How much cost for lan card - Computers & Internet
  • 74 Answers
Its about 20$ and more depends on brand
Posted on Jul 12, 2009
Having lan card problems what does it affect how much does it cost to replace and fix
C521 LAN card is integrated in MB.
You can Flash the BIOS to most current and load the latest driver (Support.dell.com) see if the card works, next I'd reset BIOS defaults, and try again. If NIC will still not work, it may be damaged. Turn it off in BIOS and replace with a PCI NIC
http://cgi.ebay.com/Xinruilian-Fan-92mm-Ball-Bearing-2pin-4pin-PSU-Power-/200552830688?pt=Computing_ComputerComponents_Fans_Heatsinks_SR&hash=item2eb1e156e0
Jan 14, 2011 | Dell Dimension C521 PC Desktop
LAN port of my laptop hp dv2000 is damaged. I understand from technicians that it is fused to motherboard and would be costly to replace. I am using USB to LAN converter plug. Is this the only...
Aside from having the LAN port repair user a USB to LAN is the device thing to do here to save money because he repair for this type of problem will cost more.
Using a USB to LAN converter will also work just like a regular LAN card on a computer so that will be fine if you think about the performance.
Oct 09, 2010 | Dell Latitude E5400 Notebook
Lan card send reciving problem solutions
The lan card send receive problem occurs only due to following reasons
1.The network cable connection not having good connectivity
2.Due to physical damage of lan card due to power and etc
3.Due to improper fixing of lan card in case where lan card is not inbuild
solutions
you can check which is the problem
if the lan card is damanged means replace with external card
Feb 13, 2010 | Computers & Internet
My dell lan card is not working,i cannot connect to internet.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
Nov 14, 2009 | Dell Ethernet Card Network Adapter
No internet connection due to ethernet cable problems
Means you have on bord LAN .
No worry you can add new LAN card easily in PCI slot on motherbord.
For that you need to pur chase new LAN card from store it is very low cost.
Then fix it in PCI slot of motherbord then install driver of it from disk which comes with lan card.That's it.
Aug 18, 2009 | Dell Ethernet Card Network Adapter
How a conect to internet
METHOD 1 - Using Internet connection using DSL or cable connection.
1st. If you wish to connect to the Internet with a LAN cable or a wirelessly and if your computer doesn't have a LAN card or wireless LAN card you need to purchase a LAN card (to configure the wireless router) and if you want a wireless connection you will also need to purchase a wireless LAN card.
2nd. You need to select an Internet Service Provider in your area with a plan and cost to suit your requirements.
3rd. You need to decide what type of broadband connection you need, DSL or cable modem with or without a built-in wireless router, the Internet Service Provider can assist you with this.
5th. The Internet Service Provider can supply these items or advise you what make and model to purchase. They will also provide information on how to connect and setup your Internet connection.
METHOD 2 - Using USB wireless adapter that plugs into the laptop's USB port. It doesn't need a wireless router or a cable or DSL modem.
This is used mostly on laptop computers which allows Internet access anywhere the Internet Service Provide has a wireless transmitter. It uses the G3 mobile system.
This type of service usually costs more and again you need to select an Internet Service Provider that can provide the wireless coverage, the plan and costs that suit your requirements.
Installation and setting up information is supplied by the ISP.
Jul 31, 2009 | Computers & Internet
Lan Card burnt
Not worth repairing
May 20, 2009 | Panasonic KX-FM181 Fax
Internet connection
plug the modem through the USB cable given to the usb port and install the required driver from the given CD..If usb cable or CD is not given approach the BSNL office and ask for it..Else u can buy a lan card whick cost abt 100 i think..
Sep 28, 2008 | Computers & Internet
I want lan card driver for fmv-6100mg2
buying a lan card is costly..........u can hav the same adv by buying a modem of bsnl which has lan and wifi for the same rate which is usb connected to the comp
Mar 29, 2008 | Fujitsu AMILO D-7820 Notebook
Wired LAN
A usb ethernet adapter does not cost much and no troubleshooting needed.
I assume your trying to get your built-in card to trigger have you checked the bios to be certain it is enabled.
and go to control panel check the system device manager to see what it says about the ethernet.
does it show up under my network places and if it does is it bridged. Get properties on it.
Jan 29, 2008 | Acer TravelMate C100 Notebook
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
