Question about Canon BubbleJet i560 InkJet Printer
How do I do a waste ink bypass to recycle ink from waste tank to avoid it getting full again?
I already manually cleaned it once but don't think it will be able to be cleaned a second time!! It's losing absorbancy.
    Sergeant:
  • Canon Expert
  • 394 Answers
There is a small tube running from the pump to the waste ink pads. If you connect another tube to that, you would be able to run it out to an external bottle. Please note this won't stop the waste ink counter from doing it's thing.
Posted on May 03, 2016
SOURCE:
SOURCE: Waste ink absorber on canon iP 1600
For Canon ip1000 and ip1600, maybe others
1. remove cartridges
2. unplug AC power
3. hold power button and plug AC power (keep holding power button.
4. press resume 4 times
The waste ink counter should be reset by now
Or
http://www.servicemanuals.ru/download/canon/ip1600.htm
Posted on Nov 30, 2007
SOURCE: waste ink tank full
please help me for repair waste in tank full canon ip3300.
Posted on Jan 24, 2008
CAM THE MAN
  • 20 Answers
SOURCE: waste ink absorber
This is the ink counter reset instructions:
1. Service mode: Menu->Scan->Copy->Scan( one at a time in sequence)
2.Select "test mode"
3.Select "(8) ETC
4.Select "(4) EEPROM CLEAR
5.Select "(1) INK COUNT
6. press the OK button
7. Press the STOP/RESET button(returns you to the TEST MODE sub-menu
8. Press the ON/OFF button (which resets the printer).
There you go.
Posted on May 27, 2008
  • 3 Answers
SOURCE: waste ink absorber is full. How can i fix it?
error code E7 for canon210
Posted on Jun 03, 2008
SOURCE: ink waste absorber
Waste absorber is full. Where is the waste ink absorber and how do I empty it?
Posted on Apr 09, 2009
What is error P7 on Canon MP250 printer?
Please refer to this video, to fix it:
https://www.youtube.com/watch?v=HvBpioLPm3M
Inkjet printers has an "ink absorber" counter in which when it has reached a certain level that error will occur. Because when you are printing, some parts of the ink become waste ink & goes to the internal "tank" inside the printer where they are dried. The ink absorber counter tells you that the "tank" is nearly full which might flood the internal parts of the printer and damage them, causing short circuits.
However, this error could be bypassed by resetting the printer as described on the video.
Another better solution is by installing an external waste ink tank to channel the waste ink outside the printer to avoid internal damage. The P07 error will still occur, however you can bypass it.
Apr 28, 2014 | Office Equipment & Supplies
IP 6700 d waste absorber nearly full. How do I resolve?
Hi. I think the problem on that one is the waste ink tank is already full, so you need to clean it or replace the pads on it, because when you are printing or opening your printer it blows little amount of ink to the heads so that it will not be clogged, and that ink goes into the used/waste ink tank. Also after cleaning the used/waste ink tank you need to reset the counter of the printer so that it would print again, you can just download the counter reset software2_bing.gif over the internet or just bring that machine to an authorize canon printer technician. Hope this Helps
Jun 09, 2010 | Canon PIXMA iP6700D InkJet Photo Printer
Sir , my printer canon pixma ip 1200 when i start to print it show waste ink obsorber is full. please help
Jun 09, 2010 | Canon PIXMA iP1200 Photo Printer
Ink absorber nearly full keep gettiing the prompt. Like to know solution.
Hi. I think the problem on that one is the waste ink tank is already full, so you need to clean it or replace the pads on it, because when you are printing or opening your printer it blows little amount of ink to the heads so that it will not be clogged, and that ink goes into the used/waste ink tank. Also after cleaning the used/waste ink tank you need to reset the counter of the printer so that it would print again, you can just download the counter reset software over the internet or just bring that machine to an authorize canon printer technician. Hope this Helps
Jun 08, 2010 | Office Equipment & Supplies
The printer doesn't respond any more, and the computer, when asked any task, answers: the used ink tank is full, contact maintenance center in order to replace the used ink tank. But it would not don...
Jun 04, 2010 | Canon PIXMA iP90 InkJet Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
WASTE INK ABSORBA FULL
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink tank full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 23, 2009 | Canon Office Equipment & Supplies
Message "wasted ink tank near full" on Canon Multipass F80
May 17, 2009 | Canon MultiPASS F80 All-In-One InkJet...
Waste tank is full, How do fix it, can I clean it myself?
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
May 15, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Canon BubbleJet i560 InkJet Printer Logo
71 people viewed this question
Clive
Clive
old marine
old marine
