Question about Kenwood KVT-817DVD DVD/CD/MP3/WMA 7" Motorized In-dash Monitor With 5.1ch DSP Car Video Player
Kenwood KVT-817DVD screen goes black, have to reset constantly
Kenwood KVT-817DVD installed professionally, shuts down on starting vehicle. Audible pop/crack in speakers then the system screen goes black. After holding the reset button, system works properly...this problem is persistent. Where should I start?
  • 909 Answers
You will find that there is a voltage surge upon starting, solution is quite simple, try to avoid starting the engine with the unit on, as you may blow more than a fuse.
Posted on Jul 12, 2009
    Genius:
  • 1,139 Answers
Hello johnnychi925,
The unit appears to have been installed on the 12vdc connection that is on the same circuit as the the vehicle's ignition switch. This means that when the ignition is turned there is a rapid drop in voltage which cause the problem with your device. You need to connect the device to a 12vdc circuit that comes straight from the battery and does not connect to the ignition circuit. Now for another possible cause if the 12vdc you are connected to is from the battery and not the ignition connection. The battery could be dropping below 12vdc during the starting of your vehicle. This could be the sign of a malfunctioning battery, or a problem with the car's electrical system.
To test out if the battery ids dropping below 12vdc I would suggest connecting a voltmeter to the - and + of the battery and starting the car. The voltage should drop but not below 12vdc.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
How do you set the clock
on tho screen you have settings, open it and then, clock adjustment.
Sep 27, 2012 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Tip
Kenwood Excelon Manual (KVT-817DVD)
Kenwood Excelon KVT-817DVD Users Manual
Misplaced your Kenwood Excelon KVT-817DVD manual?
Would you like a pdf format, digital, searchable KVT-817DVD users guide?
The Kenwood Excelon KVT-817DVD owners guide is available here.
I hope that helps.
on Apr 02, 2010 | Car Audio & Video
Tip
Kenwood KVT-817DVD Manual
Kenwood KVT-817DVD Users Manual
I hope that helps.
Does the 817 come with a brain?can i get the harness separate that has the speaker connections as well as the audio jacks
KVT-817dvd MANUAL LINK
Yes - there is a separate receiver unit.
CLICK HERE to see all the available parts to the unit.
Look at the installation part of the manual to determine which harnesses you will need.
Thanks!!
Feb 07, 2011 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Need reset code for kenwood kvt-715
i have attached a link with a HOW TO reset a kenwood radio code. i have never tried this on any of the KVT units, but its worth a shot.
http://www.tech-faq.com/reset-kenwood-security-code.shtml
Aug 25, 2009 | Kenwood KVT-715DVD Car DVD Player
Tip
Kenwood KVT-817 Manual
I hope that helps.
on Apr 02, 2010 | Kenwood KVT-815 - 7" DVD/MP3/WMA Rcvr Car...
Kenwood kvt817dvd powers up after reset but cuts out after src
I removed my brain from beneath my seat and exposed all wires and connections. I have found that on mine (kvt-815) there were two pinched wires- 1 for a speaker and the other the remote wire. I respliced these sections and tested my radio again. It appears to be working now and stays on again. I'm guessing one of the wires must have been touching something metal under the seat (seat frame) and grounding out. If the unit doesn't power on at all, check the fuse first. Otherwise, I would  inspect every wire like I did and maybe you'll find a pinched (grounded) wire. Maybe I just got lucky... but at least it's working again and I don't have to replace the brain! Hope this helps.
Jan 05, 2009 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Freeway indash DVD
u need to switch function screen to dvd screen. Button is on front of unit to scroll through screens.
Dec 14, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
CD/DVD only works in Dual Zone?!
CHECK YOUR CONNECTIONS FROM HEAD UNIT TO BRAIN THERE IS A SMALL GREEN PLUG MAKE SURE IS CONNECTED
May 13, 2008 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Passcode
You might have bought a stolen one. I was installing a sub in my car and unplugged mine and it required a pass code, which i forgot for a while, but luckily remembered. I called about getting it reset and they said I had to bring it in to a official Kenwood ceter in order to get it reset. I would just suggest to call Kenwood. Also, i'm currently looking for a new one because mine was stolen again, so hopefully the person who stole it is having a problem installing it in there car. good luck.
Nov 09, 2007 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Kenwood KVT-817DVD DVD/CD/MP3/WMA 7" Motorized In-dash Monitor With 5.1ch DSP Car Video Player Logo
286 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
