Question about Emerson Fans KF160OI High Country Olde Iron Ceiling
How to hook up light kit to fan motor. They both have clear plastic wire nuts that do not remove without force. what is the solution for getting wired. Thanks, Michael
  • 308 Answers
The clear plastic connectors that you refer to are not wire nuts, they are connectors. You will have to cut these off, and use wire nuts to wire your fan. Hope this helps
Posted on Jul 15, 2009
Trying to attatch the wires from the light kit to the fan but the blue and white wires from the fan have white caps on them covering the wire. Do these need to be removed in order to attach the wires with...
They're called "wire nuts". Turn them counterclockwise to remove, lay the wires you need to join side by side with the ends of the bared sections even and screw the nut on.
lp
Dec 29, 2010 | Vacuums
Move existing ceiling fan to another location
make sure light switch is off.
start by unscrewing the fan blades. take out bulbs and bulb covers etc.
once all thats down the fan and light switch cover has three screws you can take out and unplug it to get it out of the way. look around the base for some more screws to take out and remove the big cover thats covering the motor. get it out of the way. now you will see the bracket thats holding the motor in place. remove them screws and bolts, but be careful and ready, the motor is heavy, and as it comes down, normally hamptom bay has a coat hanger type hook that will let you hook the hanging motor on the hook long enuff to disconnect the wires ONE AT AT TIME and then put the wire nut back on it just for safety. when they are all disconnected , you can un hang the motor , and then inspect the new fan bracket, it probably fits the same hanger. but if not, you need to take the bracket motor hangar down and get the wires out of it. if the light switch is off IT WONT SHOCK YOU. just dont touch the bare wires to your hands ANYWAY. if they touch each other thats ok. IF THE WALL SWITCH IS OFF. ok now its removed.
Jul 31, 2010 | Hampton Bay 24002 Ceiling Fan
Light kit
Hi .. usually the light kits come with only two wires that are not connected .. a white and a black. Look again in the install kit and make sure you have located all the wires .. the wire you want is connected to all the lamp sockets .
May 03, 2010 | Casablanca Fan (3845T) Brushed Nickel...
Hampton bay ceiling fan stopped lights work
you can test the light switch by temporarily hooking up the light bulb to where the fan normally goes ....the bulb will only work on the highest speed setting but can prove if the switch is bad or not . turn power off before woking in there ... if you know someone with a volt meter then they could quickly test the switch for you .. they can also test the motor for continuity .. .. most of the time the trouble is simply bad connections inside the wire nuts ... like insulation not skinned properly or wire not in the wire nut properly ..you can remove and inspect each connection (power off of course) ... sometimes there is a seperate power line for the fan and light ... so they can be independently controlled externally ... thats not needed when the pull chains are the only off on method ...
Apr 15, 2010 | Hampton Bay 52 In. White Redington...
Wiring light kit to ceiling fan
connect the white wires from light kit filter to the white wire labeled "for light" from fan. then connect black wire from light kit filter to blue wire from fan. use wire nuts to make the connections
Jan 17, 2010 | Hampton Bay 24002 Ceiling Fan
Replacing a ceiling fan pull chain light switch.
that is strange
normally a 3 wire switch could only be able to control 2 things + off. black would be common, red would be one fan speed or set of lights and blue would be the other fan speed or set of lights.
if it is a replacement, couldn't you just hook it up like the switch you are removing?
most likely the black wires are grounds for everything and white would be power. hook it up however you like. white power would hook up to the black wire on the switch and then the blue to one light and red to the other set of lights white wires.
good luck!
Jan 06, 2010 | Westwind Classic Hugger Polished Brass 52"...
Need to tighten the ceiling fan but cannot get the cover off the top near the ceiling! How do you remove the cover with wrecking the whole thing?
does it have a light kit? if it does remove the likt kit and inside you will see a black and white wire be sure to turn wall switch off and tpe it to the off postion once the light kit is off you will see a shaft that runs from the center up to the cealing you will see a nut that is on the threded shaft remove that nut to get to the upper part of the motor. and reinstall after words. you can also go to hampton bay web site and you can see a parts blow up of your fan and you will see how it works. hope this helps. go to this web site and sign in and you can get the picture.
http://www.homedepot.com/webapp/wcs/stores/servlet/ContentView?pn=KH_BP_LF_Hampton_Bay_brand&langId=-1&storeId=10051&catalogId=10053&cm_sp=THD_Marketing-_-hampton_bay_brand_page-_-vanity09
Sep 29, 2009 | Hampton Bay (261025) Dual Mount Ceiling...
I have a hampton bay fan with a light kit. the year of it's make is 2003. the light switch chain will not pull properly to turn the light on or off can you help me?
You probably need to replace the switch.
The most difficult part of this process is getting the lamp kit free from the fan.
Turn off the power. Test it by turning the fan/light on. Remove the lamps and the shades to lighten the load. You will find 3 or 4 screws holding the kit onto the fan. Electrically, you will find a green or bare wire, a white wire and a colored wire all connected with small wire nuts, or maybe you will find a plug. Remove them, pull the wires apart. Place the wire nuts back on the wires coming from the fan. Take the light kit and yourself down the ladder. Find the switch and remove it.
Take a picture with your cell phone before you do this so you can refresh your memory when you get back from K-mart/Lowes/Home Depot or where ever you get your hardware with the replacement switch. Reverse the process and proclaim "Let there be light".
Be aware that in some cases the power to the fan is not controlled by the wall switch. Just because the light is off doesn't mean the power is off
Let me know if this helps you.
A
Sep 21, 2009 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
I cut the plastic wiring connector, fan motor to to light kit, from a Harbor Breeze paddle fan. This connector had a short in it, and I wanted to hard wire around this connector. I reconnected all of the...
The top wires, black, white, and green are the ones to hook to just run the fan. The blue wire is wired with the black at the top if you want the lights to work. At the light kit, the blue and white wires power the lights.
Apr 21, 2009 | Electrical Supplies
Adding light to Hunter Fan w/o light
you can get the kit at home depot, it has a plug inside, under the cap. very simple
Dec 25, 2008 | Hunter 52" Ceiling Fan With Light And...
Emerson Fans KF160OI High Country Olde Iron Ceiling Logo
59 people viewed this question
Top Emerson Fans Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
Are you an Emerson Fans Dryer Expert? Answer questions, earn points and help others
