If the paper is size is set wrongly, then you need to change the default paper size of your printer. Click Start and go to settings. Click printers. Right-click your printer model and select Properties. Click the paper tab. Choose the size of paper that you require to use in the paper Size-box. Make sure to load the correct paper for the printer mentioned in the paper tab. Click OK and then close the Printers folder. Most of the HP Laserjet printers automatically detect the paper sizes loaded in the paper trays thanks to the sensors present in the paper width guides.
For a better method, go to the Control Panel on your computer and select Devices and Printers. Right-clickon your printer model from the list and select Printer Properties. Change the paper size from A1 to A4. Set manual feed to A4 instead of Letter. Call Our Toll-Free 1-866-293-9220
Paper size is set for a different country. Assumimg your in the US. Have to go into admin mode Maintenance mode set paper size to letter or legalnot B4 or C5 or A3 or A4 theese are metric size paper.
The reason you need to press the print button is because of the mismatch between the two paper sizes, this is normal. Find the manual and follow the instruction on how to change the paper size on the printer, or change the paper size in your software. Either should work. They must be the same for it to work properly.
2.may be you have given wrong paper size.u might have give wrong paper size.for ex for A4 paper u might have given some other size like a3. check this it will work for u
on the control panel you should change the settings, like it shows---> Default Paper Size: A4 or Letter Default Paper Type: Plain Manual Feed: Off Tray 1 Size: Any Size Tray 1 Type: Any Type Tray 2 Size: A4 or Letter Tray 2 Type: Heavy 111-130g Tray 3 Size: A4 or Letter Tray 3 Type: Heavy 111-130g
your printer CHANGE PAPER TO
A4/LTR/LGL PLAIN
The paper size setting is set to a size other than
A4, letter or legal in fax receive mode.
The paper type setting is set to a type other than
PLAIN in fax receive mode.
Set the paper size setting to A4, letter or
legal and load paper of the same size.
Set the paper type setting to PLAIN.
There is no way to change your machine into printer mode only.
machine works in dual mode copier/printer.whenever you send a print from the computer, machine automatically receive the document and print it at the same time without changing the mode.like SCAN MODE AND HARD DISK MODE.
So if you are facing a problem regarding printing then please check the paper size of the machine, and also check the paper size from the "PRINTING PREFERENCES" by taking the properties of printer icon in printer and faxes menu.(where installed printers shows) right click on the bizhub 200 printer icon and clickj on "properties". now click on "printing preferences" tab and then click on "size" tab, now from here check the paper size.its A4 or not if its not A4 then please change it to A4 then again give a print command.machine will start printing.
