The bolt holding in the mower drive clutch failed -- second time in two months!
It's a 180 mile round trip to the nearest dealer, so last time I got the parts and had a local handyman replace the entire clutch (which was shredded). I'm wondering if the dealer might know something that would make it worthwhile to trailer the mower to the dealer? I also wonder if I'm doing something wrong, although I haven't changed anything, and the first clutch lasted six years. I mow two acres of pretty rough pasture about every four days, occasionally sideswiping 6" wood posts as I try to cut close to the fence line.
I have this mower and had this same problem. It turned out the bolts holding the motor to frame backed out and were allowing the motor to tilt, and then the belts would slip and burn up. Check all motor bolts for tight, and if not tight change bolts and lock washers. Lock washers were not originally on these mowers.
Message Center Configuration Oil Life Reset - Message Center Cluster
NOTE: The oil life calculation is set at a maximum of approximately 8,000 km (5,000 miles) or 180 days
Press and release the SETUP button until the message center displays PRESS RESET TO BEGIN SYSTEM CHECK.
Press and release the RESET button until the message center displays HOLD RESET IF NEW OIL.
Press and hold the RESET button for 2 seconds and release to reset the oil life to 100%.
The message center displays SETUP MENU HOLD RESET.
Oil Life Reset - Base Instrument Cluster
NOTE: The oil life calculation is set at a maximum of approximately 8,000 km (5,000 miles) or 180 days.
Place the ignition in the RUN position with the engine off (KOEO).
Press and release the TRIP/RESET button until SETUP MENU HOLD RESET is displayed.
Press and hold the TRIP/RESET button until SYSTEM CHECK is displayed.
Release the TRIP/RESET button.
Press and release the TRIP/RESET button to scroll through the system check menu items until HOLD RESET IF NEW OIL is displayed.
Press and hold the TRIP/RESET button until OIL LIFE SET TO 100% is displayed.
Release the TRIP/RESET button. The oil life is now reset.
Oil Life Start Value - Message Center Cluster
NOTE: The oil life start value is used to reset the oil life value back to the maximum of approximately 8,000 km (5,000 miles) if the value was previously changed or to lower the value from the maximum (8,000 km To reset the oil monitoring system to 100% after each oil change [approximately 5,000 miles (8,000 km) or 180 days] perform the following:
Enter SYSTEM CHECK to display "OIL XXX% OIL LIFE OK".
Press RESET control to display "HOLD RESET IF NEW OIL".
Press and hold RESET control for more than 2 seconds. Oil life is set to 100% and "OIL CHANGE SET TO 100%" is displayed
I own the same model for 3years. Last month exactly same thing happened . In my case i send it to dealer they diagnosed ecu malfunction which need to be replaced.as im in karachi(Pakistan). It took them almost a month to import it from japan
1.) Turn the key to the on position (do not start car) 2.) Press trip reset button 3 times until service shows 3.) HOLD DOWN reset button 4.) WHILE HOLDING button, turn key off 5.) While key is in off position release the button and repress 6.) Turn key back on holding down the reset button 7.) Wait until service resets
This has to be done in 10 seconds. It may take a couple tries.
Variations include...make sure door is shut and car in neutral.
there is a little button switch on the top of the clutch mounting bracket check it it is adjustable it may be off also the mounting plate for the clutch and brake pedal may be bent i have seen this in these trucks many times check it out for contact on the switch
