Question about Speed Queen Dryers
Speed Queed AEM677W2 dryer does not blow hot air
Speed Queed AEM677W2 electric dryer does not blow hot air.
  • 525 Answers
Below is a checklist provided by; www.repairclinic.com. They also provide repair parts, disassembly procedures and diagrams for DIY assistance.
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Firstly, ascertain that you have made a positive heat selection, then read on.
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jul 12, 2009
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
GTDX100EM1WW GE Electric Dryer smells hot and electric cord is very hot Problem not present on air dry. Vent is connected and air blows through. Cord is quite hot to touch at the outlet.
Usually the motor, if you're not experienced, better to have a service person come out. Almost always the motor in the dryer that causes this
Oct 10, 2011 | Dryers
Dryer not blowing hot air
When you say 220 gas dryer I'm not sure what you mean. If it's 220V then it should be an electric dryer, not a gas dryer. Troubleshooting is totally different between gas and electric. If it's electric (large 30A 220V plug) then good chance heating element(s) have gone bad. You can look up parts on www.searspartsdirect.com Have your complete model number. IF it's gas, it may be the pilot ignition has failed
Jul 26, 2010 | Kenmore 62602 Electric Dryer
Speed Queed Dryer Motor makes humming noise when starting.
motor is no longer strong enough to turn drum,soory-mike
Jan 24, 2010 | Speed Queen AES28AWF Electric Dryer
No longer blows hot air, only cold air
when a dryer does'ny blow hot air,it's normally either the element or the stats on the element.
Nov 01, 2009 | Dryers
My Amana electric dryer will not blow hot air.
Your problem could be faulty heater element and or faulty thermostats.
This is a normal problem if the blower is blowing cold air.
Sep 26, 2009 | Maytag MDE4806 Electric Dryer
Dryer working but not blowing hot air
Either bad thermal cutoff or bad element .( first 3 numbers missing on model #)
Jul 05, 2009 | Kenmore 800 6983 Electric Dryer
Air flow and heating problem inside dryer.
???? this doesnt make much sense, can see how you would be measuring air flow within the cabinet??? air blowing out unit strong means your gettin good air flow fom within, that is a direct relation as to the amount of (hot) air being pulled across the clothing
Jan 14, 2009 | Whirlpool LER4634J Electric Dryer
Kenmore dryer replaced heting element now it does not blow any air
HI danon this dryer its common to have the blower wear out, it slides on the motor shaft, and what they do is wear out the flat in the blower. that could have caused the element to fail. check the blower thanks the appliance doc. please rate my answer. thanks
Sep 30, 2008 | Kenmore 62602 Electric Dryer
KENMORE DRYER
Electric or gas?
Sep 13, 2007 | Dryers
Dryers Logo
459 people viewed this question
Top Speed Queen Dryers Experts
Marvin
Marvin
shaun taylor
Dennis Boxerman
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
