Question about Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive
USB connector on drive case seems loose will. OS will not recognize
    Problem Solver:
  • 8 Answers
Do you have any important Data on there? If so, this may repair it, butit has chances to destroy your drive /data if you are not careful Wasit loose when you first used it? It could be the USB Connector that isunsoldered.
What you need:
-Tiny plate precision screwdriver, or something super thin (not too big)
like a blade (a screwdriver does a better job)
-Extreme care
-Your WD Passeport drive
-(Maybe) Low power soldering iron
-Patience
My solution would be to open the drive plastic case up.
Youmay use a tiny precision plate screwdriver, and gently insert in thegroove on the side where the light is, or behind it (opposite sidewhere the connector is). BE GENTLE THOSE ARE LAPTOP DRIVES AND ARESUPER FRAGILE! Do NOT Put the screwdriver deep into it, else you maydamage the drive. Once you pop it open after some gentle time, (Thereare no screws, only clips) move the screwdriver to pop out a few clips.Once done, you will see a laptop drive inside, and an USB-sata adaptopwhich connects to the drive. Look, maybe the connector is loose in thedisk itself, or maybe the USB connector is loose / unsoldered. If itneeds re-soldering, do it with a low power iron! Using high poweredirons will damage the components. You will need to remove a thin layerof foil. DO NOT DAMAGE IT! It is REALLY important. You must place itback when you are done else damage to your disk is imminent. You canlift it to unplug the connector. do not force it of, tilt it up anddown a bit to loose it up. do not touch anything else, else you maybreak something and render your drive inoperable permanently!
Ihave the same drive, and once the USB connector got a bit loose, otherthen the plenty of problems it gave me. I open it and it was simpleloose from the disk itself. I've took pictures of some of the steps,and uploaded them for you.
You may find the pictures at http://bzaddict.net/WDPassport
Hope that helps you!
Posted on Sep 03, 2009
Installation
hello,
Normaly you don't need a instalation disk because your OS will recognize it but in case it doesent enter in bios and then shold work.
Sep 07, 2012 | Galaxy 1 Bay (3500SGCB) USB 2.0 External...
Have just been given the Toshiba Hard Drive PX1396U-3T01, number 2978109s. No install instructions, or paperwork. He is now overseas. How do I install the HD, or get a driver?
Your Toshiba PX1396U-3T01 external HDD is USB-attached, so you'll need to acquire a
standard USB cable to accomplish the physical layer attachment. USB cables do not have
the same connector at each end - the system (computer) end has a USB "A" connector (flat-shaped), and the device end (HDD) has a USB "B" connector (square-ish shaped).
There is no software (driver) needed for this external HDD - support for USB-attached external
drives (either HDD or flash drives) is built into WinXP, WinVista and Win7.
IF your version of MSwindows doesn't want to recognize the Toshiba when you plug it in, try
START > Run > then type in "diskmgmt.msc"
then select the command "Rescan disks."
If you're running Mac OS or Linux, repost including your OS (operating system) info.
Aug 15, 2011 | Computers & Internet
Windows 7 NexStar CX USB 2.0 3.5 inch SATA drive when connecting, windows 7 can't recognize the USB drive and shows a message "unknown device". The blue light of the the hard drive...
This is the usual reason:
USB port has 4 pins (connectors). The two at the ends supply 5 Volts to the hard drive (or any other appliance you connect. I don't think there's a problem with those two because you can see the power light on the hard drive.
The middle is for data transfer. If one gets damaged, although the device gets power, the OS cannot recognize the device.
Try changing the USB cable you are using. Connectors in the wire are damaged more easily than those in the device.
Jul 09, 2011 | Vantec NexStar-3 External 3.5inch...
Hi I accidently dropped my Dane-elec 4GB on my tile floor. Now it is giving message USB Device Not Recognized. I really need to get the last 4 pages of information I copied to it. What do I need to do? ...
There's a change the connector just came loose from the rest of the circuit board. Find someone you know who deals with electronics. Have them carefully pry away the plastic casing and you should have a better idea of what happened. If you have never handled a soldering iron though, this will not be a job for you.
A case like this unfortunately there is no easy fix/answer, but the good news is theres not much that could be damaged from such a short drop....
I hope this helps,
Magoo
Mar 08, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
How broken is this WD external HD
It's not broken.
Try to use a usb cable with 2 connectors(plugs). I mean, you plug one connector(plugs) in the hard drive and 2 connectors in the computer. Because you have 5 volts per usb connector.
Or you can use a small nokia charger to start the hard drive.
If you need further assistance please post
Mar 16, 2010 | Computers & Internet
USB recognizes it, but not the OS. I get no drive
Hello, nkhamo
Now, when you say USB recognizes it, do you mean you see the drivers being installed? Because if you are the OS is recognizing something has been plugged in.
Sometimes updating the USB Drivers will be needed. Do that by visiting the maker of your computer and search for Drivers and Updates on their Web Site, look for 2.0 USB drivers class, download that package to your desktop. The driver might be in the form of a Zip FIle. In that case, unzip the files using standard WinZip program or use software provided by computer, to a folder called cab. The driver program might show preference were it wants to unzip to. If so, let it do its thing. Then afterwards find the folder (cab or other folder) run USB driver by clicking install exe file. Note that all periperials need to be unconnected from all USB ports ( the port the laser printer connects to the computer at ) before updating USB drivers. So check cables for solid reconnection after installing drivers.
Its important to recognize the os you have. You'll find that information by clicking on Start Menu > Settings > Control Panel > System.
After doing this update, reconnecting the hard drive via USB Port.
Good luck, jasahasch
Aug 13, 2009 | Western Digital My Book Home Edition 500...
My computer doesn't recognize my external hard drive
Hi Trajan & Cossrock,
Both may be as simple as stopping in at the local computer store and buying a new enclosure to move the drive into, however in Trajans case if the drives were working as a stripe set yours will likely need more in depth help.
So Cossrock, pop into your local computer store and have them test the AC adapter, it may simply need replacing, if not then try moving the drive to a new enclosure. If that doesn't work then you will need the help of a Data Recovery Expert and I can point you in the right direction, just comment back here and let me know how you made out.
Trajan, if your NAS box was simply running two drives seperately you should be able to move them into seperate cases or another dual drive case similar to Cossrocks solution, however if they are RAIDed you will likely need more assistance, please check and comment back if they are in RAID format. Also even if they are not in RAID many NAS boxes use a Linux OS and therefor a Linux format on the drive, if this is the case comment back and I will get you a link to a Linux file format driver but please include your OS Wndows Vista/XP/2000, Mac, Linux etc.
Well folks hope this helps you both out and like I said comment back with an update if you run into trouble and I will keep helping on the next steps.
Chris
May 17, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
OnBoard USB ports (both front and back) will not recognize any devices
When you reloaded the OS did you reload all the drivers? Sometimes if you do not reinstall the Intel driver the USB port will not be recognized. Happened on the last two DELL's I reloaded. Go to DELL's website and download all the drivers for your model.
Dell support website http://support.dell.com/support/downloads/
Look up your model by service tag, it is the alphanumeric code on the barcode label on the back of your DELL and also sometimes found on either the front or top of your DELL (sometimes it is hidden beneath the USB port cover that you flip up.
Try that and see if it fixes it. Also make sure that the connector did not come loose when you opened the case.
Apr 30, 2009 | Dell Precision 360 Workstation/Personal...
Cruzer micro 4GB, unreadable in USB ports
sounds like your USB connector of the flash drive is damaged. Could be a loose/broken solder joint, or one of the pins on the USB connector could be damaged.
If it was my drive, I would open the case, solder a new connector on the board and backup the files.
Nov 09, 2007 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
PC won't recognize external usb HDD
You may not have installed the HDD correctly in the case... I had the same problem with my Thecus N1050 enclosure, the green power light on the enclosure would come on and the drive would spin up but my PC would not see the HDD!!??... I thought, becuase i could hear the drive spinning that i had it installed correctly but this wasn't the case, when i removed the enclosure again and FIRMLY pushed the HDD into the connector (all the way in) and connected it back up to my PC, it recognised it instantly. Hope this helps!
Jul 25, 2007 | Seagate USB 2.0 External Enclosure + 400GB...
Western Digital WD Passport 250GB Portable Drive 250 GB Hard Drive Logo
568 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
