Question about Desa International White Wireless Plug In Door Chime
Lighted doorbell works ok.Yesterday the bell still works but light don't.
    President:
  • 3,197 Answers
The light receives its power from the same place as the door bell. It is burned out.
Posted on Jul 13, 2009
The wireless doorbell does not work in our house.
Remove the door bell button and verify that it works not mounted on door frame. If that is the case then you are getting interference from the structure....not necessarily from the door itself but it won't help. The door bell runs on RF and at that distance it will most likely be from electrical interference (too close to an outlet or light switch.)
Feb 16, 2015 | Home Security
My 202 doorbell does not "react" if the button is pushed AFTER my neighbor unlocks his car by using his remote key. Can I change the frequency range of the doorbell?
look for a cover that has small switches under it. You can change frequencies there. You must match the door button the same way .
Nov 19, 2014 | Office Equipment & Supplies
Just a thought if the bell is wireless your diagnosis may just be coincidental, but look to at swapping out the battery. can you press the bell, say 5 times one after the other ok? Batteries sometimes recharge slightly between presses, maybe just pressing it twice once after each other doesn't work.
Nov 19, 2014 | Cars & Trucks
Have had major snow storms in the past few weeks. Installed, prior to storms, new door chimes that worked. Since the storms, neither the front nor side bells function. The bell button has a light on...
Most times, doorbell problems are button, especially since indicator light shows you have power.
Take off front doorbell button and see two wires.
These wires are low voltage and safe to touch.
Use screwdriver and touch both screws together, or remove wires from button and then touch two wires together.
If doorbell rings, then replace button.
If bell still doesn't work then scratch two wires together and look for static-type spark that says wires have power.
If wires have power, and you crossed both wires and bell didn't work, then new door chime is suspect.
If wires do not have power, then transformer is suspect.
Open following link to see example transformer:
http://waterheatertimer.org/images/attic-transformer10.jpg
Transformers are located in basement or attic.
Scratch a wire across both screws on transformer and look for static-like spark.
If no power, then check circuit breaker.
Home centers sell transformers in the doorbell section. They are 12 and 24 volt. Check markings on old transformer.
If transformer has power, then new door chime is suspect.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 12, 2011 | Garden
I WANT CKT DIAGRAM OF SIMPLE CALLING BELL
http://en.wikivisual.com/index.php/Doorbell
Here is circuit diagram for 24 volt AC call bell system.
Made with off-the-shelf parts from hardware store.
Connect transformer to box with 120Volts
Box with 120Volt ac can be any wall box with receptacle.
Home doorbell system have this kind of box-and-transformer located in attic or basement or utility room ... you can tap into same transformer and use it for both doorbell and call bell.
12V AC and 24V AV transformers are sold in doorbell department of hardware store.
Buy doorbell button in same department.
Buy bell to match voltage of transformer (for example, 24Volt DC bell will not work with AC transformer)
Thermostat wire is sold in electric department of hardware store.
Add a comment if you need more help.
Nov 26, 2010 | Cycling
How do i fix my doorbell
99% of the time, you need a new doorbell button
Also check if any circuit breakers are tripped
Check GFI breakers in baths and kitchen
Real-estate lady answer: buy a new doorbell button and connect 2 wires on back of new button.
Doorbells are low voltage and not dangerous.
If screws are loose in the holes, break off toothpicks in hole so screws have something to bite.
You need small screwdriver:
Repairman answer
Doorbell problems have 3 parts
1) The button
2) The chime or bell located in house
3) The 12V or 24V transformer located in attic or basement
4) rarely the wiring because it's low voltage and does not get hot
1) start at the button.
Remove button from wall
There are two LOW-voltage wires on back of button
Remove 1 wire and touch other wire, copper to copper
Does doorbell ring? Do you see a spark?
If bell rings, then button is bad
2) Chime or bell doesn't ring when button wires are crossed
Take cover off chime
The button works, so have helper push button while you're looking at chime
Can you hear any noise? Have helper push button on-and-off
Chimes have 2 or 3 wires >>> 2 wires if only front door has button, 3 wires if back door also has button
Take one wire loose and scratch it across each of the other wires
Remember front button is held down (or front button wires are twisted together)
Can you see a spark when wires are scratched together?
Try this with more than one wire ... but don't mix up location of each wire
If you are getting a spark, then chime is getting power, but it's not working
Replace chime
3) Transformer in attic or basement looks similar to this:
Use a wire and scratch across both screws to see if you get a spark
If you get a spark ... and the crossed wires dont ring the chime... and there is no spark at chime, then there is a bad wire
If no spark at transformer, then check circuit breaker
At last resort, but new transformer at Home depot in the doorbell section near light department
Oct 05, 2010 | Garden
Doorbell doesn't complete cycle
What exactly is the cycle? If its a standard doorbell, thats right when you push in it makes contact copleting the circuit. Hence you Get a traditional Ding dong for front door and a ding for a second or rear door. if you release early it breaks the path of low voltage current and does not dong.
With that said is your door bell a custom doorbell, that could change things
Dec 01, 2008 | Cooper Industries 3WAY WHITE COPAL SWITCH
Desa International White Wireless Plug In Door Chime Logo
320 people viewed this question
Top Desa International Home Security Experts
Marvin
Marvin
Lawrence Oravetz
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
