Question about Velbon CX-470 Tripod
Focal tripod, 20-08-44 crank handle broke
I have a Focal tripod, 20-08-44 that fell off a chair and broke the crank handle. Looks like I could just replace the crank by tapping out the pin where the handle folds. Any idea where to get new crank handle?
I have 3clb tripod.the hand crank broke off. Looking for replacement.
Replacement for what ? Entire tripod - look on eBay. Broken handle -- contact mfr support and service
Oct 16, 2017 | Photography
I'm looking for an elevator crank handle for a slik master classic tripod 6857u
By elevator crank handle I presume you mean the centre column adjuster. May be available from the manufacturer or importer, otherwise try Ebay or your local friendly camera service centre.
Jun 27, 2016 | Slik Photography
Tripod handle
for $49.95 you can get another tripod
Jul 28, 2014 | Slik U9000 Tripod
Why can't I find a replacement part?
Available replacement parts for Sunpack tripods are pretty much limited to new heads, mounting plates, or carry cases; take a look at what B&H Photo has to offer. You don't say what specific tripod you have, but I'd suggest a search at eBay where several are available at auction right now. Furthermore, a check of completed auction/sales shows both new and lightly used ones sold in the past month for between $10 to $50. Buy one for parts or use it as is. You won't find any part plus shipping for less than that.
Sunpack makes consumer not pro level tripods even though the term Pro may appear in some product names. When you buy a tripod that costs $400 and up without the head, you get more options for replacement parts. I have a Sunpack myself for lightest duty when hiking, but my main tripod is a Manfrotto with the grip head. The huge difference in cost makes a corresponding difference in what parts I can find online. When my Sunpack broke (in a different way than yours but equally unusable) I used gaffer's tape to hold it together until I could find a new one (on eBay for $15).
May 07, 2014 | Sunpak Photography
Sunbelt crank handle
Refer your inquiry to the manufacturer/distributor
May 07, 2014 | AmbiCom V-0555 Tripod
Focal tripod
I have a Focal tripod model # 20-08-87 that is missing the quick release plate. I cannot seem to locate a replacement. Can you help me locate one??? Thanks, Jackie
Mar 01, 2008 | Sanford Traveler Tripod
Need parts to repair pan handle
I just had this problem! I took it to Ace hardware and the guys helped me out, big time. I have a PH-358 panhandle and the same piece fell of during a shoot into some brush and dirt outside.
We (they) fixed it using a #6 metric bolt and butterfly wing nut along with two grommets (3/8 ID and 5/8 OD). It worked perfectly! Not only does it hold the handle together but you can tighten or loosen the handle as well using the butterfly wing nut.
Sep 17, 2007 | Velbon VideoMate Deluxe Heavy-Duty...
Velbon CX-470 Tripod Logo
336 people viewed this question
Top Velbon Photography Experts
Marvin
Marvin
Dennis Kyne
Dennis Kyne
Tony Parsons
Tony Parsons
Are you a Velbon Photography Expert? Answer questions, earn points and help others
