Question about Black & Decker Black Decker 16" Hedge Trimmer
Have opened to rewire but cant connect trigger back together
Have cut through wire and opened to rewire it but cant get the trigger mechanism back together. Black and decker hedgetrimmer. model no gt90 type 1.
SOURCE: how do i assemble a black and decker powershot
I borrowed my sister in law's PowerShot to put new upholstery on some chairs and after TWO successful staples, it quit working. Any ideas? The spring seems to be in there, but when I press down, there is no resistance. Help?
Joy
Posted on Mar 29, 2008
trippssmengi
  • 76 Answers
SOURCE: placement of switch mechanism
Go to www.toolpartsdirect.com and in the search box select brand and enter your model number and you should be able to find a break-down of your machine which will give you an idea as to how it goes together.I tried the GT249/H1 and GT249 as the model number and it didn't come up so you will have to look for a tag with the model and serial number on it for the correct number.
Posted on Mar 02, 2009
  • 4 Answers
SOURCE: got a Black & Decker GL301 strimmer but have lost instruction manual. dont know how to fit new cutting wire
Go to Homebase, B&Q, Ebay or your local hardware shop and buy a new spool, ALM part number BD032.
Posted on Jun 01, 2009
  • 52 Answers
SOURCE: black and decker steamer hs900 type 1
Hi marylou, below is a link to the user manual for this steamer. Just click on the link or copy and paste to the address window of your browser. You need Adobe Reader installed on your computer in order to open this .pdf file (free at www.adobe.com). If this helps, please rate this answer. Thanks! Hal
http://useandcaremanuals.com/pdf/HS90038.pdf
If that link doesn't work, try the one below and click on "Get This Manual"
http://kitchen.manualsonline.com/manuals/mfg/black_decker/hs900_1.html?s=fpw
Posted on Jun 21, 2009
woobie dog
  • 1273 Answers
SOURCE: Black and Decker Cordless Drill Chuck stuck in full open position
I'd put penetrating oil in it and tap the chuck with a plastic hammer. That should free it up.
Best rgrds, W/D
Posted on Aug 18, 2009
Rewireing radio wires cut when I bought it
all depends how short they were cut if there is a little length you can join wires together with connectors
Apr 12, 2016 | Cars & Trucks
Wires has been cut under dash of a 1997 ford escort need help rewiring so car will run
HOW CAN THE WIRE BEEN CUT,
DO YOU HAVE TILT WHEEL, REMOVE STEERING COVER OD THE IGNITION STEERING AREA, LOOK AT THE WIRES, DO THEY LOOK LIKE SOME ONE CUT THEM OR THEY CHANGE COLORS DO TO A ALARM SYSTEM, IF THEY CHANGE COLOR, COULD BE THE AFTER MARKET ALARM RELAY THAT WONT ALLOWED YOU TO START, IF YOU DO NOT KNOW WERE IT IS, IS OK, OPEN THE CONNECTION AND REMOVE THE WIRE COMING FROM ALARM TO IGNITION SWITCH WIRE, FIND THE OTHER END OF THE IGNITION WIRE THAT WAS CUT OUT , SEPARATE FROM THE OTHER WIRE ALSO FROM THE ALARM, AND RECONNECT BOTH IDENTICAL COLOR WIRE TOGETHER AND IT WELL START, UNLESS YOU HAVE A SECURITY LIGHT ON THE DASH, CHECK THIS OUT FIRST., PROGRAMING MAY BE NEED IT OR OTHER PROBLEMS ARE THERE.
May 24, 2014 | Cars & Trucks
Ge true temp start button not working, how to fix
There is a short in the wiring. Now you can repair this yourself or get a proffessional. I removed my back paneling an rewired mine by cutting each wire and twisting the same wire back to it.then I used some electrical tape to cover the open wires. Warning,you must have the dryer unplugged and you must connect the same wires together. If not you can cause an electrical fire.
May 06, 2014 | GE DPSE810EGWT Electric Dryer
How to put a rotozip rz10 back together
Hardest part is getting the trigger mechanism back in the right position while putting the screws in place. Everything has a slot/groove it fits into before both outside covers can be put together. One side will be easier to hold the pieces while the other simply covers them. A spot of glue (elmers) may help to hold trigger in place and the wires.
Apr 22, 2013 | Bosch RotoZip Spiral Saw RZ10 - 2100
Going back to stock wiring after someone had HID's and LED's and has cut factory harness at front realays on a 2002 R1
You gotta love when someone makes "improvements"! Your most reliable way to restore it to factory configuration would be to replace the harness that was cut. If it isn't feasable, you will need to splice the wires back together using **** connectors and lengthen any that may have been cut short. You will also need new headlamp/tail lamp sockets to accept bulbs and rewire them to the relays and switches. It will be a time consuming task. Good luck and safe riding.
Jun 28, 2011 | Yamaha YZF-R1 Motorcycles
The usb cable has been cut. is it possible to rewire myself?
Yes, just strip the wires on both ends, joint the wires with the same colors together and solder them together. Don't forget to insulate each of the wires so they do not short out against each other.
Oct 10, 2010 | Logitech QuickCam DeLuxe Web Cam for...
When starting the car...trunk opens..when turning off ignition alarm arms and goes off if you don't have the door open...after driving for a time car stalls
has the dash been pulled apart? any reason why there would be wires crossed? i have heard of someone having their trunk pop when starting their car, but they put the dash from an mk4 in their mk3, and crossed a couple wires. as far as the stalling, it is most likely because your alarm is going off. your best bet, is to take it to a mechanic, unless you are good with wiring, and either have them rewire the alarm, because somewhere there is a loose connection, and it's tripping itself, or have them snip the alarm all together.
Jul 28, 2009 | 1996 Volkswagen Jetta
Wiring
You may be able to take the back of the speaker can off the speaker plate on that side to rewire the headphones. You have to carefully remove the earpad and look for screws holding them together. Make note of which color wire connects to what at the solder connection. Cut your cord shorter and cut back the insulation. Test for continuity from the plug to the newly exposed wires with a volt ohm meter. You should be able to get the old piece of cord out of the grommet in the headphones to insert the working cord. Hope this helps.
Jul 04, 2009 | Bose on-ear TriPort Headphones
Computer turns on whean i put the wires on and cuts right out 2 s
this usually happens if the connections are not firmly made.. also a small **** to your cpu might be the reason. try reconnecting all the wires and then if you know how to do this try else dont.. open your cabinet and dust the cabinet's inside and put the ram back.. it shud work now.. else some loose contact exists somewhere in your connections..
Mar 20, 2009 | Systemax AOL Optimized PC (100607) PC...
POULAN TRIGGER PROBLEM
Remove the air cleaner which usually exposes the carburetor--operate the throttle (engine off) and watch what moves--likely wood chips blocking the action--less likely, a wire linkage got bent somehow, or there is sawdust in the trigger mechanism. From your description, this saw starts full-throttle at the get-go. Sort of dangerous!
Jan 19, 2009 | Garden
Black & Decker Black Decker 16" Hedge Trimmer Logo
288 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
