Question about Compaq Computers & Internet
When starting up computer, compaq monitor has blue screen and says intel inside, won't continue to start up
  • 339 Answers
The intel inside logo is coming from the computer. Try the display on another computer and I suspect you will find it works OK. If so then you likely have a bad computer.
The other possibility is that your computer is switching to a screen resolution or scan rate that isn't supported by your monitor. If this is the case then you'll need to borrow a more modern monitor and adjust the display settings to falll within a supported range for your display and then things will be fine.
Posted on Jul 12, 2009
Imac intel blue screen
Can you start up in Single User Mode? Restart and hold down the command/Apple & the "S" key.
Apr 17, 2012 | Apple iMac G5 Desktop
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
Out of range set monitor to 1024 x 768 @75mherz
Your monitor probably does not support this frequency. 60 Hz is most likely correct for a monitor of this size and resolution.
Oct 21, 2010 | HP Compaq 1501 15" LCD Monitor
The picture on my Compaq monitor shifted 1 inch to the left. There is a one inch black space on the right side. I have a HP Compaq d530 CMT
click menu button on monitor. you will see a series of Icons (or scroll through a series of Icons) and one will be a square with a smaller square inside it that is half inside the larger and half out. Navigate to that Icon. Use the + or - buttons to move the screen in either direction until it evens out. Use + or - button to navigate back to exit and and then press menu button to exit screen. Or, sometimes you simply push the menu button a second time. These 3 buttons will be on the bottom front of the monitor. Good luck
Oct 21, 2010 | HP Compaq d530 CMT Intel Desktop PC -...
Intel D865GLC computer problems.
Go back to what started the problem. You bought 2 1 gig ram sticks. My bet is they're either not matched ram that matches what you already had in your computer or is not compatible with your motherboard or the ram is defective and has bad memory addresses. If your computer has build in video card then it probably gets it's video ram from the system ram. A lot of the blue screens of death are caused by bad memory address although it can look like it's blaming the problem on a certain program or device driver because that is the program or driver that was atempting to use the bad memory address.
Jun 08, 2009 | Intel D865GLC Motherboard
Flickering or Blueing of Vison V221WD monitor.
Check all the cables, if it is not the cables being loose, then it is a component inside that is starting to fail.
Mar 19, 2017 | TDV Vison F153 Monitor
Not display computer name(intel) when turn on
enable it from your bios setup. logo at startup screen.
May 28, 2009 | HP Compaq MV 7500 17" CRT Monitor
Presario v2000 display problems
there is someting loose inside the computer so you may have to open it and check for loose conections or pices that they may be loose or video conectors
Jan 05, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario 1245 doesn't start up
Most laptops have a video connector that you can use to connect you laptop to an external monitor. connect an external monitor to your laptop and see if anythig comes up on the external monitor.Your laptop has a key to switch between it's own screen and the external monitor.When you use the external monitor ,you'll have to use this key to switch to the monitor.Your battery should'nt matter if the laptop is running on AC.Let me know what happens and we'll go from there.
Jan 02, 2008 | Compaq Presario 900 /1500 Series EVO...
Computers & Internet Logo
75 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
