Question about Lowrance LCX-15MT GPS Receiver
My LCX15 MT will not turn on - Lowrance LCX-15MT GPS Receiver
    Scholar:
  • 30 Answers
If the power connections are good and clean, you can get a volt meter to test power through the power cable. Unplug the power cable and test for 12VDC across the two big female pins. If you are getting good power, then the LCX-15MT is toast and it will need to be replaced. If you can get a hold of Lowrance support at 800-324-1356 or email at http://www.lowrance.com/en/Support/Product-Support/Contact/ you can get a rebate toward a current model.
Posted on Jul 14, 2009
Cam specs on a 1967 Pontiac 400, 335 hp
Firebird App. Pontiac Part # Duration @ .050 Degrees Int/Exh Adv Duration Degrees Int/Exh Lobe Center Degrees Int/Exh Lobe Separation Angle Overlap Cam Lift Int/Exh Gross Lift Int/Exh
(1.5:1 Ratio Rocker) Gross Lift Int/Exh
(1.65:1 Ratio Rocker) 1977 TA6.6 549431 274/289 62 .249/.270 .374/.406 .411/.446 1978 TA6.6 10003402 273/289 54 .270/.271 .406/.407 .446/.448 1979 TA6.6 10003402 274/298 55 .249/.270 .374/.406 .411/.446 1967 400, 1968 350, 1973-76 400 w/ AT 9779066(E) OEM 200/210 273/282 106/116 111.25 55 .272/.271 .408/.407 .449/.448 1967-68 400HO w/ MT 9779067(P) OEM 200/213 273/289 113.5 54 .272/.271 .408/.407 .449/.448 1968 400 HO MT & RA-I AT, 1969 350 HO MT, 1969 400 MT, 1970
RA-III MT/AT, 1971-72 455 HO MT 9779068(S)
OEM 212/225 288/302 113/118 116 63 .272/.271 .408/.407 .449/.448 1967 RA MT/AT, 1968 RA-I MT,
(Some 1969 GTO RA-III MT) 9785744 (H)
OEM 224/236 301/313 112/119 115 76 .272/.271 .408/.407 .449/.448 1968-70 RA-II & RA-IV MT/AT 9794041
(T) OEM 230/240 308/320 112/115 114 87 .313/.313 .470/.470 .516/.516 (Stock in RAIV)
Sep 20, 2017 | Pontiac Cars & Trucks
Yamaha mt 03 engine light flashing
from my experience that spells code 55
Jul 25, 2012 | 2006 Yamaha MT-03
Soyo tv Mode MT-SYTPT3227AB will not turn on
It might be the power supply board. There is a repair service which addresses any problem with the power supply board, not just bad capacitors: http://www.coppelltvrepair.com/p/783/soyo-mt-sytpt3227ab-power-supply-board-repair-service-no-power-shutdown-etc
Jul 11, 2012 | Soyo SYTPT3227AB 32 in. LCD TV
How do i change the speedo from kmh to mph on my yam mt 03
Push the SELECT and RESET buttons together and turn the key ON,when the digits start flashing on the display push the SELECT button to choose kilometres or miles .
May 07, 2011 | 2007 Yamaha MT-03
What automatic transmission was used in the 1992 Ford F-250 Diesel
A.T., 4x4, AOD (5.0L)
EAC}G}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 11-1/4" ext hsg
EA}}}400" type="radio" name="userInterchange" />M.T., 4 spd (Warner T-18), 4x4
M.T., 5 spd, Mazda/Toyo Kogyo, 4x4
M.T., 5 spd, ZF, 4x4, 8-460 (7.5L)
M.T., 5 spd, ZF, 4x4, 8-445 (7.3L, diesel)
EAA}N}}400" type="radio" name="userInterchange" />A.T., 4x2, AOD (5.0L), 10-1/4" ext hsg
M.T., 4 spd (Warner T-18), 4x2, 12" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 12" ext, elec speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, cable drive speedo
M.T., 4 spd (Warner T-18), 4x2, 4" ext, elec speedo
F>}A}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-460 (7.5L), (elec speedo), (tag F2TP-YA)
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 6-300 (4.9L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-351 (5.8L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-460 (7.5L), elec speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), cable drive speedo
M.T., 5 spd, ZF, 4x2, 8-445 (7.3L, diesel), elec speedo
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID E9TA-TA & TB
M.T., 5 spd, ZF, 4x4, 6-300 (4.9L), ID F4TA-BA & BB
M.T., 5 spd, ZF, 4x4, 8-351 (5.8L), ID F4TA-BA & BB
>C}}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, elec speedo
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 2.73 ratio
>D}A}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.08 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 3.55 ratio
>D}B}}400" type="radio" name="userInterchange" />M.T., 5 spd, Mazda/Toyo Kogyo, 4x2, cable drive speedo, 4.10 ratio
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2TP-BA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 6-300 (4.9L), (elec speedo), ID F2UP-DA & DC
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-302 (5.0L), (elec speedo), (ID F2TP-DA)
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2TP-FA
A>}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-351 (5.8L), (elec speedo), ID F2UP-EA, EB & EC
?}}}400" type="radio" name="userInterchange" />A.T., 4x4, E4OD, 8-351 (5.8L), (elec speedo), (ID F2TP-HA)
}}}400" type="radio" name="userInterchange" />A.T., 4x2, C6, 8-460 (7.5L), (elec speedo), ID F2FP-CA & DA
A.T., 4x4, E4OD, 8-460 (7.5L)
E}}}400" type="radio" name="userInterchange" />A.T., 4x2, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; w/o ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), w/o ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), w/o ID F2FP-BA; ID F2UP-CA
A.T., 4x2, C6, 8-351 (5.8L), ID F2UP-CA
A.T., 4x2, C6, 6-300 (4.9L), ID F2FP-BA
A.T., 4x4, E4OD, 8-445 (7.3L, diesel)
A.T., 4x2, E4OD, 8-460 (7.5L)
A.T., 4x2, C6, 8-445 (7.3L diesel)
EF}D}}400" type="radio" name="userInterchange" />A.T., 4x4, C6, 8-351 (5.8L)
Good luck
Aug 10, 2010 | 1992 Ford F250
2007 Yamaha MT-03 Specs
Hi, Afaudio for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Yamaha MT 03 2007
Yamaha MT
Yamaha MT 03 Service Manual
OEM parts for Yamaha
YAMAHA MT 03 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 01, 2010 | 2007 Yamaha MT-03
Mt-03 km/h not mph
Place the key in the ignition switched off. Press and HOLD both the select and reset buttons before turning the key to the on position. Now let go of both buttons and the on screen digits should start flashing. Now press select to toggle between kilometres and miles per hour.
Mar 23, 2009 | 2006 Yamaha MT-03
LCX15 ci no trails
Check your settings. Menu>My Trails>Trail Options>Update Trail. If you uncheck the Update Trail option, automatic trail
creation will be turned off. This must be check to record and track.
Triton72
Jan 07, 2009 | Lowrance LCX-15MT GPS Receiver
Lamp Hour Meter
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Lamp hour reset to many popular projection TVs are given.
Mar 03, 2017 | Televison & Video
Lowrance LCX-15MT GPS Receiver Logo
466 people viewed this question
Top Lowrance GPS Experts
JonSnell Electronic
JonSnell Electronic
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
