Question about Psi Blue Max 2200 High Pressure Gas Power Washer
Water will not come out of hose on pressure washer
  • firehead May 11, 2010
    Do you mean it is not coming out of the nozzle or when you disconnect the gun and wand it doesn't come out?
Water hose won't come off pressure washer
release pressure by squeezing trigger then grab the brass quick connect fitting at the knurled section (at end of hose) and push it toward the pump. when properly pushed back, the hose connector will pop out.
Aug 11, 2014 | Craftsman 2700 PSI Briggs Stratton...
I can't get the pressure washer to start up. The water is coming out of the hose, but there is no water pressure
If the washer is the kind that shuts off completely when the pistol grip is released, the problem is likely the little pressure sensor located near the output fitting (the threaded part to which the hose connects). The sensor is a little plunger held down against an opening in the side of the pipe by a spring when there is low or no pressure in the output pipe, as when the trigger is pulled and the pressurized water in the hose is released by pulling the trigger. That completes the electrical circuit and the washer is on and continues pumping water. When the trigger is released, water in the hose and output pipe jams up super high pressure, forcing tjhe little plunger out against the spring, and the electrical circuit is broken. If you take the case apart, you will see wires coming from that area. The fix (if this is the problem) is to free up the little plunger.
Dec 05, 2012 | Coleman Powermate DuraBuilt 1400 PSI...
Washer flashes f 1 on the display window
The F1 error means that water pressure into the washer is out of range...the control on the washer learns the water pressure coming in from when it was brand new it is capable of learning just the water pressure to your house since it will vary from your neighbors...after it has learned what the normal pressure is if it doesnt see that normal pressure coming into the washer it will throw up the F1 error code
What to check is if water is coming into the washer from the rubber fill hoses with as much pressure as always did...things that could cause lesser pressure is; kinked/crushed fill hose,sediment built up in the filter screens inside of the water inlet valve( can be checked by turning off water and removing hoses and pop screen out from the back of washer where the hoses connect to)
If the filter screens are clear and water seems to coming from the hoses with good pressure...the washer control board would need to be replaced
GENE
Sep 06, 2011 | Kenmore Oasis HE 27082 Top Load Washer
WTW6600SW1 whirlpool cabrio washer keeps giving an F1 error, why??
GENE
Sep 06, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a honda 2600 pressure washer. After running fine for a couple of seconds the water will stop flowing out the tip. It is receiving water,but will not flow it to the pressure hose. I even disconnected...
This happens when air gets inside the hose. An air bubble of sorts is in the hose and will not build pressure until you blow the air out of the line. Start the pressure washer, turn on the water. pull the trigger on the gun. It will spitter and spatter and come to a trickle. release the trigger on the wand. Pull the trigger again and it will eventually work it self out.
Jun 13, 2011 | Honda Black Max 2600 PSI Pressure Washer
Why does my washer start with a forcful stream and then cut doyn to minimum flow ?
Check for kinked or clogged water supply hoses(s). Be sure to make sure that if there is a screen-like filter in the supply hoses or at the inlet on the wash machine, that it is clear.
Shut the water supply off. Start the washer to fill on warm wash / rinse to relieve the water pressure in the hose. Shut off the washer. Unscrew the hose connection from the washer and direct both hoses into the washer tub (or other container). Turn the water supply on. Both hoses should discharge water evenly and forcefully, then shut the water off. If the flow was uneven, slow or poor - clear obstructions in / or replace the hose(s). Next, inspect the water inlet on the washer. Clear any obstructions, dirt, etc. Reconnect the hoses and try again. If flow is still lacking, there may be obstructions in water lines or valves INSIDE the machine.
I hope this helps - please rate my reply. Thanks.
May 06, 2011 | Craftsman Garden
Engine runs , not getting any water flow when trigger pressed.
Disconnect hoses.
Look for kink in water hose.
Check incoming water connection for filter washer
Replace filter washer
If you don't have a filter washer, put one in.
Hook up water, and turn on
Water should come out other side of pump.
Turn on machine.
Do you get pressured water out of pump.
If no pressure, then pump is suspect
Hook up washer hose without gun
Does pressure come out of washer hose
Finally, the gun trigger may be bad.
We had to buy guns now and then.
Search for pressure washer guns
Following link shows guns we used:
http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
My pressure washer is a G 2500 oh n i have no pressure coming out, it turns on but no pressure.
Good news, your engine runs
But your pump may be bad
Here's how to test your pump
Check oil as outlined lower down
Disconnect the washer hose and gun
Connect water hose and turn on water and water should pass straight through the pump
Look for clogs in the hose-end where water hose connects to machine
Turn on machine and see if water shoots out pump
If water shoots out of pump, but no water shoots out of gun, then you may have a 'mud-dobber' wasp clog in your washer line or gun
Look for clogs in the end of each water connection.
Now connect washer hose without the gun, tun on the machine, and see if water shoots out of washer hose
Finally, the gun trigger mechanism may be bad
I don't know which gun you have ... but we replaced guns on our machine now-and-then ... google-search power washer guns for a replacement
Check your pump oil
Pump oil is SAE20 or SAE30 non-detergent motor oil
Pump should be no more than 1/2 full of oil
Use plastic hose to drain pump oil
Do not turn machine on its side or turn machine over or engine oil will run into carburetor
Oct 20, 2010 | Karcher 2500 PSI Pressure Washer
My pressure washer will not pump the soap, when you take the pipe loose from the handle it pumps out when you hook it back to the handle it quites pumping
Most pressure washers introduce soap into stream of water by the siphon method. In order for the system to siphon the pressure tip must be changed to one with large opening. Once the large tip is install, the fast moving low pressure water thru the hose and wand will draw-in soap. With the pressure tip installed soap will not be drawn-in. To spray soap and water under pressure use a large container (larger the better like clean 30 gallon trashcan) and fill with clean water and measure of liquid detergent. Use short water hose from with-in container and connect to pressure washer as normal. Keep checking water level so that washer will not run dry. Most pressue washers will **** water in quickly from container, however you can pre-fill the water hose with water to speed things up. Trailer mounted pressure washers use a very large container for water. You can estimate how log the pressure washer will take to use the water by checking the gallons per minute rating of your machine. Good luck
Sep 02, 2010 | Campbell Hausfeld PW2102 Gas Pressure...
Psi Blue Max 2200 High Pressure Gas Power Washer Logo
622 people viewed this question
Top Psi Garden Experts
John Trevino
fordexpert
Jay Finke
Jay Finke
Are you a Psi Garden Expert? Answer questions, earn points and help others
