Question about Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator
In the last week ice has tasted bad and bitter. Changed filter and cleaned freezer but no change.
  • 585 Answers
What about the refrigerator side? Air is exchanged between the refrigerator and the freezer to chill the fridge side. You could also try flushing the waterline, allowing any old water and contaminants/rust to purge away and try another new filter. Lastly, though the maker itself shouldn't be the problem, it's not hard to remove, usually just a couple of screws and one small plug. Clean the mold with mild detergent, maybe a soft brush, and rinse well.
I must insist that you unplug the appliance from power before attempting removal of the icemaker for your safety. Be sure to plug the appliance back in when done.
If that doesn't clear it up, you've just got bad water. You can either buy ice, or some ice trays and make ice from store-bought water.
Posted on Jul 12, 2009
  • 4,070 Answers
If this is old ice try new ice to see how it is. If it is new, freeze some water from the tap to see how it is(if your fridge water comes from the same source). Has the water been run enough to make sure the water has been through the filter.
Can you bypass the filter to see how it taste without going through it.
Ice tastes bad
If It were me I would change the filter in the fridge, that always worked on mine.
Dec 03, 2013 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice maker is makeing bad tasting ice water supply is good no bad taste in water , can it be cleaned
Change the supply line to the plastic tube line or copper. Do not use a braided plastic or metal braided line these will make the water taste bad. Changed mine to the plastic line and cured mine, no filters needed.
Oct 09, 2010 | LG LRFD22850 Bottom Freezer Refrigerator...
Ice tastes bad. How do you flush the system?
May 14, 2010 | Kenmore 76579 Bottom Freezer French Door...
Whirlpool ED25RF Does ice maker have a filter? My ice taste funny and sometimes its dirty
The ice maker doesn't have a filter , the problem could be the ice maker itself that the tray ,which is made out of aluminum is losing particles.Look at the conditions of the ice maker tray ,if you see like white spots replace the ice maker.
Aug 30, 2009 | Whirlpool Refrigerators
BITTER SMELL AND BAD TASTE IN ICE IN FREEZER
try putting an inline filter in your water supply line before you hook it to the waterline
Jul 12, 2009 | Refrigerators
Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Jan 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Ice from Ice maker smells and has a bad taste. Whirlpool model ED22TQXFW00.
if the ice has been in the freezer ice bin for a couple of weeks or if you added any food to the freezer that is not totaly frozen before adding then the ice will absorbe the odor of the food added, also the defrost of the evaperator will also add to bad ice taste
a new filter for the ice maker is maybe needed, depending on how long it has been since it was changed
if it has been changed, youcan try this whirlpool tip
put a small pie pan in the freezer and one in the fresh food section
add 1/2 inch of fresh coffee not coffee grounds to each pan
leave in for 24 hrs
dump out coffee in the sink drain
repeat the process
dump coffee in 24 hrs
odor GONE
Apr 15, 2008 | Refrigerators
Sudden low espresso quality
Have you been using the cleaning tabs regularly? If not, that is the first step. Second, if the time for brewing is too long then it goes bitter quickly. I time shots at about 11 seconds and add hot water after that. If you take taste tests for longer periods you can tell where it goes bad quickly and adjust the timer to stop at the right spot. Maybe timing changed. Have you had the wiring recall? If not, call Capresso and see if they'll still recall for free and they will also offer and exchange or full repair of existing unit.
Mar 02, 2008 | Jura Capresso C1000 Espresso & Coffee...
Kenmore 56549 / 56542 / 56544 / 56546 Side by Side Refrigerator Logo
111 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
