Question about RCA DRC8052N DVD Recorder
I do not know how to record from the tv
Hi my name is ivrin
can you help me to record a program that has been saved on my tv recording list i would like to save the program on a dvd can this be done
  • 51 Answers
These machine is pretty much a waste of time tryin to program them with another appliance like youyr tv guide it all depends how you are hoocked up cable in the dvd recorder or do you go thru a dish box cable box its very hard to syncronise this machine if your are no directly in from conventional cable!
Posted on Jan 08, 2008
TV switch to live tive when wtaching recorded program
Hi there anil! My name is Kimberly and I form part of the Social Media Department with DISH, It is my pleasure to assist you. When watching an already recorded event and having a timer set up to record it should not interrupt your viewing of that DVR event. When this happened, did you get an error message on the screen? And has this happened again? Please reach me at: kimberly.escobar@dish.com with the details.
Kimberly. Escobar
Social Media Representative
DISH L.L.C
Dec 14, 2013 | DISH Network ViP 922
I have a Goldstar VCR and I want to record a tv program using it. How do I do it?
Most Goldstar VCRs only have an analog tuner. (TVs do not often have an option to output their video to another device.)
So first what is the source of the TV program? If it is an OTA analog or CATV cable. Set up the VCR normally by connecting the incoming signal cable to the VCR and then use the coax out to the TV. Scan for channels and set the VCR to record the desired program. (Either use the timed record or one touch record method.)
If your source is digital, you will need a set top box (either a digital to analog converter or cable box). To split an incoming OTA signal between your TV and the converter box, you can use a switch or a splitter. (A splitter will give lower signal strength to both the TV and the converter box.)
Depending on the box, you can either connect a coax cable from the box to the VCR and then to the TV or composite video from the box to the VCR. If you use coax, set the converter to channel 3 or channel 4 and record that channel. Otherwise set the VCR to record Line 1.
To record, put in a tape with sufficient space available with an intact safety tab. For One Touch Recording, set the VCR to the desired channel and tape speed. Then press Rec. Press several time for a timed recording. For Timed recording, press Menu > Program. Press Select and move through the list to program day to record, the start/stop time, and channel, etc. When done, press Menu to save the setting. The timer light should come on (most VCRs will turn off).
I hope this helps.
Aug 05, 2011 | Goldstar GBV241 DVD Player/VCR
How do you delete a program that is mistakenly added to the record every episode mode
The easiest way I know is to press menu, then daily schedule. Find the program in question in your list. Click on that program and you will se a window "timers", click on that and you will see "delete", click on that. then you can reset your program to record the way you want. You can also follow the same proceedure, click menu, then daily schedule, then click on "timers". Scroll to the timer you want to delete, click on it, then click on delete.
May 02, 2011 | DISH Network ViP622 DVR DTV Receiver /...
I have the Zenith XBV443. I'm trying to copy saved programs from my dvr on my tv to dvd discs. My neighbor has a simular model yet we can't find out why I'm unable to do the same. What do you think is the...
The Zenith player/recorder will be able to record to DVD from an external input such as a PVR. The most likely reasons you are unable to record successfully are:
1. The TV / DVR is not connected to the Zenith recorder correctly. You need a separate cable for recording. You cannot record using the cable that is connected for playback of DVD discs.
2. The TV / DVR does not have "VIDEO OUT" sockets
3. You have not selected the correct external input on the Zenith recorder
If you can let me know the brand and model number of your TV / DVR and how it is connected to the Zenith DVD recorder, I can let you know why it isn't working, how to make it work, and even draw you a setup diagram, if required. It's very difficult to give you the correct answer without these details.
You Zenith DVD recorder will record from the DVR - the real question is, can the DVR send video to the Zenith DVD recorder . . . ?
Regards,
BElectric
Feb 17, 2011 | GoVideo Go Video DVD/VCR Combo
Dual transmitter DVR has stopped recording on TV2. Programs are set to record, the guide shows that they are being recorded. They are listed in the to record list, but they are not in the list of...
Hi, my name is Cheri Torres and I am with DISH Network Customer Service. I have never heard of receiver only recording on one tuner but not on the other but I would like to see if we can find a solution for you. The first step to try in order to resolve your issue is make sure that you do not have any timers conflicting with each other. If you do have two different timers that are set to record at the same time it can cause the DVR to record one show and not the other. Another trouble shooting step to try is a hard reset by unplugging your receiver for ten seconds then plugging the cord back in. After you have allowed your DISH receiver to reset try your DVR recording functions again. If both of these options are not correcting the problem please feel free to email me at Cheri.Torres@Dishnetwork.com so that I can ask you a few more questions about your issue and get this resolved for you as soon as possible. Thanks and have a great day! :)
Feb 02, 2011 | DISH Network ViP722 DTV Receiver /...
Hi I have a 42 inch Toshiba TV and the problem is that I record stuff but I don't know the place! so please help me please
you could try and save a new record when it ask you to name the file you will see the default save location.Or serch a file name on your computer to locate its save location adress
Jun 03, 2010 | Toshiba Satellite A100-S8111TD Notebook
Have magnavox dvd recorder record direcTV DVR programs w/ hdtv
I am unfamiliar with this unit.
If you have scart connecters on both, connect av2 on the tv to av in on the recorder. set the recorder to record from av source.
You should now record a program, I think the static is the fact that composite is out from the dvd only, not an input, and in on the tv, not an output.
Sep 04, 2009 | Philips Magnavox MWR10D6 DVD Recorder
Pioneer dvd recorder dvr-530H
The EPG is the electronic program guide trying to download TV listings.
http://en.wikipedia.org/wiki/Electronic_program_guide
This is normal for this player. To disable this, you would need to turn off the TV guide function.
Sep 28, 2008 | Pioneer DVR-530H-S DVD Player/HDD Recorder
RCA DRC8052N DVD Recorder Logo
93 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
