Question about Zebra 170XiIIIPlus Thermal Label Printer
Print too light
I have adjusted the pressure and Darkness to no avail. Printing acceptable on the left but nearly missing on the right.
The printer hadn't been used for several months.
Thanks, Steve
  • 53 Answers
The printhead alignment sounds to be out or the hopefully just dirty. on this printer the printhead is not autoaligning like on the smaller printer and you need to tune the tilt,rotation,position, and so on. not just the print pressure. there are about 4 sets of hex screws around the head mech that are used to adjusted the alignment.
good luck
Posted on Nov 21, 2007
1. If you are printing using postscript driver, try using PCL6 - printout would be darker for grey scaled items.
2. Print in lower resolution 600dpi or 300dpi, printouts would be darker.
3. Try printing all characters as black
You can adjust darkness at the printer using the console menu.
In the Configuration Menu ' Print Quality sub Menu , there is a parameter called Tonor Density. Factory Default is 3. Set to 4 or 5 to increase darkness..
Sep 27, 2013 | Office Equipment & Supplies
Workcentre 275....customer supplied multi page pdf's all of which contain a signature. When printed from the 275 a lot of background noise appears in and around signature, prints fine to various other...
Hi Paul.
I don't have a Xerox, but my previous HP and Samsung and current Samsung have on-screen Windows-configurable settings for adjusting darkness etc.
Open Start>Control Panel>Printers and Devices
Right-click the XEROX icon and choose Settings.
Browse through the menu pages until you see a page with similar to the screenshot.
May be called Advanced.
Darkness should be normal, or if still showing, try light.
ECO mode should be On.
That fact that other printers are not printing the noise means that the current user-settings of your XEROX are too dark, thus reproducing the pixels of the signature graphic.
If you selected a pixel near the signature and analysed it in MS Paint, you'd probably find that the 24-bit RGB value is not pure white 255.255.255 but maybe a few steps darker, say 254,254,254.
To the human eye this would be hardly noticeable, but the printer may be darkening the pixels even more, causing the noise.
I wish you luck in your noiseless quest.
Nov 18, 2017 | Xerox Office Equipment & Supplies
Hello, I changed the ribbon. The ribbon and labels
can you adjust the printhead pressure?? if so then do that
Aug 22, 2017 | Zebra ZM400 Thermal Label Printer -...
HI, our Zebra 4m+ is currently set to a Darkness of 30 as that seems to eb th eonly way it will print enough detail on the label. We have tried adjusting the pressure settings to no avail. Now we are...
Full resin ribbons tend to require higher darkness settins on all thermal printers.
It could be a mismatch between label and ribbon. This would need to be looked by your supplier.
May 25, 2011 | Zebra 105SL Thermal Label Printer
The Thermal transfer labels are not readable when I print to the Intermec easy coder PM4I. They print too light. I can use the same ribbon and label stock on an Intermec 3400 printer and they print...
You can adjust the darkness level +/- 10. If you adjust it all the way to 10 and it is still too light, there is a print head pressure adjustment screw to the left of the ribbon feed roller.
Aug 19, 2010 | Intermec EasyCoder PM4i Printer
Labels are "faded" looking when printed. looks like you need to change ink but obviously there is no ink
Is this unit in thermal transfer or thermal direct mode? Depending upon the usage of this machine, perhaps a new thermal head is required. If thermal direct, try a different roll of labels, it is possible to get a bad batch. In thermal transfer mode, the tape could be bad as well. Try a new one to test.
Let us know what you find.
May 12, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Changed the ribbon, but the labels are to light.
The DARKNESS setting controls the amount of ink released to the label. The 105 has a range of 1-30, 1 is the lightest - 30 is the darkest. The setting used will depend on the combination of label / ribbon used. There is no "correct" number, always try to use the lowest setting with acceptable print quality.
The DARKNESS can be adjusted from the front panel by pressing SETUP and changing or DARKNESS can be controlled from the software or printer driver. The printer driver or software usually overrides the setting in the printer.
Hope that helps !
May 07, 2010 | Zebra 105SL Thermal Label Printer
My 3'' by 1'' label now prints in the middle to the right and cuts of info.
So the left side is blank ? Usually caused by an imbalance across the printhead. Check the toggle pressure on the left side. Each toggle has a dial on top for adjusting the down pressure. Probably less pressure on the left than the right. Quick test would be to use your finger to put some down pressure on the left side of the printhead while printing. If the print is there, you have your answer. If still no printing, then something else is happening.
Hope that helps !
Apr 28, 2010 | Zebra S4M Thermal Label Printer
Zebra Z4MPlus not printing dark enough
In your label software there should be a setting option for print darkness (I assume it adjusts the head temperature) In ours (bartender) you can get to it when you select 'print' and a window appears with a 'documents properties' button. Click on this and select options and a darkness bar appears which you can adjust. You may also need to slow the label print speed if the darkness adjustment is not enough. I suspect it isn't in the printers best interest to run the print head at maximum darkness/heat so a sensible balance of darkness and print speed is best.
Another, less likely, possibility is an incompatability between the label material or surface finish, and the ribbon type. We did have a problem once whem Homebase changed their price label design and we had to test a load of other ribbon types until we got one that did the job. A chat with the label or ribbon supplier is always usefull, they sent us several sample bits to test.
Sep 30, 2009 | Zebra Z4Mplus Label Printer
Zebra S600 Thermal Ribbon Ripping after printing
Hi chunnon,
What darkness setting are you using? If the darkness is at or near 30, you may be burning through the ribbon.
Try defaulting the printer and running a Pause test. Does the ribbon tear during the Pause test?
Sep 23, 2008 | Zebra Stripe S600 Thermal Label Printer
Zebra 170XiIIIPlus Thermal Label Printer Logo
103 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
