Computers & Internet Logo
Louise Meisenhoelder Posted on Aug 26, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I find Microsoft 10 description? - Microsoft Computers & Internet
Jamie Fuller
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Jul 25, 2017
Jamie Fuller
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
97
Points
18
Microsoft Windows 10 Professional is an operating system and allows all the program to use or run on the system. Windows apps can now be finally resized and operated in window mode. In addition, Microsoft has integrated the function of virtual desktops directly into Windows 10, additional tools are no longer necessary.Also, a universal search function will be found here. Windows 10 makes suggestions here, how the programs can be arranged particularly efficiently. Here, too, it is easy to see that Microsoft has a focus on users with many open applications, especially the business users.
Anne Medina
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Sep 28, 2015
Anne Medina
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
0
Helped
2177
Points
25
Scott Fryer
Level 2:
Scholar:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 106 Answers
  • Posted on Aug 28, 2015
Scott Fryer
Expert
Level 2:
Scholar:
Cheetah:
Answers
106
Questions
0
Helped
27328
Points
212
2answers
04 kia spectra fuse diagram and description
Description Fuse rating [A] Protected component
ECU B+ 10 ECU, ECAT, Shift lock, Data link connector, Check connector
AUDIO 10 Audio, Auto clock, ETWIS
ABS 10 ABS
TURN LAMP 10 Turn lamp
STOP LAMP 10 Stop light
CIGAR LIGHTER 15 Cigar lighter
AIR BAG 10 Airbag
METER 10 Meter, Inhibitior SW, Speed sensor, Back-up light, ETWIS
DRL 10 Daytime running light, illuminated ignition switch
SEAT WARM 15 Seat warmer
FRONT WIPER 20 Front wiper & Washer
TCU IG 1 10 ECAT, DRL
C:\Users\Nelson>ipconfig /all Windows IP Configuration Host Name . . . . . . . . . . . . : Dragonlorde Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP...
It does not show as connected. Connect the ISP modem to main uplink port. Then connect pc to any other port. Done! Test it with network cable to pc before trying a wireless device.
Default IP is 192.168.1.1 Use web browser to access. User: Admin Password: password.
There is reset option in the back. Hold it in till it cycles. This will clear all custom settings.
http://www.netgear.com/images/WNR3500Lv2_DS_07Jun1118-5898.pdf
I am getting code 10 error in device manager
Code 10
If the device has a FailReasonString value in its hardware key, that string is displayed as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message: This device cannot start. (Code 10) Recommended resolutions
Here are some things that you can try to resolve this problem.
Update the driver
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor's Web site.
View the article in the Microsoft Knowledge Base
For more information about Code 10-related errors , click the following article number to view the article in the Microsoft Knowledge Base: 943104 (http://support.microsoft.com/kb/943104/ ) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
Sigmatel s18 alawys handsfree mode sir, plz help
i get disconnected every 5 mins when im on online games... Microsoft Windows [Version 6.1.7600] Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\vaio>ipconfig/all
Host Name . . . . . . . . . . . . : vaio-VAIO Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Bluetooth Network Connection:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network) Physical Address. . . . . . . . . : 00-26-43-FA-BD-FC DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Marvell Yukon 88E8057 PCI-E Gigabit Ether net Controller Physical Address. . . . . . . . . : 00-24-BE-84-48-99 DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Wireless Network Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Intel(R) WiFi Link 5100 AGN Physical Address. . . . . . . . . : 00-24-D6-3C-A4-1A DHCP Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes Link-local IPv6 Address . . . . . : fe80::2565:e8a3:5e8f:4e8d%11(Preferred) IPv4 Address. . . . . . . . . . . : 192.168.0.103(Preferred) Subnet Mask . . . . . . . . . . . : 255.255.255.0 Lease Obtained. . . . . . . . . . : Monday, May 09, 2011 6:54:42 AM Lease Expires . . . . . . . . . . : Tuesday, May 10, 2011 6:54:41 PM Default Gateway . . . . . . . . . : 192.168.0.1 DHCP Server . . . . . . . . . . . : 192.168.0.1 DHCPv6 IAID . . . . . . . . . . . : 184558806 DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-14-9C-59-56-00-24-BE-84-48-99
DNS Servers . . . . . . . . . . . : 192.168.0.1 NetBIOS over Tcpip. . . . . . . . : Enabled
Tunnel adapter Local Area Connection* 17:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes
Tunnel adapter isatap.{07E2F4DD-B9BA-4164-9865-1833EC48EA69}:
Media State . . . . . . . . . . . : Media disconnected Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Microsoft ISATAP Adapter #2 Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes
Tunnel adapter Teredo Tunneling Pseudo-Interface:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Teredo Tunneling Pseudo-Interface Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0 DHCP Enabled. . . . . . . . . . . : No Autoconfiguration Enabled . . . . : Yes IPv6 Address. . . . . . . . . . . : 2001:0:4137:9e76:8bb:234c:8f31:410a(Prefe rred) Link-local IPv6 Address . . . . . : fe80::8bb:234c:8f31:410a%15(Preferred) Default Gateway . . . . . . . . . : :: NetBIOS over Tcpip. . . . . . . . : Disabled
HI,
Information as from the Microsoft website:
Code 10
Update the driver
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
943104 (http://support.microsoft.com/kb/943104/ ) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers For further details: http://support.microsoft.com/kb/310123
Xbox live
1 year=about $50
1month= about $10- $10*12months = about $120
$50 per year is less than $120 a year + pay each month, so its better to get a 1 year xbox live description
Cd rom wont start (code 10)
Device failed to start. Click Update Driver to update the drivers for this device. On the General Properties tab of the device, click Troubleshoot to start the Troubleshooting Wizard.
943104 (http://support.microsoft.com/kb/943104/) Description of Code 10-related errors that Device Manager generates on Windows XP-based computers
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
