Question about Dell Computers & Internet
I need to replace a harddrive
Ihave a Dell PC with a 40GB harddrive that I would like to upgrade to a compatable 500GB harddrive that I already have. I have backed up my entire harddrive and I know the mechanical basics of installing the new harddrive. I have a Hitachi Deskstar 500GB replacement harddrive, My computer is an Optiplex SX 280. I need to know what else is involved.
  • Steve Caulfield Jul 12, 2009
    I have a Windows Vista OS install Cd that is made for new installs on Dell pcs. I was thinking of upgrading from Xp pro to Vista Home edition. Would that change what I do for the drivers?
    Excellent, knowledgable and faaaaaast!!
  • Dell Master
  • 13,433 Answers
Its very simple, open up the machine, unscrew and disconnect cables from the old one. Remove the old hard drive from the case. Place the new on in, screw it in, attach cables. Close the cover of the computer. And the upgrade is done.
You will now need to use the dell discs that came with the system to restore it or a windows installation cd to install windows into the computer, when the windows is working again you need to download the drivers, unless you used a dell recovery cd which already contained and installed them.
Then restore your files from the back up and install all programs into the computer again that you want to use.
Or where you thinking about cloneing the old hard drive so you wouldn't need to restore the machine or install windows into it again? That gets somewhat more complex, here is a software to do that: http://www.runtime.org/driveimage-xml.htm
you would need to create a image of the old hard drive and then restore the image into the new hard drive.
Posted on Jul 12, 2009
  • Ekse Jul 12, 2009
    if the cd doesn't contain the drivers then you need to download them from dell website after the windows setup is complete to get all the functions of the computer to work.
I have a dell dimension 4500, I need a compatible internal hard drive for it. Which one to buy?
Check the manufacturer's web-site:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=2684&l=en&s=pub&os=WW1&osl=en&SystemID=DIM_PNT_P4_4500&catid=-1&impid=-1
for your (7-year-old) model, and you'll find a list of PATA (Parallel-ATA) disk-drives recommended by Dell, up to 120GB. Any PATA disk-drive that you can buy, up to 500GB, should also work.
Aug 09, 2010 | Dell Dimension 4500 PC Desktop
Is a 320gb HD compatible with the Inspiron Dell laptop?
Hi, I think its compatible with Dell Inspiron as long as the 320GB uses the same cable like IDE or SATA with that dell inspiron, and I think if ever your machine right now uses on the IDE cable it can still handel a 320GB capacity because an IDE cable can accomodate up to 500GB size Harddrive. Also I would suggest that if this would work on your machine try partioning your 320GB to one 60GB for your operating system and the other space is for your data storage. Hope this helps
Jun 03, 2010 | Dell Inspiron 6000 Notebook
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
Whats the biggest ram I can put in my HP G7000 note book to replace ST9120822AS which is currently in my machine.
Currently the largest drives for notebooks are are
Hitachi Travelstar 5K500 500GB
Seagate ST9500420AS Momentus 7200.4 500GB
Seagate ST9500420ASG Momentus 7200.4 500GB
Seagate ST9500325AS Momentus 5400.6 500GB
Samsung Spinpoint M7 500GB
Samsung SpinPoint M6 500GB
Nov 13, 2009 | Seagate Momentus 5400.3 ST9120822AS 120 GB...
I need to replace the dead hard drive in my dell dimension 4500s. Current dead drive is a 40GB Ultra ATA-100 (7200 RPM). Can someone tell me what I can upgrade to. I think I have the flat data cable so it...
You can replace the hard drive with a larger capacity hard drive. Best bet would be a 250GB .
Hard drive have come down in prices, you should be able to get a 250 GB. for less then $100.
Western Digital ansd Seagate are my preference.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
May 16, 2009 | Dell Dimension 4500 PC Desktop
Have maxtor 40gb hd want to add 2nd WD hd in DEll dim8200
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Regards..
Apr 04, 2009 | Dell Dimension PC Desktop
Having problems upgrading my laptop hard drive !!!
From what I gather basically you want to copy everything off of your 40GB and put it on the new 320GB and the install correct? Why don't you do a backup (Start>All programs>System Tools>Backup to the external 500GB drive. Install the new 320GB drive and then load the operating system from your operating system disc, then restore the data from the 500GB you backed up, or am I missing something.I know it is not as convenient as cloning but sounds like you may need to do it the old fashion way..there is no good reason that the cloning software would quit reading your disc unless it's some kind of "only get one chance and throw away software".
Dec 27, 2008 | Dell Inspiron E1505 Notebook
My hard drives that i put in my computer is a 80gb harddrive but wen windows is loaded up it says its a 40gb
Either your hard drive is defective, formatted wrong, or improperly partitioned. Most likely it will need to be reformated, and I recommend the default partition size unless it is signifigantly (more than 10%) less than your actual drive size. 500GB drives are available for less than $100, and much more viable than the smaller drives.
Dec 16, 2008 | Computers & Internet
Hard disk and ram
Hello Kevin Shaggy...
Let me see if I can help you out a bit...
Adding a 160gb to a 40gb does give you 200gb. BUT!!! you will loose a little bit on each one after formatting the harddrive. The new drive will wind up being about 157 or 159gb give or take a little.
ANY harddrive partition, whether it is a c:, d:, etc...you DO have to format EACH drive letter.
If you partition your 160gb harddrive into 2 parts, (2) 80gb drives, then they would get two drive letters and both of them get formatted.
IF the 40gb drive is C: then the new 160gb partitioned in half would be D: & E:.
CDROM Drive would be F: and so on....
Floppy Drives, CDrom Drives, DVD Drives, you do not have to format like a hard drive...
If you add a 1gb stick of memory to your existing 256mb stick of memory then you WOULD have 1gb + 256mb. If you remove the 256mb and just add 1gb, then you would just have 1gb.
Nov 24, 2008 | Samsung Computers & Internet
Computers & Internet Logo
35 people viewed this question
Clive
Clive
Alun Cox
