Question about Ovens
How do I fix my oven door keeps locking up and F1 comes up and starts beeping
    Guru:
  • 310 Answers
Here is a detailed description of this error code. Your control can be rebuilt by fixyourboard.com. See article here on Kenmore/GE F1 Error Code: Oven Failure After Self Clean and F1 Errors
Posted on Sep 01, 2015
  • 3422 Answers
SOURCE: Jenn Air double oven keeps beeping
HI,
The problem is with the faulty relay board or wire harness harness.
There are no home remedies for this problem.The only solution is to get it repaired.
Posted on Sep 17, 2008
  • 833 Answers
SOURCE: Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Posted on Nov 28, 2008
praky16
  • 744 Answers
SOURCE: F1 is displayed on Maytag Electric Oven
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad...
thank u
rate me!!!
Posted on Aug 14, 2009
tbirdfan1
  • 3051 Answers
SOURCE: f1 beeping
hello there:
Please read this carefully and follow the tips and this will help you find out what is exactly the problem ok
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part. * We have seen a few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Posted on Jan 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: Keep getting F1 error code (constant beep) on my GE profile oven.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%#$TEF
Posted on Oct 01, 2010
Stopped f1 flashing and beeping by adjusting the lock feature to 12 o clock not oven and self cleaning not working at all
You have disabled the oven feature if you did adjust the door lock assembly. Interesting that the F1 stopped. notsure why myself.\
Usually the F1 feature does not go away unless you replace the electronic/control board.
I wonder what would happen if you set the door lock assembly to where it was before?
Oct 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
F1 is displayed on Maytag Electric Oven I ran the self-clean cycle on my Maytag Model MER5530 oven yesterday; before it completed F3 was displayed and beeps sounded. I pressed CANCEL, the F3...
Hi
thank u
rate me!!!
Aug 14, 2009 | Maytag Ovens
Kenmore locked
The www.managemyhome.com website has some troubleshooting options when the door wont unlock. Good luck. Also you can download the whole manual online it you have your model number. Mine was inside the drawer under the oven.
Apr 12, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore, F1
I really need to know the make and model but most F1 are a bad control board.. F1 Analog to Digital Failure Disconnect from power for 30 seconds - if display reappears - replace control board
Aug 27, 2007 | Ovens
Ovens Logo
307 people viewed this question
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
