Question about Weber Genesis Silver B Grill
The wire on my grill caught fire. Now it will not light. What can I do?
    Problem Solver:
  • 6 Answers
You'll need to replace the igniter wire switch assembly. you can usually find them at the hardware store pretty cheap. follow the instructions and make sure the wire is properly shielded from the heat.
Posted on Jul 30, 2009
3 Suggested Answers
Treefrog15
  • 127 Answers
SOURCE: grill fire
Check to see if the flexible tubes from the burner assembly to the gas valves are clear, undamaged, and completely seated on the burner valve orifices. If these tubes are only partially seated at the valves, gas can leak and ignite under the control panel. If this happens, the control valves can be damaged creating a serious fire hazard. If in doubt, replace the control valves.
Posted on Jul 07, 2009
bulldogchief
  • 388 Answers
SOURCE: Grill fire
That large tray underneath the grill is supposed to be cleaned after each use!
Posted on Sep 10, 2009
Our cabana CNA480 Grill caught on fire. where can we find a new?
Try the bbq center in Calagry they are on line they may stock what you need .
Aug 28, 2011 | Cabana Kitchens CNA480 (NG) Grill
Our Weber Q grill CAUGHT ON FIRE TONIGHT !! RIDICULOUS ! It almost burned our apartment down - WTF ????
Not exactly sure what your question is, but there are a several reasons as to how and why a gas grill will catch on fire. And almost all the reasons, boil down to one thing - a lack of proper routine maintenance (i.e. Regular and frequent cleaning of the grill, checking the grill hose and regulator for leaks, keeping the grill a minimum of 6' from exterior walls when in use and turning OFF the gas tank when not in use).
I'm truly sorry, you had such a frightening experience, but in 86% of the cases, operator error is the cause.
Apr 17, 2011 | Weber Q Grill
Grill caught fire & went to 700 degrees
It should be OK. Just make sure you get ALL the greese cleaned out of the grill before you fire it up
May 14, 2010 | Kenmore 774 sq. in. Cooking Area Gas Grill...
The hose to the regulator caught fire and burnt off. I bought a regulator with hose, but it doesn't seem to attach.
Keep in mind that LPG valve threads are reversed (left to tighten and right to loosen). In addition tank valve and regulator fittings change causing confusion and problems.
Apr 25, 2010 | Fiesta Blue Ember Gas Grill
Grill fire
Aug 28, 2009 | Weber Genesis Silver B Grill
SEVERAL DAYS AGO,THE GRILL GREASE CAUGHT FIRE,TEMP WAS 600,TURNED OFF IMM.SINCE THEN GRILL LIGHTS,FLAME IS VERY LOW OTHER BURNERS LIGHT BUT FLAMEIS LOW. HAVE CHECKED GAS SUPPLY.EVEN PUT ON A NEW TANK.SAME...
The regulator is damaged. This is the little round between the hose connected to your knob adjustment and the Gas tank. This one is not expensive. it costs less than 30 bucks. Good Luck.
Jul 06, 2009 | Grilling
Grill fire
Jul 03, 2009 | Grilling
Char broil grill 463631705 lights ok. burns for 1-2 minutes ok. then the fire extends outside the grill box burning between the box and the controls. looking underneath it looks like the fire is following...
there is most likely spider webs inside those gas tubes...you need to clean them out with maybe a wire brush or such. lucky you caught it they can explode sometimes
Mar 07, 2018 | Char-Broil CharBroil 4637318 Grill
Weber Genesis Silver B Grill Logo
176 people viewed this question
Top Weber Grilling Experts
Paul Carew
Marvin
Marvin
Joseph Hoffmann
Are you a Weber Grilling Expert? Answer questions, earn points and help others
