Question about Refrigerators
I have a GE refrigerator, Model GSH25KGMC The coils in the freezer side are freezing up and the refrigerator side is getting warm. I have replaced the defrost unit on the freezer (glass tube unit at the bottom of the coils)one time and the freezer/refrigerator worked great for a month. I had the same problem a week ago and thawed the unit replaced the same part and it worked for about 5 days. Now I am having this problem on a 5 day cycle where I defrost the coils with a blow dryer and get it working again, this time the defrost unit has not gone bad, the unit is not milky looking and I can still see the wire coils inside the glass. Any good words of wisdom on this one ??
  • 4,070 Answers
There are three parts to the defrost system You've taken care of the heater do now check defrost thermostat>http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the heater and thermostat are ok it’ll be the Motherboard.
Your motherboard is part 801 on diagram 10>http://www.appliancepartspros.com/partsearch/model.aspx?model_id=210244
Posted on Jul 12, 2009
I have a GE SSL27RGRB BS. The freezer stopped freezing all the way when I took off the interior rear panel the bottom coils are working good but the top coils are warm and do not freeze at all. What do I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 04, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side Not freezing or cooling at the top levels
heatman101
rtyhrtgf
Apr 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer coils freeze up, refrigerator gets warm
You first need to check your defrost heater for continuity if none this is your problem if it has continuity it is good and you will need to replace your adaptive control board part # AP4010220 ? Enter your complete model # at www.appliancehelponline.com for illustrations and correct parts. The model # listed should have a few more digits thats why I ? the part # I listed. There is also a troubleshooting page that can help walk you thru testing these components.
Mar 28, 2010 | Amana ASD 2624 Side by Side Refrigerator
GE Refig. water does't dispense
adjust tempt of fresh food side it may be to cold and freezing veg/ and water line .. **** ..
Jan 19, 2010 | GE GSH25KGMWW Side by Side Refrigerator
Coils freeze up in freezer and fridge gets warm
You have to completly thaw out the the freezer and dry off all moisture with paper towels then turn back on be sure to wipe the rubber seals down so no moisture is pulled out of the air between the seals of the door and cabnet.
Oct 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Turbo cool will not turn off in GE side-by-side refrigerator. Replaced circuit board...still stays on
There are three temp sensors in my GE side-by-side model GSS20IEMDWW (two in the freezer and one in the fresh food side). Replacing the temp sensor in the fresh food side was enough to allow the compressor to finally turn off.
For me, the problem manifested with an iced-over evaporator coil inside the freezer compartment. Since the compressor never cycled off (presumably because the temp sensor was providing faulty data about the temp inside the fresh food side, thus causing it to continually attempt to cool), the coils were constantly chilled. Eventually the ice on the coils would block the air flow and the freezer side could no longer freeze
I purchased a pair of inexpensive thermometers from a kitchen store and put one in the freeze and one in the fresh food side so I could occasionally look at the temps to see if it made sense for the compressor to be running - ie, was it really a warm-enough temp for cooling to be required, or was the computer reading faulty sensor data.
Six months later I also needed to replace both temp sensors in the freezer compartment. My refrigerator is about seven years old. I would recommend replacing all of the temp sensors just to rule that out.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=GSS20IEMDWW&mfgModelNum=&fkMfgID=2
Your model may be different, but this will give you an idea of part numbers and relative locations of the parts.
Jul 16, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Kenmore Cold Spot fridge, freezer on top. Fridge is warm, and freezer keeps freezing up on sides and bottom. I cleaned it all out, defrosted it, and it still freezes up and fridge still won't get...
Is this a self defrost model? Frost inside the freezer could be an air leak around the door gasket. Remove the back panel in the freezer and completely defrost the coils. Is the fan running in the freezer. That will make the frig not be cool. With the door closed peek in the gasket to make sure the light is shutting off, this will warm a frig also.
Eric
Jun 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer is freezes it self up and a giant block of ice froms but refrigerator is warm
Hi: your model number dosn't get a match on a search. Did you check the defrost heater? I hope this helps Jeff,
Jun 01, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer coils freezing, fridge warm
You might want to check and make sure the interior fan is working above the evaporator coils. If the fan isn't working the air won't circulate over the evaporator and it will frost over very quickly, and also cold air won't be pushed into the fridge side.
The fan might turn off when the door is open, hold the door switch shut while you check it.
Apr 27, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Refrigerators Logo
283 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
