procedure that you can do to verify the operation of the Water Inlet Solenoid Valve.
Verify that your water hoses are hooked up and the water faucets (Hot & Cold) are turned on.
Unplug the washer's 120Volt AC power supply cord from the electrical plug on the wall.
(1) Remove the top cover...There will be three screws on rear area of the cover: Left - Middle -Right.
(2) Once the top cover is removed...you will be able to see the Water Inlet Solenoid Valve...just follow the Hot & Cold water hoses from the wall to your washer. Usually the water inlet solenoid has a blue plastic housing assembly with (2) separate push-on or pull-off quick disconnect electrical connectors. One connector pair provides 120volt AC to the Hot water solenoid and the other connector pair provides the 120volt AC to the Cold water solenoid.
(3) Remove the push on or pull off quick disconnect electrical connector to one of the water inlet solenoids..It does not matter which one at this point in time.
(4) You will need an electrical 120v AC Test Cord. You can make this from an old lamp AC power cord or and old 120v AC Extension Cord. You will need two alligator test jumpers or leads (Radio Shack has them). The end of the test cord that plugs into wall is not to be modified. The other end of the test cord will have to be modified in order to conduct this testing. Strip back the insulation to reveal the two leads that will carry the 120v AC power. You should have one black lead (120v AC HOT) and one white lead (120v AC Neutral). Connect (1) alligator test lead to the black lead and insulate with electrical tape as necessary and connect (1) alligator test lead to the white lead and insulate with electrical tape as necessary You now have your 120v AC Test Cord ready. If you have a VOM test meter..you can connect the VOM meter to the two remaining alligator test leads. Have your VOM test meter set for AC Volts and on a scale that will measure 120v AC. Plug in your test cord to the 120V AC wall power. If everything is OK your meter should read approximately 120 Volts AC.
(5) Unplug your 120v AC Test Cord from the wall power.
(6) Connect your 120v AC Test Cord to your Water Inlet Solenoid Valve electrical terminals.
See Step (3).
(7) Plug your 120v AC Test Cord into wall power. If the water solenoid valve is good you should hear water surging thru the water solenoid valve. If you do not hear the water running thru the valve you can verify if the 120v AC is getting to the valve with your VOM. It should read 120v AC. If it does read 120Volts AC at the terminals of the valve and you do not hear the water then the valve is probably defective: Either stuck shut and won't open or the solenoid coil is open (Bad).
(8) Unplug your 120v AC Test Cord from wall power.
(9) Disconnect your (2) alligator test leads from the solenoid valve and re-install the electrical push on connectors that was disconnected in Step (3)
(10) You can now repeat this test on the other side of the Water Solenoid Valve (See Step 3).
(11) If both sides of the Water Solenoid Valve check out good...then your Water Inlet Solenoid Valve is good. If it does not check out then replace it.
(12) If your Water Inlet Solenoid Valve is good...then ....unfortunately, there is a good chance that the CCU module is bad. The CCU module is in effect a computer control unit and controls the overall operation of the washer. The CCU module will cost approximately $150.00
If you need further help, I’m available over the phone at https://www.6ya.com/expert/henry_239f63a136de60f0
Mar 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have a small proble with my whirpool heater/acThe modle is ace184xs0 and it is tripping breakers. Both the breaker built in the power cord and my wall panel breaker
check the amp rating on the unit, ur breaker may be rated to low, also check outside coil, if dirty(clogged up0 the fan cant cool it down, this will cause comp, to over amp tripping braker
May 22, 2010 | Heating & Cooling
I've just installed a hoover central vaccum SH800CA and when i plug the hose in the inlet, it doesn't turn on. It turns on when I turn on the switch on the canister
The hose connects to a set of low voltage contacts inside the top of each inlet. The vac wiring is connected by a low voltage circuit to each inlet as well. your hose when plugged in completes the circuit when you turn the hose switch on. For simplicity ,I also use a coin to connect the terminals mentioned below instead of dragging the hose with you.
Reinsert the hose with the tongue or cord at 12 o clock or 6 o'clock position. If the vac does not start, rotate the hose cuff to 3 oclock.This over rides the hose handle switch to test the vac circuit.
if the vac still does not start you have a loss of LV signal in your wiring. You will need to back track to make sure you have continuity from the vac to each inlet.
if you have colored alarm or telephone type wire, it is very easy to break a wire strand while fastening so go back one connection at a time and inspect.
If you have no power to any inlets,your problem will be in the main run of wire from the vac, likely to the first connection. If you have power at only some inlets, your issue will be at one of your wire junctions, either at a pipe intersection or where two wires meet at an inlet, depending on how the system was wired.
Post back to say how you are making out
Sep 27, 2009 | Vacuums
Brand new Magellan Maestro 4000 does not turn on or indicate powe
I had the same problem and I solved it by cutting a few strands of speaker wire and twisting them together and inserting them into the center of the generic car gharger end which plugs into the Maestro 4000, It seems that the 4000 has a very small center conducter on the GPS itself and by adding a few strands of speaker wire about 1/2" long into the plug before pluging it into the 4000 it allows it to makes contact with the small power inlet conductor which is smaller than most generic cigarette lighter 5vdc power cords. I did this to mine and it powered up right away. The other solution is to buy the actual car power cord from Magellan which has the proper size connecton and makes proper connection all the time.
Dec 24, 2008 | Magellan Maestro 4000 Handheld GPS...
Mag Innovision InnoVision LT865s 18" Flat Panel LCD Monitor Logo
123 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
