Refrigerators Logo
Chuck Feldman Posted on Aug 25, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ice maker not making much ice makes only about 20 cubes all day
Elie Balas
Level 2:
  • Expert 170 Answers
  • Posted on Aug 26, 2015
Elie Balas
Expert
Level 2:
Answers
170
Questions
0
Helped
38404
Points
260
Ice maker only take water in and waits for the freezer to freeze it, then dumps it into the tray. If it take too long to dump, you are probably on the way to a freezing problem.
First check for presence of frost on the back wall of the freezer. You may also check freezer temp, should be at "0" . Note that a stocked freezer makes ice faster than an empty one.
write back if needing more help
3answers
My ice maker makes ice but melts fast
All ice is the same...at or below 32FH is ice, above 32FH it's water
Perhaps your ice maker is making very small ice cubes that melt faster then bigger ice cubes, if so the your ice maker needs to be adjusted too make bigger ice cubes.
1helpful
Samsung refrigerator rf26v ice maker
Check the condenser is clean and clear. Remove all fluff, dust or dirt from under and behind the unit
Our ice maker is making 5-10 cubes per day. Ice
OK, Have a look (if you can) and see if one of the water jets might be broken, or if there might be a defect in the tray. I can't help any further i'm afraid.
AMANA ARB2257C ice maker makes noise/doesn't eject cubes into bin
Hi: First off make sure the fridge is level. Is It too high in front? Making the rear of the icemaker overflow and jam? Also make sure the freezer section is a zero degrees, not just frozen. Ice cream should be rock hard. I hope this helps you avoid calling service. Thank You, Jeff
2answers
Ice maker does not consistently make ice...
try turning off ice maker for a day. remove the bucket that holds the ice. look all around bucket and into ice maker to determin if there is a jam, or if there is a cube stuck there preventing operation. Check that the ice arm can move freely and it is properly inserted on both ends. Make sure there is nothing in your freezer that could be getting in the way of the ice maker operation, either above or below the unit. One hint-wear disposable gloves when working with the ice maker-if you have any moisture on your hands, you tend to stick to the unit.
2answers
GE Side by Side: Ice Maker Issue
Is the freezer working at the correct temp ?? Is the ice maker feed pipe blocked ??
4helpful
3answers
Ice maker doesn't make enough ice to supply two senior citizens. This is the 2nd refrigerator we have had installed this month. What can we do to increase the amount of ice it puts out. The ice bin has...
Found in the FAQ section on Samsung.com:
Samsung refrigerator freezers produce about 120 cubes per day, which is in line with most manufacturer specifications.
Empty the ice tray and let the unit run for 24 hours.
If fewer than 50 cubes are produced during the 24-hour test, then your refrigerator requires service. Please contact Samsung Service at 1-800-SAMSUNG to schedule a service appointment.
If your freezer is producing 50 to 90 cubes per day, try the following:
  • Set the freezer temperature display to a lower setting. Freezer temperature must be 5 degrees Fahrenheit or less for the ice maker to work properly.
  • Make sure that the water valve on the refrigerator water supply line is completely open. You can find the water valve where the refrigerator water supply line taps into your house water line.
  • If you have a water filter in your refrigerator, change the filter cartridge. For instructions, see your Users Manual.
If you want your freezer to produce more than 120 ice cubes in a day, try the following:
  • An ice maker typically makes 1 tray of ice every 90 minutes. To shorten the amount of time the freezer takes to produce a tray of ice, set the freezer temperature display to a lower setting.
  • If your refrigerator has a Power Freeze function, press the Power Freeze button to speed up the ice making process. In the Power Freeze mode, both the compressor and the freezer fan run for 10 hours continuously. The ice making interval is reduced from 90 minutes to 55 minutes. If the ice bucket fills in less than 10 hours, Power Freeze stops automatically.
NOTE: If you have just installed your refrigerator, it will take 6 to 12 hours for the refrigerator to produce ice.
You should throw away the first three batches of ice cubes that the ice maker produces (approximately 30 cubes) to ensure the ice maker is making ice from clean water.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
