Question about Canon Cameras
My Canon Ixus 75 will no longer take pictures.The screen remains blank and no image is recorded when the shutter is pressed. All other functions appear normal, including the display ing of previously recorded images.
  • Canon Master
  • 4,738 Answers
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Posted on Jul 12, 2009
Hi my Canon Powershot SD 750 LCD screen stays black when taking pictures, you can't view them either. The only thing that shows up on the screen is the menu functions, you can look through everything...
First try pressing the DISP or DISPLAY button on the back of your camera. If that doesn't help, astuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 05, 2011 | Canon PowerShot SD750 / IXUS 75 Digital...
My canon PowerShot SD750 digital camera screen suddenly turn black(dark ), I can not take picture because there is no image shown on screen. I still can record sound on video,but no image. what is going...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A.
Dec 26, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Turned on ixus 75 and i have a black screen
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help. Pay particular attention to Fix #5A of the link.
Dec 23, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My view screen has suddenly stopped working although the other functions show on the screen
You may have accidentally pressed the DISP or DISPLAY button on the back of your camera. Try pressing it again to see if this corrects the problem. If it doesn't, take a picture and download it to your camera. Is the picture black like the screen? If so, you then likely have a stuck shutter. In that case, see this article for a quick fix that you can do.
Dec 19, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I can open my camera but the view screen is blank! Help!
Press the DISP or DISPLAY button. If that didn't fix it...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jun 17, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
Mt camera will not show a picture to take the screen is blank when you turn it on
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
If that didn't help, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
The LCD screen has gone blank...the other features seem to be fine...but can't click pictures any more...they appear black..
Jul 24, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
When I turn my canon ixus 75 on I see a black sreen is all the camera functions. Viewing the already taken pictures I can see them all. When I take a picture it shows in view mode a balck picture. I guess...
No, if your camera is an Ixus 75, it's more likely that you're experiencing a stuck shutter. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jun 15, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Blank screen
did you press the disp. button?
May 08, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Cameras Logo
167 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
