Question about Jensen's VM9312 Car DVD Player
I have a 2001 ram 1500 i try the hot and neg wiring on the stero still nothing, what color is the park brake wire so i cand tap in to that to view the movie at all times
  • 11 Answers
Most of the time it is blue
Posted on Jul 12, 2009
Which color wire is the hot wire that goes to the car stero
Most likely the red one. black is ground yellow is memory.
Dec 23, 2013 | 2001 Buick Regal
2005 dodge ram 1500, will not turn over. Battery is hot and tapping on starter doesn't help.
What you need to do is check to see if your getting current coming from the key switch to the starter. it's the thinnest wire that goes on the startex, that little round thing on the starter. if no current check the fuses you will see one as ( ST ) that is staring fuse. If fuse is ok then you check the starter relay and if that is ok then you might have a broken wire. to make sure the starter is working you could put the van in park and connect a jumper lead to the startex where the small wire runs to the starter and touch the next end to the B+ or 12 volts side of the battery and if the starter works then you have a broken wire.
Feb 25, 2013 | 1998 Dodge Ram 1500 4WD
2002 dodge ram 1500 brake and parking lots went out
Both. If the running lights ( marker, tail, clearence, or parking) and brake lights are out since the rain, a tail light assembly is broken and filling with water enough to create a short to ground. If there's no broken lens, whitch normally only blows the bulb. Then, the problem lyes in the trailer light harness. the brown wire (tail) & green wire (left turn/brake or yellow wire (right turn/brake) must be bare exsposed that shorts to ground when wet. all the trailer wires could be smashed together damaged the plastic coating on them. no problem till water shorts to ground. The white wire is the ground wire make its not able to touch the other 3 wires or bare & wet. Tape wires seperate then replace tail/mkr fuse and brake fuse. That should do it.
Jan 30, 2013 | 2001 Dodge Ram 1500 Truck 2WD
1996 dodge ram 1500 P/U, looking for wire color at brake pedal for cold side of switch for trailer brake controller hookup
if you have a test light then check for voltage at the wire that only has voltage when the brake is applied that is the wire that your looking for.don`t remember the color.
May 05, 2011 | 1996 Dodge Ram 1500 Club Cab
2001 dodge ram 1500. Brake lights do not work.
Do the taillights work? If so it might just be the bulb. If not then the wiring is broke some where or loose.
Feb 05, 2010 | 2001 Dodge Ram 1500 Truck 2WD
2004 dodge ram 1500 slt wiring diagram for hooking up a brake controller for a trailer
Try http://www.etrailer.com/faq-wiring.aspx. If it is factory installed, there should be a plug in next to/behind the parking brake pedal... at the top. Not easy to see or get to.
Oct 18, 2009 | 2004 Dodge Ram 1500
Locating the parking brake system on a 2002 Dodge Ram 1500
i believe they want you to wire it through the parking brake for safety purpose only. so you dont drive and watch a d.v.d. @ the same time. try wiring it to a ground directly,you should be o.k.
Jun 19, 2009 | 2001 Dodge Ram 1500 Truck 2WD
How do i bypass the emergency brake wire on a dual xdvd700
Its illegal to do but i have done it! You have to connect the brake wire to either the pos or neg wire! You need to find out which one it is thou, so attatch it to the negative first so you dont cause any damage if it doesnt work then connect it to the pos wire and it should work a treat for ya! I stress connect to neg first!!!!!!!!!!
Jun 13, 2008 | Jensen's VM9312 Car DVD Player
Jensen's VM9312 Car DVD Player Logo
52 people viewed this question
Top Jensen's Car Audio & Video Experts
Richard Foster
Richard Foster
afairman1927
Jose Velazquez
Jose Velazquez
Are you a Jensen's Car Audio and Video Expert? Answer questions, earn points and help others
