Question about Maytag MER6772 Gemini Electric Kitchen Range
Control lock we were cleaning the oven and the botttom door switch is now moving freely back and forth and the panel says control lock how can be change the lock cannot get to it
    Problem Solver:
  • 6 Answers
Press and hold cancel and cook and hold pads for 3-5 seconds then you will probably have to replace the sensor.
Posted on Dec 20, 2007
How to get the F9 err off when i press the button clean for my oven
The F9 code indicates a problem with the door lock. (Since the oven must lock the door for a cleaning cycle, this will be a "fatal" error for the cleaning cycle.) There are a few possibilities. Open the oven door and look for a L-shaped piece of metal on the top of the oven frame. Check that this lock part is angled to go straight up (12 on an analog clock). If it is rotated slightly, it won't fit properly during the lock cycle.
Clean the latch and wiggle it to check if it will move freely. If these steps don't fix the problem, you need to check the door latch motor and switches. You will need to take off the back panel of the oven to find the motor. Check for loose wires or damaged/loose switches.
If the motor assembly and switches are good, then the central control (clock) probably needs to be replaced.
I hope this helps.
(most self-cleaning ovens will eventually have a problem with the lock assembly.)
Sep 24, 2013 | Frigidaire Stove/Oven/Range Cooktop -...
Whirlpool self cleaning oven Accubake. 2 yr old
Hi
The oven door lock needs approximately 1 hour to cool down before the oven door can be opened after a self cleaning cycle has finished. If the lock does not open after the oven has cooled down, you can try....1) Unplugging the range or shut off the circuit breaker for 5 minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. 2) Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door.
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid. In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
If you've interrupted the clean cycle or have accidentally set the clean cycle with the oven door open, the latch may have engaged and now the door can't be closed because it will hit the latch. There may be a door activated* switch on the front face of the oven. In this case you may need to manually press that door switch with your finger while at the same time canceling the clean cycle to get the latch to retract so the door can close fully again.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jul 06, 2009 | Whirlpool 30 in. RC8700 Electric Cooktop
Self-cleaning oven door won't open
May 15, 2009 | Ovens
I accidently pressed self clean instead of boil on my oven
Hi
*On -some- Frigidaire built ranges, the switch is located behind the right hand side panel and activated by the right hand door hinge. On this model, the side panel may need to be removed to access a malfunctioning door switch.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Apr 27, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door won't open after cleaning
After self cleaning the range the door won't open....
Apr 01, 2009 | GE Kitchen Ranges
GE Double Oven doors locked and circuit not responding
Hi, well this is a brain tester!! I think you need really to look at this in a simple way. Check to see where the door lock wires come from first? Find where the mains power comes into? then if it goes directly to the main control board then check to see if there is any power getting through the board to the otherside where the wires disapear into the cooker. I would consider checking the control board for any signs of burn damage and then look at the clock unit to as these are normally the main components in the cooker that will stop it from working.
Good luck,,,,,,,,,,,,,,,
Jan 02, 2009 | GE Profile JTP56 Electric Double Oven
The self cleaning oven lock is locked but door is not closed.
It's time for service sounds like you have a bad oven door switch or the mechanical rod that engages the switch is not travelling back and forth freely. Anr repairs with the rear access panel off should only be performed by factory trained service tech's.
Dec 22, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
My Electric Frigidaire Convection Oven just locked it's own door! I heard a continual beep..then "Err" "F9" flashed, then beeping stopped and the illuminated "padlock" symbol lit up and the door locked...
I have a similar problem with my electric Frigidaire convection oven, which flashes ERR F9 and beeps after finishing a cleaning cycle; if you haven't had to have it repaired professionally by now you might try cutting the circuit breaker to the oven for a few seconds and then turning it back on. My oven takes a few minutes to reset, after the circuit is turned back on, but then will unlock the door and let me reset the clock and continue cooking as normal. . . until the next time I set the clean cycle.
FW
Seattle WA
Dec 15, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
Self clean oven door lock will not unlock accidentally pushed clean button, cancelled clean but oven door will not unlock. it's been two days now.... what should i do? tried unplugging unit, that...
Most ranges today use 3 different types of door locks...one is a solenoid controlled lock ( you hear a loud buzz noise when setting or unlocking the lock and has a arm that you must move to set the lock )...another is a heat sensitive lock ( has a arm that you must move to lock and un-lock, makes no noises and has a spring that slowly moves to lock the door will the oven is heating up )...Some locks are motorized ( no handle to move, the motor locks the door by it's self when you set the range for self clean )... If the motorized and heat sensitive locks fails to open after the self clean cycle, you must access the lock and move it yourself to open the door. On the free standing ranges, most times you must lift the cook top to access the lock mechanism. On built in ovens, the oven must be pulled out to remove the top access panel to get at the lock mechanism. Some build in ovens can have the control console removed to access the lock system. On the heat sensitive style of lock, there are no electrical parts to operate the lock, usually you will need to replace the lock. On the motorized style of lock, you will have to use a ohm/volt meter to test why the motor will not work. On the solenoid style of lock, the solenoid is often mounted on the back of the range and can be accessed by removing the rear panel, some may be mounted at the front, such as in a built in oven. The failure of the solenoid style of lock is normally caused by a bad lock solenoid In order to get your door open, you must operate the door latch mechanism manually. Unplug or remove power from the range. Take the rear cover off the range. Locate the door latch assembly and operate it manually and open your door. Then check continuity of the solenoid. Some of the latch assemblies have micro switches to supply power also. You may need to check them. You should be able to get the door open and use your range until you can get a tech to repair if you can not repair yourself.
Sep 09, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Our GE Profile JTP18 keeps flashing "door lock" since we ran a self clean
most of the time a simple fix.... http://www.geappliances.com/search/fast/infobase/10004586.htm
you have to trick the door lock mech into cycling through the cleaning process (takes about 20 seconds)
Print Range - “LOCKED DOOR” flashes in the display
If “LOCKED DOOR” is flashing in the display of your range or oven, and the self-clean cycle has not been selected, follow the steps below to reset your control:
Motorized Switch
    1. With the door open, locate the door jamb switch on the face of the oven. It will look like a small black post or dowel.
    2. Push it in until the oven cavity light goes off, indicating that the oven believes the door is closed.
    3. While you hold the door jamb switch in this position, complete the following steps.
    4. Press the Clean pad, wait 10 seconds.
    5. When the cycle initiates, press the clear/off or cancel pad immediately to cancel it.
    6. Wait 10 seconds for the display to clear.
    7. The door should unlock and there should not be a need for service.
Manual Switch
    1. Press the Clean pad.
    2. Close the door.
    3. Slide the latch to lock the door.
    4. Hit the cancel button immediately.
    5. Unlock the door.
If the above does not correct the situation, a service technician will need to check your cooking product. To obtain in or out of warranty repair on Major Appliances, you may call 1-800-GE-CARES (800-432-2737) or schedule service online.
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Maytag MER6772 Gemini Electric Kitchen Range Logo
104 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
