Question about Panasonic DMR-E85H DVD Recorder
The machine goes into a recurring "self check" / blank display when attempting to dub or copy from HDD to DVD
  • 158 Answers
TRY REPLACING STRG6353 IN PSU,IF THAT FAILS THE HARD DRIVE NEEDS REPLACING
Posted on Jul 27, 2009
I have a Magnavox H2160MW9 A. It has a dubbing feature and says I can copy from HDD to DVD. But when I follow the instructions "Selected Title Dubbing", The dubbing selection is grayed out. Note that I'm...
Choose Dub on remote. Choose HDD to DVD. When you are looking at your HDD Titles, move the cursor (the highlighted box, using the left/right buttons on your remote) to the title you want to Dub. Hit the OK button on your remote. Then hit the Dubbing button on your remote. If you are ready to record, move cursor down to Start Dubbing. Choose speed, then hit OK button.
Jun 19, 2010 | Magnavox H2160MW9 HDD Recorder
Problem dubbing from HDD to DVD+R (LG RH7823W)
Received no proposed solution, Is this the service I can expect from fixya,com?
Jun 16, 2009 | LG DBRH197H DVD Player/HDD Recorder
Will not dub to dvd-r from HDD in high speed mode
It will only high speed dub in the speed it was recorded in. You can dub, for example, SP on your hard drive to SP on a DVD. You cannot dub high speed, for example, SP on your hard drive to LP on a DVD.
Dec 01, 2008 | Panasonic DMR-EH50 DVD Recorder
HDD>DVD dubbing.....stopping, creating coasters
Still unable to find a solution for this problem. No response from JVC on their product either.
Jun 25, 2008 | JVC SR-DVM600
Cannot start dubbing
I'd guess you are using cable TV-some cable companies put their own copyguard on the cable signal, Comcast, in my area does this. The DVD sees the 'do not copy signal' and won't do it.
Try recording directly to DVD without using the HDD drive. If you get a playable disk, I doubt it is your machine. If you don't get a playable disk, that plays in THAT machine-it is the machine..
Jun 07, 2008 | Televison & Video
Faulty Panasonic DMR-E85H
My dvd DMR-E85H frequently displays self check, then goes blank
for long periods before eventually starting.
May 25, 2008 | Panasonic DMR-E85H DVD Recorder
Dubbing from HDD to DVD disc
I beleive you can only dub from hdd to disk,
Try formatting the disk first.
good luck
Norm
Apr 03, 2008 | LG RH177 DVD Recorder/HDD Recorder
HDD to DVD
make sure you set dubbing speed to sp ,short play,thats the default setting,then go to start up menu and finalize disk
Oct 11, 2007 | LG RH177 DVD Recorder/HDD Recorder
Copying from hdd to dvd
1. select the recording you want to copy.
2. press the SELECT button. You should see a yellow / red icon by the title.
3. press RECORD / DUB.
Oct 04, 2007 | Wharfedale DVD-M3 DVD Player
DVD problem
I've had the same problem. Are you using x8 DVD-R? I had no problems with the old x4 discs, but had the (long) Self Check process and a failed dubbing occur between 1/100 and 2/100 in the dubbing process with the x8 discs. I've found two workarounds: 1) The problem doesn't seem to occur if the recordings are made with hi-speed dubbing enabled. I do this now as a default, but the loss of the ws tag is a pain . If I still get a dubbing failure with hi-speed dubbing, a quick power down/power on of the unit seems to rectify the situation. 2) If you record a "leader" in hi-speed dub mode of a minute or two, and dub it onto a x8 DVD-R first, you can then copy non-hi-speed dub recordings onto the disc. Not quite sure why this works, but it does - it's like the first minute or two being dubbed over needs to be hi-speed enabled to be written from the memory of the E-85 to the disc, but once that's done it dubs as it should. btw, another process that crashes the unit is if you try an change the thumbnails on a x8 DVD-R. Not the end of the world but again annoying on expensive equipment less than two years' old. DVD-RAMs are not affected by the problem in my experience. Apparently there's some firmware in the US that addresses the problem with x8 discs - http://www2.panasonic.com/webapp/wcs/stores/servlet/vDownloads?storeId=15001&langId=-1&page=DVDFirmware , but Panasonic UK don't distribute it. I think the E-85 is a good box but it has proven too buggy and I'm thinking of upgrading it, possibly when the new 85 is released by Panasonic in a few weeks. Good luck
May 14, 2006 | Panasonic DMR-E85H DVD Recorder
Panasonic DMR-E85H DVD Recorder Logo
230 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
