Question about Kitchen Ranges
Kenmore gas range--oven won't come on
After self cleaning, the oven will no longer come on. When you turn the oven control on, the self clean light flashes, but the oven won't come on. I have tried to self clean again...which it WILL do, but after the cycle is finished, the lights on the contol panel flash instead of going off. The burners work, but I know that they run independently of the oven. I cannot locate a cancel or reset button & I've tried unplugging the unit to let the control panel cool off, but nothing has worked.
  • 2 more comments
  • nbwindchime Nov 15, 2007
    The model number is 362.72321002. Thanks.
  • nbwindchime Nov 18, 2007
    Having been in the appliance business for over 10 years, I actually was pretty sure of the problem before I started. It was not the ignitor, unfortunately, because I could have fixed that. I actually seemed to have taken out part of the board, thus forcing us to replace the oven. Thanks.
  • tracyburrel Dec 17, 2007
    I have A Spectra Electric Oven and after the clean cycle the oven will no longer work.When I turn on the oven the lights on the control panel only flash but it does not heat up.I have tried cleaning it again(which it will do) and unplugging it nothing works.
  • Anonymous May 30, 2008
    Bought a Kenmore gas range in 2006. 13 mo. later had same problem,
    replaced the part for $226. Used the self cleaning oven 3 weeks ago and
    the same problem occured. Now they want $368 to fix it, plus the $75 I
    spent for the last service call. Can't find anyone at Sears to help with
    this defective range.
My oven will not work. After pressing the desired temp on the oven, the preheat light and oven light comes on. After about 15 minutes, the oven is slightly warm and maybe an hour later the oven may or may not heat to desired temp. Kenmore gas range model #790.72851301.
Posted on Jun 16, 2009
  • 473 Answers
Give me the complete model # from the sticker on the oven and I can tell what you need to fix it.
Posted on Nov 15, 2007
  • Craig Shelton
    Craig Shelton Nov 16, 2007
    During the self clean it may have burnt out the ignitor. Need to check power to ignitor when in bake. Should have 120 volts. If power is there and ignitor is not coming on then it is bad. Could also check resistance of ignitor with an ohm meter. Also, could have burnt out the oven temp. sensor. You can check the resistance on the sensor from the board. Now, if the ignitor is coming on and oven is not lighting, the ignitor could have become too weak. In this case you would need to replace the ignitor. Let me know what you find.
Cannot do anything but self=clean
The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. More than likely your thermostat or oven control has been damaged and needs to be replaced. I would replace the temperature sensor as well
Apr 26, 2012 | Kenmore Kitchen Ranges
Oven lite won't go off and when turn on self cleaning it says door
The door switch has gone bad. This will keep the oven light on and the self clean won't work because it thinks the door is open.
Dec 12, 2011 | KitchenAid KESC307 Electric Kitchen Range
The oven does not work. The self clean does not too
kenmore self cleaning range c970-595084 everything works except the oven will not heat up,on self clean door locks but thats all, top elements work, lights work, digital display works, but no power going to oven elements when i used a tester to check voltage. Can anyone tell me what to do? Is there a fuse for the oven only?
TY Fr; Clyde
Mar 15, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
After self- cleaning my Kenmore Gas Range, I have not been able to get the 'Cooktop Lock' light turned off! So while I can use my oven for baking I can't turn the gas on the top of my stove! I have...
This may be a silly question but, did you just try turning off the circuit breaker for a couple minutes to see if it resets itself when you flip it back on?
Nov 21, 2010 | Kenmore Kitchen Ranges
How do you turn off the self cleaning feature on kenmore gas stove 790.75660?
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Sep 06, 2010 | Kenmore 75022 / 75024 / 75029 Gas Kitchen...
Kenmore Gas Range
Hey Alan- 'Self clean' sells. Techs call this function 'self- destruct'. Depending on age and number of previous 'clean' cycles, the control may have developed errors, or lockout switches may not function. If inside is thoroughly scraped, and bottom pan checked, removed, and cleaned if necessary, oven should work fine. Preventitive drip pans and a lot of aluminum foil keep the 'Self Clean' Gremlins away. Hope this helps- Thanks- ED
Feb 25, 2010 | Kenmore 73053 Gas Kitchen Range
My range is actually the RGB746 self cleaning gas
oven don't stay on and it takes a long time to heat up
Nov 21, 2009 | Hotpoint RGB745 Gas Kitchen Range
Kenmore gas range will not stop beeping showing F9 in window
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%^
Apr 03, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kitchen Ranges Logo
2,109 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
