Question about Canon PowerShot A650 IS Digital Camera
Bad photo sensor
Occasionally, my images will have a upright rectangular area that is slightly washed out in the middle of the picture. (I assumed a bad photo sensor) I sent my camera back to the dealer, and they sent it back after they said it was fixed. Only they had jammed the battery cover shut so I couldn't open it. Also they had chipped off a piece of the cover, probably trying to close it. We sent it back again. Then they sent it back, saying they had repaired the problem. After a few weeks, I was starting to occasionally have the same problem with the photo sensor again. Can this be fixed?
  • Canon Master
  • 4,738 Answers
Canon will repair that problem for free. I'm assuming you mean Canon when you say "Dealer". If not, hope you were not paying money for those previous repairs. Recommend not letting anyone but Canon touch that camera. Please see the following:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=320&modelid=15658&keycode=2112&id=39151
Posted on Jul 12, 2009
How do i cut and paste photos togeather
open photoshop and open the photo you want to cut. Now use the rectangular selection tool to select the area you want to copy. After selecting the area, press ctrl+c to copy it. Now press ctrl+N to open a new page and paste ctrl+V to paste the selected area of the image.
May 15, 2014 | Computers & Internet
I got new Sigma 18-200 DC II lens, with Canon EOS 5D Mark II it has black lens frame is visible through viewfinder or on the photo. Does it mean this lens is not compatible with 5DmrkII?
The EOS 50d Mark II is what's known as a "full-frame" camera. Its image sensor is the same size as a frame of 35mm film. The Sigma DC lens is intended for cameras with smaller sensors. The lens is compatible in that it will work with the camera to take pictures, but the pictures are cropped due to the smaller imaging area of the lens.
In order to use the full image sensor area you need to use full-frame lenses. In the case of Sigma, this means lenses without the DC designation.
Aug 03, 2012 | Cameras
Split images
use good antivirus with updates and then transfer ur images and cd write it
half middle pic is due to speed of ur pc and viruses
Jun 18, 2009 | Canon EOS 40D Digital Camera
Pictures come out grainy with blue green hue and streaks
You'r right - probably pointless (I assume it's off warranty).
Apr 18, 2009 | Kodak EasyShare C533 Digital Camera
On playback, picture is "pink"
I have had the same problem with my Kodak. It happened only with macro photos and photos of the moon. It is caused by a fualty image sensor. Professional repair is probably needed.
Jan 16, 2009 | Canon PowerShot A85 Digital Camera
Bad photo quality
The Konika Minolta 7D is a DSLR. With the DSLR you have a much bigger sensor, and can use much bigger lenses (with larger apertures - lower f-stop numbers) to gather light to the sensor. This allows the DSLR to take much better photos in low light. You will never get the same quality out of a small pocket camera like the Nikon S60. Hand-held non-flash photos in low light with this camera are going to have the flaws you have noticed - especially in the darker areas of the image. This is digital noise caused by amplifying the signal from the sensor as the camera processes the image with the high ISO setting.
You said you are sure that you are using the highest picture quality settings. The next thing is to change the ISO - this camera's "high ISO" does not produce images with good quality. The camera automatically uses a high ISO setting in low light, you need to tell it to not use high ISO by setting a lower ISO value. When shooting with a low ISO setting in low light, you need to use a tripod, and your subject can not be moving.
If you need to take hand-held photos, or your subject is moving, then you need to use flash with this camera, or else use your 7D.
Dec 29, 2008 | Nikon COOLPIX S60 Digital Camera
Ripples appear in the image when photographing an object with fine plaids or stripes. How can I fix that?
When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red cross-stripes and black cross-stripes overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly. Reference You may find another Moire effect displayed on the LCD of the camera. As this is caused by the aligned pixels on the LCD, this effect does not necessarily appear in pictures you have taken.
Sep 04, 2005 | Canon GL2 Mini DV Digital Camcorder
Picture ripples
The following describes the symptoms, cause and prevention of the Moire effect. Symptoms of the Moire effect When you are shooting a subject that has a fine regular pattern such as stripes or plaids, a ripple that does not exist on the subject sometimes appears in the image. An example of this can be seen in the pictures below. The photo on the left shows the fine plaids pattern on the shirt. The photo on the right is a distance shot of the same shirt. In this photo, you can see a ripple that is not visible in the photo on the left. This effect is called the Moire effect. Why does the Moire effect occur? Digital cameras and camcorders are equipped with imaging devices such as CCD sensors and CMOS sensors that have pixels that are finely aligned horizontally and vertically that convert light into electronic signals. When the pixels and the fine pattern on the subject overlap slightly misaligned, an interference pattern occurs and a ripple that does not exist on the actual subject may appear. This is the Moire effect. Look at the image above. This image shows red stripes and black plaids overlapped slightly misaligned. When you look at the entire image, you find a ripple that differs from either of the patterns. This is the same principle that causes the Moire effect. Preventing the Moire effect You can reduce this effect by changing the distance, zoom setting or the angle of the image. If you are using a camera with manual focusing, the Moire effect can be reduced by simply changing the focus slightly.
Aug 31, 2005 | Canon PowerShot Pro1 Digital Camera
Picture ripples
Aug 31, 2005 | Canon PowerShot SD300 / IXUS 40 Digital...
Canon PowerShot A650 IS Digital Camera Logo
128 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
