Question about Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE3 washer keeps filling with water
My Kenmore Elite HE3 front loader keeps filling with water when not in use. I can drain it just fine, but why does it keep filling with water? The washer was not used for the past two days, and today, I tried to open it to wash an item, but it was locked. I looked closer and saw that it was about 1/4 full of water (more water than it normally uses to wash).
I put it in the drain cycle, it drained just fine, and it operates just fine otherwise. Could this be a leak inside and how do I fix it if so?
  • 2 more comments
  • sportrider Nov 27, 2007
    where is the inlet valve located?
  • Anonymous Dec 04, 2007
    I have the exact problem. The difference is that it comes and goes. My washer did it about 4 months ago, stopped, and now it has started again. Is it something I can do myself?
  • Anonymous Dec 21, 2007
    Kenmore Elite front loader. Cold water slowly fills the drum when not in use. I turn the cold water valve off at the supply in between uses until I can get the replacement valve.
  • mruck Sep 05, 2008
    We had the same problem. The washer would fill - not all the time, but even after we replaced the input valve in the washer, it has recurred (with a full load of water all over the floor!). I'm now turning off the hot and cold input valves after each load, but I'm very frustrated at having to do this. Any suggestions?
  • 447 Answers
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Posted on Nov 16, 2007
    New Friend:
My washer fills but drains at the same time what can i do to fix it
Posted on Jan 09, 2014
My kenmore elite HE3 fills up with water when it is not running.
Hi... if your Washer is filling and its not running... you need a new water valve
Mar 30, 2011 | Kenmore Elite 45986 Front Load Washer
Water leaks into drum and machine intermittantly
The mixing value is leaking. I ordered a new one and will replace it.
Dec 20, 2009 | Kenmore Washing Machines
What is the most common reason for my washer to leak water
leaks are usualy from the drain or fill pipes, or door seal(front loaders), and lastly, the pump.
I recommend starting at the hoses, then check seal, then pump
Nov 10, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
I have a Kenmore Elite HE3 front loader washer. I
"F02" is a Long Drain error. The error code is generated when the drain time exceeds 8 minutes. In most cases this means you need to clean out the trap on the drain pump. The following link explains the error and how you need to remedy the problem. There is a follow-on link included that explains how to access the drain pump and clean it: If the error code reappears after you clean out the drain pump, you may need to replace the pump. If the pump motor or impeller is damaged and it is not pumping at the correct volume, the error code will continue until the pump is replaced.
A replacement pump (if needed) can be purchased at any of the following web sites:
Use whatever part source you like, but I have found these sites to be the most reliable and offer competitive pricing.
If you have questions, or need additional assistance, please let me know. I hope this helps you.
Sep 08, 2009 | Washing Machines
Kenmore HE3 front loader keeps getting F02 error message, most often when I wash towels. I was able to workaround by pulling half the load, but that no longer does the trick.
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and F02 is flashed.
Press PAUSE/CANCEL twice to clear the display.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F02 error code will be displayed.
Potential Causes
• Check the drain hose and make sure it is not plugged or kinked
• Check the electrical connections at the pump and make sure the pump is running.
• Check the drain pump filter for foreign objects
• If the above does not correct the problem replace the pump
Jul 13, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Full of water wont drain
had trouble with some washers not dumping water found penny screws and other small material in the pump removed and worked o k .this might help.hum might be from restriction in pump.
May 21, 2009 | Kenmore Washing Machines
Kenmore Elite HE3 washer door will not open
The error code F-02 on the Kenmore HE3 means that the drain pump could not pump out all the water within 8 minutes. Not sure what this has to do with the door being locked,, but its also possible that if the machine thinks there is still water in the drum, or if in fact there is still water in the drum that it would keep the door locked as some sort of safety precaution
Mar 13, 2009 | Washing Machines
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
2,050 people viewed this question
Sal De
 Brian Main
Brian Main
