My amp after 5 hours stopped working is there a cut switch
  • Garth Urie
    Garth Urie May 11, 2010
    Hiya more detail please, type make nodel, are the lights still on or off. thanks Ganx
  • 3 Answers
First check that you have the amp grounded on to the frame it has to be good metal to metal contact then go back and check your rca wires and the remote turn on and tour fuses and power wire
Posted on Jul 13, 2009
How do I test alternator on 23hp Briggs & Stratton vanguard mod. 386447
Please make sure you turn off light switch after cuttings or start up
Feb 02, 2015 | Tools & Hardware - Others
Wiring diagram
are the A/C fuses good? what transmission, auto or stick?
the first check is , does the compressor, cultch, engage
and spin the actual compressor main shaft at full speed.
yes, then loop is bad. (freon loop) (fan good)
No, then below is wrong. (electrical)
94/metro/swift
did you check pressures yet?
if not , then the hi/low limit switch may be open killing the compressor
so it dont self destruct, never bypass this limit switch.
the High low switch if open kills DC power to the A/C main relay. coil.
coil yellow wire must be at 12vdc or the loop has wrong pressures.!
dig,. it refuses to destroy its self. so kills the relay.
all posts, USA.
does the A/C lamp on dash turn on? if not the blower is dead.!
on the 94,(i dont have 93 drawings)
you can get better drawings for 94 at alldata.com, any time.
yellow wire is hot. (clutch dead)
the next point of failure is the car has throttle pedal switch
that is closed all time but wot, wide open throttle cuts AC.
so this switch can fail and cut A/c (USE A VOLTMETER) opens.
the clutch has its own relay, that is controlled by
the A/C amp module (better name A/C logic module)
it cuts A/C for many reasons.
we use a voltmeter at the AMP mod..
inputs that can stop A/C compressor, are:
1: engine overheat sensor bad. 0v , goes to 12v at 235F engine temp.
pin 9.
2: pin11, not 12v means dash lamp out
3: pin 5, transmission cut, or throttle pedal cut out (WOT).
4: pin 4 and 10 , evap core iced up cut, thermister sensor.
5: pin 8, lost 12vdc power.
The TCM cut out , to pin 5 is just for automatic trans, with TCM shifter electronics, it sends cut when the trans detects overload.
(hills? or tranny goes to limphome mode, {sick})
see amp below.
that is it, for electrics. answer my first questions for better answers.
Mar 31, 2014 | 1994 Geo Metro
Pto cuts off while mowing
check the safety switches start with the one on the seat then the one on the clutch/brake pedal then the reverse cut out switch bypass them one at a time with a paper clip to test them also look for a loss connection at all the same switches
May 23, 2012 | Garden
I have a Honeywell T8601D thomastat. It has been in service for 5 years and operated well. In the last month, it has gone "dark" (stopped working) 3 times. The first time it stopped working for a couple...
If you have a float switch on your drain line and the drain is backing up this will cut power to the tstat. Drain slowly drains, float switch resets, power comes back to tstat. That's my educated guess. But, is there batteries in the tstat?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 25, 2017 | Honeywell Electronic Programmable...
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
1993 C1500 CHEVY CHEYENNE
try unplugging the negative of the battery for 1 hour, then replug and try....
Jul 22, 2009 | 1989 Chevrolet C1500
Left headphone stops working
Probably a broken wire, try to isolate where it is at & then cut the wire, strip it back & re-connect & tape it up. To isolate where the break is hook up your headphones & pull, push & twist the wire all the way up to the ear piece till you find a spot where it cuts out or comes on & there is your broken wire.
Jun 20, 2009 | Logitech ClearChat Pro USB Headset
Won't start after running for some time
check the oil in it some of the new mowers have a low oil shut down switch on them so engine doesn't blow up the other thing you can try is sprying carb. clean in carburator try these & let me know , wade
Jun 06, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Channel cuts out
I suggest you switch your speakers and test again , if the same happens , ship it it can only be an output problem >>>>Good luck
Jan 30, 2007 | Classe CAV-500 5-Channel Amplifier
43 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
