Why does my honda 420 FI light flash 9 times
Check your bike with it parked on the side stand. Count how many times the F1 light flashes. There are two types of flash that it gives off... a long one and a short one! A long flash = 10 short flashes.
So you may get 2 x long flashes and 5 x short flashes = 25 flashes in total.
The codes for Honda ST1300 are as follows. I know yours is a different model but I would have thought they would all be the same across the Honda range.
0 - bank angle sensor, ECM, PGM-FI fuse
1 - MAP sensor
2 - MAP sensor vacuum hoses, or sensor itself
7 - ECT sensor poorly connected or open circuit
8 - TP sensor, TP senspr wiring
9 - IAT sensor connection, or open wire
10 - Baro sensor, or connection, or wiring
11 - Vehicle speed sensor, or connection or wiring
12 - #1 injector connection, or faulty injector
13 - #2 injectior connection or faulty injector
14 - #1 connection or open/shorted circuit
15 - #2 connection or open/shorted circuit
18 - Cam pulse sensor, connection or loose sensor
19 - Ignition pulse sensor, connection or loose sensor
20 - faulty E-PROM in ECM.
