Question about Maytag HAV3460AWW Top Load Washer
My Maytag washer will agitate without clothes in it but will not agitate with clothes in.
    Problem Solver:
  • 7 Answers
The water pump can begin to lose its shiney steel retainer which digs into its housing and slows or stops the belt.
Posted on Mar 20, 2010
  • 585 Answers
The belt is not doing it's job. It could be that the belt is worn, if so a replacement can be bought from a Maytag dealer. It is also possible that the belt is just not under the proper tension. Maytag motors are mounted in a slide, and tension is applied by a spring. if the grease in the slide gets old and hard, the slide will stick making for a loose belt. To access, you'll need to remove part of the cabinet. Pop the top loose at the front, remove two screws at the top of the front panel, and release the clips at the bottom to remove the front panel. Free up the slide with some light motor oil and re-assemble.
Posted on Jul 12, 2009
4 Suggested Answers
  • 219 Answers
SOURCE: LAT9604AAE No agitation but drum spins and drains water
cold possibly be just the agaitor but odds are u need a transmisson not worth repair
Posted on May 21, 2009
wiringlunati
  • 576 Answers
SOURCE: how can I make the Maytag Centennial 3.2 agitate
You really can't without redesigning the washing machine.
Posted on Mar 07, 2010
SOURCE: Maytag Centennial washer agitates when
Don't know what it is , but the 3 guys above me are wrong
Posted on Oct 16, 2012
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Will an agitator pick clothes
Do you meant pinch ??
If so - YES...
I have had several washers with agitators and pinched little tiny holes in my cloths..
So irritating..
I baught a front loader that just tumbles with no agitation..
Hope this helps !!
Please rate me good ;o)
Jul 11, 2009 | Maytag MTW5900TW Top Load Washer
Maytag Washer never stops running, goes from 1 cycle to the next
The timer is not stopping the agitate mode. And the timer is suppose to have its own off setting at the end of cycles. Suspect pretty strongly that the timer is at fault. Cant say for sure without looking at a wire diagram and eliminating any other controls.
If this helps you please rate me as high as possible.
If it doesn't help you please rediscribe your problem in more detail to help me understand, post back and I will follow up.
Mar 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Frontloader (Perf series) brand new Agitator off axis
Okay! We just fixed this problem on our washer. First, be safe and be sure that the electrical cord is unplugged. Then you want to take the lid panel off of your washer. Then you'll feel around under the base of the agitator/washer basket. You should notice that its feet sit inside huge springs which are fixed to the base of the machine unit. Determine whether any of your basket feet are disloged from their spring and re-insert. Make sure the fit is good or else you might have the same problem again. After you reassemble, plug in the machine and try a test spin without any clothes. Then try with a smallish load.
Hopefully this helps.
Jan 04, 2009 | Maytag Neptune MAH6700A Front Load Washer
Maytag top load performa, put clothes in , fill up and now the agitator is noisey, looked under washer belt appears to be loose 2-3 inches in play, should I replace belt,or something else to repair noise...
thats normal tension on the belt if the agitator is making noise the cams within the agitator are worn (loud clicking or popping noise during wash) the agitator will need to be replaced
Dec 15, 2008 | Maytag HAV2558 Top Load Washer
Maytag HAV3460AWW Top Load Washer Logo
243 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
